Question about Vizio VX32L Television
My Vizio vx32L isnt getting power. the orange light comes on when plugged in but when you power it up the white light comes on but no picture. and it wont turn off unless you unplug it. please help me
  • 13 Answers
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Posted on Jan 22, 2010
2 reason causes this problem
1- power board need to replace
2- power switch is broke, try to pull that button out, move it slowly, to disconnect switch between on and off, then plug power to wall outlet. try it
Posted on Feb 19, 2012
The orange light isnt on
Make sure the power plug is secure both to the TV and the wall. Also make sure the outlet is not on a switch. Try and unplug and plug the TV back in. Try a different power outlet. Make sure you are pressing power on the TV itself as the remote may not be working. Otherwise TV may need service, and for this unit I would recommend just replacing it to save cost and frustration.
Apr 09, 2014 | Vizio VX32L Television
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
My Vizio VX32L LCD TV will power on but no picture or sound
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Nov 23, 2009 | Vizio VX32L Television
My vizio vx32L turns on but only a black screen shows up
Sep 30, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio VX32L 32" LCD HDTV has no picture or sound, won't shut off
Having the same problem, but thankfully, i purchased the extended warranty. i will let you know what they find.
Jul 15, 2009 | Vizio VX32L Television
Power Light comes on but no picture or sound.
for your VP50, it could just be simple as a power supply but it could also means more. Do you have the amber LED light when off and green when on? if so, try the main board first. If that doesn't resolve the problem, then change the sustainer boards.
May 28, 2009 | Vizio L32 32 in. LCD HDTV
Vizio model VX32L TV has no picture
80% of TVs are having this same problem in different brands.
I'm sure Carlos meant well. If you took it to someone to have it fixed, then yes, it would be cheaper to by a new TV. ( Labor + Part )
But, if you can repair your TV yourself for less than a $100 vs buying a new TV for over $450, would it be worth it? ( Part alone )
If you or someone you know can replace a whole ciruit board, then it can be fixed.
Here's a web site to get the replacement board:
http://www.shopjimmy.com/catalogsearch/result/?q=vx32l+back+light
You'll just need to find the right one by looking at yours. Your backlight board will have letters & numbers on it for a board model#. It should be easy to find one and replace it.
May 13, 2009 | Vizio VX32L Television
Vizio VX32L Television Logo
1,364 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
