Question about Sanyo DS19310 19" TV
Paperclip stuck in Antenna jack
A paperclip is stuck in the antenna jack in the back of my TV how can I get that out
    Sergeant:
  • 279 Answers
You could try a small, powerful magnet. You can get a magnet that is on a telescoping pole at some hardware stores - they're used to pick up dropped screws, and things like that. Something like this: http://www2.northerntool.com/product/200314334.htm
That might be strong enough to pull it out. As far as dismantling the connector - it's not really something you can take apart, or at least not something you can put back together afterwards. At best, you could open up the case, remove the connector and solder on a replacement connector. I think your best bet is the magnet pick-up tool.
-Dyllan
Posted on Jan 07, 2008
2 Suggested Answers
  • 279 Answers
SOURCE: paperclip broke off in my antenna jack of my TV
-Dyllan
No signal stuck on channel 2 with black screen. Model KDL37M3000
Are you connected to a cable or sat box, Are you connected thru antenna input on tv or a/v input. If connect to box thru antenna jack of tv do channel search to pick up ch 3 if box is set to that. If connected to outside antenna still do channel searsh but be sure tv is set to antenna. If connected via av or hdmi the cable or sat box is bad.
Apr 01, 2014 | Sony BRAVIA Televison & Video
Wpn824v2 reset
On the back of the device next to the antenna you will see a small inset button. Using a paperclip or pen. Press this button in while the device is powered on. Do this for 30 seconds then release. Next unplug the power from the device for another 30 seconds. Plug the power back in. Your device is now reset to factory defaults and can be re-configured or used as you wish.
Oct 09, 2013 | NetGear DG834G Router
I have a symphonic wf32L6 and i dont want to buy a digital adapter box, doesnt this tv have a digital tuner
Yes it has a Digital Tuner/ HDTV Tuner. Go into the setup menu of the TV and do a digital channel scan. If you still have an issue, post a reply/comment and I will help you further.
Jun 01, 2011 | Televison & Video
I purchased the RCA antenna and the end of the cord does not fit on the port of the zinwell box.
Unfortunately there is no way to make it fit. You will need to purchase an antenna. A paperclip unwound will work as a pretty good antenna temporarily and if you already have an antenna you can use it unless the problem is that the antenna you already had wasn't bringing in all of your digital channels.
Aug 18, 2010 | Televison & Video
Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 08, 2009 | Casio TV-980 2.3 in. Handheld Television
Hookup
Out to tv connects to your input or where the antenna for the tv is located. If you have an antenna hooked to you tv, remove it and hook in the vcr. Then put the antenna to input on the vcr.
Jan 21, 2009 | Zenith VRB410 VHS VCR
GE Spacemaker TV/Radio combination Model #7-7650
Yes, you will need an external antenna to pull in the digital signals. It will not work with the built-in antenna on the GE. Alternately, you can use an external antenna (ie, rabbit ears), connect them to the converter box, then connect the converter box to the antenna jack on the back of the TV (I think it has one). Granted, not an elegant solution for a kitchen TV, but it beats not using it anymore.
Cheers
Nov 11, 2008 | GE Televison & Video
Paperclip broke off in my antenna jack of my TV
-Dyllan
Jan 07, 2008 | Sanyo DS27800 27" TV
Sanyo DS19310 19" TV Logo
47 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
