Question about Hitachi 43FDX20B 43" Rear Projection Television
Ditorted picture - Hitachi 43FDX20B 43" Rear Projection Television
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
If colors are skewed, go into the customer menu and select convergence--if red or blue is wacked out and will not move--the convergence chips this set uses need to be replaced.
The 43FDX20B model uses two of the STK-392-120 chips and is fairly easy to repair for this problem.
If you have some skill and can solder I can tell you how to fix it---you can buy a pair of the chips on Ebay for under 13 dollars plus shipping.
Most shops are going to get 300 or more for this repair so if you or someone you know can do it you can save the set and a lot of money--
What it involves is replacing both chips and any bad resistors around them that got taken out---easy to check.
Let me know if you have questions or want instructions--I am here to help.
If this information helps take a moment and rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 12, 2009
Is there any way that you can fix this color problem with the remote if the chips are possibly not bad cause i have that curve on the top of the screen and there are two pictures in different colors
Posted on Jan 29, 2010
The sound is ditorted on my speaker, how do I fix it?
If you have an amp connected to the system you can turn down the power on the back of it this should reduce your distortion at high levels, you may have to do this more than once to get the right set up.
Sep 09, 2012 | Car Audio & Video
Screen has major digital ditortion (green lines, heavy contrast)
Personally i haven't had this problem but it seems to be that it's either the video board or the dmd board.. if you select the service menu and it looks like the rest of the screen, it's the videpo board, if not it's the dmd board
Jun 30, 2009 | Samsung HLR6178W 61" HDTV
When recording and playing back the view screen is distorted with alternating lines.
If there is no problem when you play back on a different camera or computer, then the fault concerns LCD ribbon cable or lcd controller circuit on main pcb.
If the recorded image is also distorted on computer and different camcorder, then you have a faulty ccd sensor.
Also wiring problem and pcb fault sometimes can cause ditorted picture, in that case the problem is usually a kind of dirturbance and does not happen all the time.
Regards.
Jun 24, 2009 | Canon ZR830 Mini DV Digital Camcorder
Not working right
Sounds like a cold solder joint,I would resolder
all pins in that one place
Good luck maybe this will help
May 15, 2009 | Uniden Bearcat Pro PC78LTW 40-Channels...
The in my HP Pavilion dv5000 laptop is ditorted but when I hold from the top it will work?
I think your problem is LCD. To make sure, try entering the bios when your pc starts. You can enter bios by pressing F10. If within the bios setup utility, your problem remains same then yoy need to change the LCD.
Nov 23, 2008 | HP Computers & Internet
Samsung HCL473w picture distortion
Check out the Convergence Gallery. If you see the colored outlines or color shading as in the Gallery, you have a convergence problem.
This requires the replacement of the defective IC or ICs and any damaged or smoked resistors. Usually there is little alignment required after the repair. If you play with all the adjustments before the fix, hours may be spent re-aligning.
Don't monkey with it.
This is a delicate and difficult repair. If not done by someone with some electronic repair experience, the TV will likely end up as junk or cost considerably more for a tech to fix the damage done.
If you live in Calgary, call me. If elsewhere, find a competent tech.
easyab
Feb 18, 2008 | Samsung HCL473W 47" Rear Projection...
I need to know how to hook up high level input from stereo to amp i dont have an adpater
honestly try to buy an adapter. very easy to hook up just use the rear speaker wires as a input
Jan 19, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Xbox 360 has sound but no picture on HD setting
Is the tv rated for HD? if its not the inputs will be at a wrong voltage and will create that snow like effect.
Is the TV you normally game on HD?
Dec 16, 2007 | Microsoft Xbox 360 Console
Channnel keeps flicking like your changing channels with remote
when you say flickering??? are you saying the screen goes black and comes back on?? does the sound go out at the same time and comes bag on with the pic ? Is the sound there when this happens but is distorted. Is the pic blacked out or is it greying out with lines and twisting?? Need more info please as if its blacking out and the sound goes with it it may be going into shutdown. If the pic is getting kinda greyish with it twisting and the sound is there and ditorted then the tuner could be bad
Mar 25, 2006 | Sony KV-32S26 32" TV
Hitachi 43FDX20B 43" Rear Projection Television Logo
462 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
