Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
How do i add my password protection - Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
  • 2,260 Answers
Are you trying to secure the wireless network ?
If yes, then you will need to access the router set up interface.
On the router set up you will find the wireless settings option.
Here you can change the wireless settings of the router and also make it secure.
Click Here for more info
Posted on Nov 12, 2009
How do I set the password for an individual folder; i.e., F1 I want to password proctect the folder as well as rename the folder.
http://www.addictivetips.com/windows-tips/how-to-lock-and-password-protect-folder-in-vista/
  • 1 Select the individual folder that you would like to password protect. If you will be protecting multiple folders, it is easiest to place all of these folders into one larger folder and simply add a password to that master folder.
    However, it is also possible to add passwords to folders at multiple levels within the folder arrangement. This is an excellent way to allow certain users access to some documents by giving them the password for the higher level files while making the master passwords for the interior folders available only to those who have access.
  • 2 Highlight the designated folder, and left click on it to open the drop-down menu. Select the "Folder Information" option, and open the Folder Information menu. This will give you access to the various preferences that are adjustable for each folder, such as color, icon and name.
  • 3 Click on "Password Protect," which may be on the main menu or on a "Settings" or "Security" tab. Apply a level of password protection that fits your needs. Set a password for the folder that will be easily remembered. Click "Apply" in the bottom right corner to make the changes permanent.
  • Mar 14, 2011 | QuickPAD IR Keyboard
    Tip
    How to Make Invisible Password Protected Folder Submitted by Srikanth on...
    How to Make Invisible Password Protected Folder2761870.jpg Submitted by Srikanth on Thursday, 10 December 200930 Comments Do you want to password protect your folder? Do you want to make it invisible so that it remains unnoticed by the normal users? Well here is a way to do that. In this post I will show you how to make a password protected folder in Windows without using any additional software. Here is is step by step procedure to create a password protected folder.
    How to create a Password Protected Folder
    Step-1: Create a new folder (Right-click -> New -> Folder) and give it any name of your choice. For instance I name it as ABC.
    Step-2: Now in this folder place all the important files, documents or any folders that you want to password protect.
    Step-3: Now Right-click on this folder (ABC) and select the option Send To -> Compressed (zipped) Folder.
    Step-4: Now a new compressed zipped folder gets created next this folder (ABC) with the same name.
    Step-5: Double-click on this compressed zipped folder and you should see your original folder (ABC) here.
    Step-6: Now goto the File menu and select the option Add a password.
    ie: File -> Add a password
    Now a small window will pop up and here you can set your desired password. Once the password is set, the folder will ask for the password every time it is opened. Thus you have now created the password protected folder.
    How to make it Invisible
    Step-1: Now Right-click on this password protected folder and select Properties.
    Step-2: At the bottom select the option Hidden and press OK. Now your folder gets invisible (hidden).
    Step-3: In order to unhide this folder go to My Computer – >Tools -> Folder options. Switch to View tab, scroll down and under Hidden files and folders you’ll see the following two options
    • Do not show hidden files and folders
    • Show hidden files and folders
    Now select the second option and press OK. Now the invisible folder becomes visible in it’s location. To access it you need the password. To make it invisible again repeat step -1 through step-3 and select the first option and click OK. Now the folder becomes invisible once again.
    I hope you like this post. Pass your comments!! Cheers
    on Mar 30, 2010 | Computers & Internet
    I have a verbatim 4gb micro with a write protect error. I cannot delete the files, add more files or format the stick. Regards Mano
    It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties.
    Jan 06, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
    I need to password protect my router.
    log on to the modem as ADMIN
    Add A NEW USER
    Then add password for new user
    (write down the new user & password info)
    save your settings
    Test away
    Rate Me Please MISTERDJ
    Apr 10, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
    I need to add a password to my wireless network
    Do you want to secure the wireless network ?
    For that you will need to access the router set up.
    You said that you want to add a password. I don't understand that. Is your wireless network already secured ? Or you want to make it secured ?
    If it is already secured then it must have the password to connect to the wireless network. You can use only 1 password for the network. You can not use 2 password for the wireless network.
    If your network is not secured yet then you will need to make it secured and enable password protection on it.
    Click Here to know more about how to make it secured
    Nov 12, 2009 | Computers & Internet
    How do I protect my connection from unauthorized access.
    Hello, David.
    The best way to protect your wireless access from unauthorized access is to add a password.
    Without a password, if someone drives by your home with a laptop, etc. and sees your network, they can connect.
    If you are uncertain about how to add a password, contact your provider.
    Hope this helps.
    Nov 05, 2009 | D-Link DIR-615 Wireless Router
    Simpletech external hard drive is showing as write-protected disk
    Usually a protected hard drive has been in a laptop and the hard drive password is setup from the laptop's BIOS configuration. This password is embedded on the hard drive's chip.
    This password protects the data from unauthorized access and must be removed before reuse in another laptop or as an external hard drive.
    There are no backdoor passwords available and needs to be removed using that laptop's BIOS configuration, you need to know the password to enable you remove the password peotection.
    Mar 29, 2009 | Sony Computers & Internet
    Lock the keypad with thw help of password
    Go to Sitting> General> Security>Locks>
    There is two option SIM protections and phone protections.
    Any protection you want to add you can.
    If this thread help you then don't forget to mark answer.
    Nov 20, 2008 | Sony Ericsson Walkman W810i Cellular Phone
    How to password protect jfv30/4gb
    hi
    this is not a password protection device and hence u cannot.
    in case u want to add a software. this is possible by doing a local/freeware software. but no guranteee.
    driver for 98 are not available by manufactueres, but u can find it freely on net . try url http://www.technical-assistance.co.uk/kb/usbmsd98.php.
    bye and thanks,
    gipi, mumbai
    Mar 21, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
    Excel password is protected....... but not i don't know that password,,,,,,, so password are remove if i see that password
    Excel Password Remover 2008
    Instructions
    FAQ
    Disclaimer
    Excel Password Remover PRO
    Recommended links:
    Password recovery software (Word, Excel, Outlook, Exchange, Visual Basic modules, Access, Winzip, Lotus 1-2-3, Lotus Organizer, Lotus Wordpro, Backup, Project, FileMaker, Schedule+, Money, Paradox, Act!, Mail, Windows NT)
    Instant password recovery (Instant online recovery service for password protected MS Word and Excel files. Free online preview of encrypted file content. )
    Visual Basic Password (Instant recovery of VBA-passwords in Office programs)
    Excel add-in decompiler (Converts Excel add-ins into normal workbooks)
    Have you ever forgotten your Excel workbook or sheet password?
    Here you can download a FREE Excel add-in that removes/cracks sheet and workbook password protection in Excel®.
    NB! This program can't remove file protection, i.e. if you are unable to open the file, this program won't help you. You could try Excel Key to remove file protection. If you need to crack the VBA-password try this one.
    This Excel add-in (password.xla) works fine in Excel 5.0 and above (including Excel 2000, XP and 2003).
    This program will remove passwords of any length, also passwords containing special characters.
    Download here: password
    Feb 23, 2008 | Computers & Internet
    Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
    78 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
