Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
My tv will not turn on, I have tried different power outlets.
Tv won't switch on following power being turned off/on by electrician installing external light
Have you tried different electrical outlets? Maybe the circuit breaker for your particular outlet blew when the electrician turned the power back on. Or maybe the electrician disconnected power to that particular outlet.
Also try leaving tv unplugged for 30 minutes or so, then plugging back in [to a known good outlet] to see if it will turn on.
Apr 27, 2016 | Televison & Video
Tcl model 21k77
Try turnning your tv off, unplug unit from outlet, press and hold down the power button for 30 seconds, let go of power button, if plugged into surge protector try wall outlet, if plugged into wall outlet try a different outlet, power tv on using power button on tv. Did you have a storm in you're area?
Jul 24, 2013 | Televison & Video
We had 52' HD JVC Tv for 2yrs and the other day, the power button was flashing and didn't have a picture and now it won't even turn on. We tried unplugging it for a while and still nothing
This can be a power problem it can be a power problem inseide the tv or a power distribution problem from your power outlets. So before you send this to a repair shop you can try to plug the tv to a different outlet by using an extension cord. I understand that you have tried to unplug the tv for several minutes but plugging the tv to a different plug in can make a difference.
Sep 09, 2010 | Televison & Video
Turn tv on no power
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 27, 2010 | RCA HD52W59 HDTV Projection Television
Tv won't turn on. Flashing 5 times
Jul 27, 2010 | Sony Televison & Video
When i press the power botton the light blinks 14 times but tv does no turn on. what is the problem
Jul 25, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv turn on for a second and after turn off. it is hitachi 52" old brand.
Jul 24, 2010 | Sony KV-27V10 27" TV
Sony trinitron tube tv Standby is flashing and the tv wont turn on
Jul 06, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
MY SONY PROJECTION TV WEGA KP-FX432 BLINKS 10 TIMES THEN TURN OFF.PLEASE HELP ME
Jul 22, 2010 | Sony KP-FX532M91 TV
Sony tv power drop
Jun 13, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
164 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
