Question about Kodak EasyShare Z710 Digital Camera
Camera powers on, then powers off
I replaced the batteries and checked to make sure the connection is not loose.
    Genius:
  • Kodak Master
  • 1,099 Answers
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Battery support : KAA2HR,CRV3, 2xAA Ni-MH and 2xAA Lithium-Ion
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 12, 2009
My nikon coolpix L320 wont turn on
Possible Solutions.
1. Charge the battery
2. If still not turning on, try using a little alcohol and wiping the battery terminal(s) on the battery and the battery terminals in the camera. Use a QTip and allow to completely dry before recharging the battery or inserting it into the camera.
2. Replace the battery with new one.
3. On/Off switch may be defective on camera. Charger may be defective. Wire connecting power from charger to wall socket may be improperly connected or loose.
Aug 30, 2016 | Nikon Coolpix L320 Black Digital Camera...
Canon G11 won't start
Possible Solutions.
2. If still not turning on, try using a little rubbing alcohol and wiping the battery terminal(s) on the battery and the battery terminals in the camera. Use a QTip and allow to completely dry before recharging the battery or inserting it into the camera.
Jul 10, 2014 | Canon PowerShot G11 Digital Camera
Camera will not power on
Assuming that the battery is OK, there are two switches that if not operating the camera will not power on - one for the SD card door and one for the battery door. Both must be closed for the camera to power on. Also, the main switch is a micro switch. You can see the battery door switch with the door open. Carefully check to make sure the little arm is closing. Sometimes if the battery door is worn it will it not close enough to close the switch - try pushing up the battery door all the way and see if it then turns on. You would have to remove the back cover to check the on/off switch, and to replace it you have to replace the entire back cover assembly. The other common cause is one of the bottom board screws coming loose and shorting the board. Most of these problem require professional repair, but if it is the battery door you can usually find them on eBay.
Jul 07, 2014 | Canon EOS 60D Digital Camera
TOSHIBA M70 BLACK SCREEN
Check to ensure power cord adapter connection on computer is not loose or broken. Replace if required. Make sure power adapter is the right voltage for the computer. Make sure battery can be charge or replace battery.
Nov 19, 2012 | Toshiba SATELLITE M70-DL3 LAPTOP LCD...
My canon ixus 75 has no power.
There are many ways to troubleshoot this problem.
First try to insert new batteries and then tap on the sides of the camera and turn on the camera. It will switch on if the problem is due to loose connection.
Secondly, clean the battery terminal before inserting new batteries and check through a multimeter, whether the battery terminal is receiving the power properly from the battery. If there is no power, you need to contact canon to get the element replaced. If there is power in terminal and still not switching on there is some chance that lens is stuck inside, and it is not allowing to switch on. So clean the lens and try to turn on the camera it will work fine.
If you still have the problem then it tends to be the problem of the circuit board inside the camera.
Hope this helps.
Shane
Feb 02, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera powers on, then powers off. New batteries
Remove the battery
Contact KODAK:
Nov 12, 2009 | Kodak EasyShare Z710 Digital Camera
Replaced battery and starter both where bad. Truck
loose connections and starter relay in power distribution box under hood. Make sure you dont have a loose or poor connection on a ground or power wire from battery.
Oct 27, 2009 | 1997 GMC Sierra
Camera wont turn on
Check the internal contacts for bent, broken or improper connections.
Try inserting and pressing the battery in the camera while keeping the battery door open to see if the camera powers (This may help you determine if the battery is being held in correctly by the battery holder or the battery door.)
Cameras using AA type batteries
Check that the battery door closes properly and is snapped into place properly. Make sure there are no cracks or any defections on the battery door.
Mar 31, 2009 | Olympus FE-310 Digital Camera
Won't run on batteries
the connectivity with the battery terminal is a problem .open n check there may be some loose connection on the points where ur battery inlets supply connection on the main board of ur camera.
Dec 17, 2008 | JVC Video Cameras
Not turning on
The batteries probably need to be replaced. Be sure that any batteries seat properly and tightly. You may have to tape the battery door shut with strong tape to keep the contact tight. This type of damage is expensive to repair compared to the cost of the cameras. You can take it in and have it looked at, but be sure to get an estimate and then you can make an educated decision on whether to repair or replace it.
Best wishes to you and Thank you for using Fix Ya!
Aug 23, 2008 | HP Photosmart 435 Digital Camera
Kodak EasyShare Z710 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
