Question about Brother MFC 420CN All-In-One InkJet Printer
Ink problem my ink is full, yet when i print the page comes out white. help!
  • tnisha901 Nov 12, 2009
    yeah i did that but it didnt work. what should i do now?
  • 149 Answers
Haveyou tried the cleaning the printing heads? there should be an option within the software that came with the printer
Posted on Nov 12, 2009
My printer will not print anything. I have a full cartridge of black ink, but low on the other colors. Will it not print with the colored ink out?
Assuming the test print page prints using the black ink, printers have a setting that allows you to select black and white printing. If you need further help you need to include the manufacturer and brand of the printer. If the test page doesn't print the black ink and Since you say you have a full black ink cartridge I would also check that you completely removed the plastic tab/sticker that covered the hole the the inks comes out of and that the ink cartridge is securly installed.
Dec 06, 2016 | PRINTER Office Equipment & Supplies
I have a canon MP600 I put a new #5 black ink cartridge in it, now it wo'nt print black. it shows full but only prints colors
Try wetting the bottom of the cartridge to see if ink will come out, it may just be dry, you can do this by placing the bottom into a little water or onto a wet kleenex, let me know how this works.
Jun 06, 2008 | Canon PIXMA MP600 all-In-One InkJet...
My hp deskjet 6940 inkjet printer doesn't show me level of ink in cartridge
Print a diagnostic page If the steps above have not helped, print and evaluate a diagnostic page to see if the cartridges or the printer is causing the problem.
  1. Make sure the printer is on and loaded with unused, plain, white paper.
  2. Press and hold the Power button and then press the Cancel button. Release both buttons. The diagnostic page prints. Figure 1: Power and Cancel buttonsc00584735.gif 1 - Cancel button 2 - Power button
Step 4: Note which cartridges printed which areas of the diagnostic page You must identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. Your diagnostic page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Figure 2: Diagnostic page layout (the patterns in each area may look slightly different on your page)c00584715.gif 1 - Printed by the right cartridge 2 - Printed by the left cartridge NOTE: If you are printing in reserve mode (one cartridge is missing), the missing cartridge's area of the diagnostic page will be blank. Step 5: Check ink levels NOTE: If you have installed a refilled or remanufactured ink cartridge, or a cartridge that has been used in another product, the ink level indicator is inaccurate or unavailable. Look in the middle of the diagnostic page. The bars with "E" (for "empty") and "F" (for "full") at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color. Figure 3: Left (tri-color) cartridge almost full - right cartridge emptyc00235259.gif Figure 4: Both left and right cartridges almost fullc00235260.gif
Feb 22, 2011 | HP Deskjet 6940 InkJet Printer
When I calibrate colour Magenta and Lt.Cyan fail to print
boil the head printer in a hot water for ten minutes and wiped it smoothly
Aug 09, 2009 | HP DesignJet 130NR InkJet Printer
Printer is printing blank pages ink levels read full.
Make sure that what you are printing from the PC is black. This sounds so trite, but if for some reason you have set the font to white you may be able to see what you have written on the screen - but it won't print. Another possibility is that somehow the print in the document has been set to 'hidden'. That doesn't help either.
Failing that you may have to reinstall the printer. Use the printer disc to do this.
Jul 08, 2009 | Lexmark Z600 InkJet Printer
Printer Pixma MX700 will only print in color not black and white?
Try going into Control Panel and click on printers. Normal 0 when the next window comes up, Click on MAINTENANCE, the Properties page will come up and this is where you can do the NOZZLE check/clean and other functions. The NOXXLE is more than likely clogged from lack of use and needs to be cleaned. It might take several times to clean it. Hope this helps. Bud
Jan 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
HP colour cartridge no. 22 won't print
if the test pages come out OK then the problem can not be the printer !!!!!!!
it must be from the application
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Internal test page fine, external prints black in blue
before you print, you have to check your options.
For example, if you want to print black and white, when you select PRINT from the menu, you click on PROPERTIES to the right side or bottom side, depending on which windows you use, then select grayscale/black and white, etc in the options that will follow to correctly use your ink, you can always REMOVE the ink from your printer as you only want to print black and white or non color pages.
I hope this helps you.
ManOwar
Jul 12, 2008 | HP DeskJet 845c Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
65 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
