Touchpad inoprtative. - Computers & Internet
  • nmcquown Nov 12, 2009
    Aspire 5517 Series Notenook Pc.Model No. LXPH10x00293302ff1601. Touchpad is not working.
  • 4,806 Answers
You say your touchpad is not working so I'm assuming this is a laptop.
On most laptops you can disable/enable the touchpad by holding down Fn and hitting one of the F keys.
Can you tell me what make and model the laptop is please.
Posted on Nov 12, 2009
  • Lee Hodgson
    Lee Hodgson Nov 12, 2009
    Try to enable the touchpad by holding down Fn and hit the F7 key. See if that helps and get back to me.
    Good luck.
  • 6,487 Answers
This can be a problem with the driver for your touch pad that's why its not working now, first thing that you can try is to run the setup cd that contains all the driver for your laptop to reinstall the software for the touch pad, but if you dont have it you can also download the software for your laptop from the manufacturer web site so you can install the software back, but if this was working few days back you can also do a system restore to the date when everything was working, To do this system restore click Start menu>all programs>accessories<system tolls>system restore then just follow the wizard make sure you restore it back to the date when touch pad was working.............
  • Mark Gil
    Mark Gil Nov 12, 2009
    Did you already tried the solution that i have given you if not yet please do try it first and let me know what happen........
Touchpad won't scroll
hi there.
this is all i could find.
Why my TouchPad is not working in laptop Acer? Enable/disable your touchpad - Many systems allow you to turn the touchpad On or Off by pressing the FN and F7 keys at the same time. ... Reinstall touchpad drivers - Missing or incorrect drivers may cause your touchpad to not work properly. Check in device manager to make sure your touchpad is reporting properly.27 Oct 2014
Touchpad troubleshooting - Acer Community - 307854
community.acer.com/t5/Knowledge-Base/Touchpad-troubleshooting/ta-p/307854 Search for: Why my TouchPad is not working in laptop Acer?
or go to this link and read up some more if you need to.
Acer Aspire Notebook PC Touchpad won scroll Google Search
Nov 27, 2017 | Acer Aspire E1-571-6492 15.6" Notebook PC...
Cursor problem
Disabling the touchpad on a Dell Inspiron can be useful when typing for long periods of time, or using an external mouse. Bumping or tapping the touchpad while typing can cause cursor jumping and unwanted results. Use the touchpad software to enable or disable touchpad controls. Download the driver for your touchpad at the Dell Support website.
Click on the "Touchpad" icon in the task bar. If the icon doesn't appear, you can download and install the driver for the touchpad from the Dell website, or choose "Start" and "Control Panel." Choose "Device Select" on the touchpad menu, or choose "Mouse" in the "Control Panel" menu and "Device Select." Click "Disable" under "Touchpad" to turn off the touchpad, or click "Disable Touchpad/Pointing Stick When a USB Mouse is Connected."
h
Feb 28, 2013 | Computers & Internet
Laptop touchpad not working
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 09, 2012 | Toshiba Computers & Internet
Touchpad not active
hope this helps
Sep 05, 2012 | Computers & Internet
Where is the touchpad lock on the Hp probook laptop.
Hi.
Turn off the touchpad Most HP notebooks come with an on/off button near the touchpad. If you do not wish to use the touchpad at this time, press this button. Press it again when you wish to use this accessory again. If the notebook does not have an on/off button for the touchpad, touch and hold the top-left corner of the touchpad for approximately 5 seconds to disable it and do this again to activate it. When the touchpad is disabled, a small light will illuminate on the touchpad and an icon will appear briefly of the touchpad with a line through it. When the touchpad is activated, a small light will turn off on the touchpad and an icon will appear briefly of the touchpad. Alternatively, if the notebook does not have an on/off button for the touchpad, and you wish to turn the touchpad off, open the Mouse Properties window, select the Device Settings tab, and click the Disable button. You may re-enable the touchpad from here at any point.
Regards.
Sep 05, 2011 | HEWLETT-PACKARD ProBook 4520s Notebook
I can not unlock my TouchPad.
You might have disabled the touchpad accidentally. If the touchpad is disabled it is indicated by a yellow LED on upper left corner of the touchpad and when the TouchPad is active, the light is off.
To turn the TouchPad on, quickly double-tap the TouchPad off indicator (the yellow LED).
Hope it helps!
CreativeTECH
Jun 27, 2011 | HEWLETT-PACKARD ProBook 4520s
How to enable touch pad operation in ubuntu 10.04
Ubuntu provides configuration of the most common touchpad options in System > Preferences > Mouse, under the Touchpad tab.
Try the touchpad after unchecking the Enable mouse clicks with touchpad check box.
Check operation after Enable horizontal scrolling is checked. This may not have been the default setting.
Disabling Touchpad while Typing
  • Go to System > Preferences > Mouse > Touchpad and uncheck 'Disable touchpad while typing' and 'Enable mouse clicks with touchpad'
Feb 15, 2011 | Dell F3534 Touchpad
My touchpad buttons do not work
hi locate the FN key on lower left side of keyboard next locate the touchpad key usually one of the F1-F12 keys,press and hold the FN + the touchpad key together and release, now check the touchpad.
good luck,
let me know how it turns out.
ken
Apr 04, 2010 | Dell F3534 Touchpad
Quickplay touchpad above keyboard
The following illustration and table describe the computer TouchPad.
(6)
TouchPad on/off button Enables/disables the TouchPad.
Component Description
(1)
TouchPad light Blue: TouchPad is enabled.
Amber: TouchPad is disabled.
(2) TouchPad* Moves the pointer and selects or activates items on the screen.
(3) Left TouchPad button* Functions like the left button on an external mouse.
(4) Right TouchPad button* Functions like the right button on an external mouse.
(5) TouchPad scroll zone* Allows you to scroll up or down.
(6) TouchPad on/off button Enables/disables the TouchPad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 08, 2009 | HP Pavilion dv9000z Notebook
HP NC6400 touchpad
Hi i am an ex HP employee
here are the steps
Remove the TouchPad Assembly
  1. Remove the T8-9 mm screw that secures the TouchPad assembly to the base enclosure.
  2. Turn the notebook right side up and open the display panel fully.
  3. Lift the rear edge of the TouchPad assembly and remove it from the top cover.
  4. Disconnect the TouchPad cable from the system board.
  5. Remove the TouchPad assembly from the notebook.
Replace the the TouchPad Assembly
  1. Place the TouchPad assembly over the palm rest.
  2. Reconnect the TouchPad cable to the system board.
  3. Toe the front edge of the TouchPad assembly into the top cover and lower the rear edge into position until it snaps into place.
  4. Close the display panel and turn the notebook upside down.
  5. Replace the T8-9 mm screw that secures the TouchPad assembly to the base enclosure.
I hope it works out
Jun 04, 2008 | HP Compaq NC6400 Business Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
