The automatic scanner tray on top cannot successfully pull a piece of paper through. The corner of the paper is getting caught on something inside and gets crumpled, which causes a jam error. I was curious if there was an easy way to open it up to see what the cause is. There are no visible obstructions from the outside.
Comments:
Jan 09, 2008
- I played with it long enough to figure out how to disassemble enough of what I needed to discover and remove the problem. Someone scanned a document that had a post-it attached. It came off in the roller and got crumpled up.
Paper is often guided via mylar /plastic strips within coopiers. It is possible that a certain section has been bent and is obstructing the paper path. It is not too difficult to open the document feeder - just be careful in remembering what came from where :) The obstruction could also be a piece of paper that was torn while removing a prior paper jam.
i have a sharp xv-zw99u projector. the bulb will only stay on for 5 minutes and then goes out.led...
(More)
I HAVE A SHARP XV-ZW99U PROJECTOR. THE BULB WILL ONLY STAY ON FOR 5 MINUTES AND THEN GOES OUT.LED LIGHT ON FRONT OF PROJECTOR FLASHES FOR FOR A FEW MINUTES THEN BULB TURNS BACK ON. THIS SEQUENCE KEEPS REPEATING.ANY IDEA WHATS WRONG ???
The toner message will not go away and when I played around with the Functions keys(F4) and changed...
(More)
The toner message will not go away and when I played around with the Functions keys(F4) and changed one of the settings ,eversince then I am not able to do anything with the copier all that displays is add toner.
