Question about Nikon D60 Digital Camera
My nikon d60 was dropped by my sister and now the built in flash isn't working, what should I do?
  • 8 Answers
SOURCE: nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Posted on Mar 20, 2009
Steve5
  • 423 Answers
SOURCE: Nikon D60 highlight
When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
Posted on May 30, 2009
SOURCE: Flash on Nikon D60 does not work
Hello. When i first bought a D60, it was working perfectly outdoors at day and would work without a hitch with external flash. However, the internal flash would never get released. No menu option would be of any use, only symptoms were flashing 'flash' and 'question mark' symbols in the finder. NIKON service fixed it - There was nothing wrong with the camera electronics. The little flash release mechanism somehow acted up and NIKON staff fixed it in +- 5 minutes. I do hope you have yours in full working condition by now.
Posted on Jun 04, 2009
  • 1810 Answers
SOURCE: My Nikon D60 internal flash does not working. what
send the camera in under warenty make a recipt using quick books pro and send it in
they will fix if for the cost of shifing if within the first 60 days of recipt
Posted on Aug 03, 2009
SOURCE: Nikon D60 is taking very dark pictures!!
elis - did you ever solve this problem? the same thing is happening with my d60 and i don't know what to do!
Posted on Jan 06, 2010
Could the Sakar Dedicated Ittl Flash work For Nikon D60
Probable will not work on the Nikon's hot shoe because the contacts on the Sakar flash gun won't match the contacts on the Nikon's hot shoe.
You can use the Sakar flash gun as a slave flash by connecting a optical flash trigger to the Sakar flash gun and use the Nikon's flash to trigger the Sakar slave flash.
Feb 27, 2013 | Sakar Dedicated Ittl Flash For Nikon D60...
I have a nikon d60 and cannot get the pop up flash to flash, any suggestion
Go to menu then custom setting menu then turn your built in flash on problem solved
Nov 13, 2012 | Nikon D60 Digital Camera
I dropped my nikon d 60 and my shutter (flash) doesn't work n my lens is loose how much will it cost to get fixed
I would call Nikon's service department at 1-800-NIKON-US (1-800-645-6687). They are open 9AM-8PM EST, Monday to Friday.
Aug 30, 2011 | Nikon D60 Digital Camera
I dropped my camera now the flash is broken,
yes of course, there are a lot of brands that compatible with Nikon D-60 e.g Nikon itself, Metz, Vivitar, Nissin, Yong Nuo, etc.
The flash with iTTL support would be an advantage
iTTL is the feature Nikon has to measure the perfect light produced from the flash from the condition of the object
hope this advice help you with your problem
May 10, 2010 | Nikon D60 Digital Camera
Sure. Nikon makes a line of what they call Speedlights. The SB-400, SB-600, SB-800, and SB-900 will give you full capabilities. Older models will give you somewhat less capabilities.
Third-party vendors also make flash units compatible with the D60.
External flash units tend to be more powerful than built-in flashes, which makes sense considering their size and additional batteries. They also move the light source further from the lens axis, reducing red-eye, improving shadows, etc. They also may allow bounce flash, which further softens the light.
May 03, 2010 | Nikon D60 Digital Camera
May 19, 2009 | Nikon D60 Digital Camera
Sb-22 flash fires but d60 still opens the bilt in fash
I think you will need to upgrade to the 22s. It sounds like the newer model provides the D60 with a 'handshake' signal that the older 22 model does not have.
Sep 01, 2017 | Nikon Speedlight SB-22S TTL Flash
AC Slave Flash - How make it works
A slave flash unit is a flash that has a sensor that fires the flash when it senses the burst of flash from the camera's built-in flash unit. Since many digital cameras fire the flash twice for each picture (the first is to set white balance and perhaps focus), these units are designed so they fire when the camera's second flash goes off.
To use it with your D60, just use your built in flash to fire off the slave flash...
Mar 03, 2009 | Morris AC Slave II Flash
Nikon d60 flash coupler
If the camera has a flash shoe, you can get adabtors that go from the shoe to a cord and or connector. Check at a professional photo supply shop for details.
If there is no flash shoe, you can try using a flash with an optical slave to work with the camera's built in flash. But, this process has limitations, is expensive to do at high quality and reliability, and is not always the best way to go. Optical flash shoes can miss at times, and are subjected to reflection problems.
Jerry G.
Jul 04, 2008 | Nikon Cameras
Nikon D60 Digital Camera Logo
57 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
