Question about Kenmore Refrigerators
Frezzer stuck in defrost cycle
I have a Whirlpool (Kenmore) side-by-side refrigerator. intermitetly the freezer will completly defrost and everything in the freezer will unfreeze. this occurs about once every 7-8 and i am forced to remove everything from the freezer compartment. the refrigerator side is unaffected and the freezer will start working again the next day. I think that it maybe getting stuck in the defrost cycle. how can I correct this problem
  • Kenmore Master
  • 1,606 Answers
You have a bad thermostat . The piece the refrig temp knob is on ( not the freezer knob , it works off an adjusting rod ) .
Posted on Nov 12, 2009
Kenmore sidebyside 53552200 stoped cooling and defrosted completly light still works both frezer and refrigerator not getting cold
It could be stuck in defrost. Check your defrost heater, and see, if it is still hot. If it is, then the defrost timer is stuck. When it goes into defrost, everything, stops working, but the defrost heater and light. As long, as the defrost timer is on, nothing else will work, as far as the compressor, freezer fan, and any cooling/freezing.
Sep 07, 2014 | Kenmore Refrigerators
Frezzer door stuck
well you've probably gotten something jammed in there and now you will need to remove everything from the refrigerator. tip on sides to see if the jammed item will shift of of jam.
May 26, 2014 | Kenmore 73502 / 73504 / 73509 Bottom...
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hi i have a ge profile side by side. the digital temp inside the refrigerator side is reading frezzer 23 refrigerator 47. The frezzer wall is iced up. when i press against the frezzer wall the coil feels...
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Sep 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
Our Kenmore Pro gets stuck in the defrost cycle. When in defrost the freezer temp reads 43 and the cooler 50. The last time it was stuck I unplugged it and it seemed to reset it. How long should...
Defrost should last 15- 30 minutes...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 06, 2010 | Kenmore 60721 Refrigerator
Unit is not cooling. pool of water collecting in bottom of frezzer.
heatman101
Sep 04, 2010 | Whirlpool ED2FHEXN Side by Side...
My whirl Pool side by side is not cooling well, I have washed the coils completely and used the recommended thermostat settings, but I have had thawing in the freezer and in the refrigerator,the freezer...
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer wont defrost and fridge not cold
Better solution is to replace the defrost element,defrost timer,or defrost thermostat,one of these are not working and when replaced will fix the problem.
Aug 01, 2009 | Whirlpool GS6SHEXNL Side by Side...
The Frigidaire Gallery freezer has ice build up restricting air flow
#1. DEFROST TIMER stuck or defective. Not allowing DEFROST CYCLE to occur. Most probable.
#2. THERMOSTAT (cold control) has gone bad.
#3. CIRCULATING FAN. It pulls air from the FREEZER side into the REFRIGERATED side.
#4. and lowest in probability. LOW (leaking) coolant charge.
Mar 09, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
160 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
