Question about Microwave Ovens
Whirlpool gh5184xps over-the-counter microwave no power
Whirlpool gh5184xps over-the-counter microwave was used around 2:30 today. At approx 6pm it was dead - no clock, no nothing. It does have power to the outlet it was plugged into.
Could it be a fuse? Please help.
  • 456 Answers
There is a high voltage fuse in the unit attatched to the high voltage capacitor, it is the most common problem for microwaves not working. Also check the protective diode,the high voltage capacitor as well as the transformer if the fuse is ok. Good Luck.
Posted on Nov 12, 2009
Why is my microwave ticking like an old wall clock?
Good question. I have never heard that one before. Good luck
Mar 04, 2015 | Whirlpool Gold GH5184XPS 1.8 Cu. Ft. Over...
I have Whirlpool gold GH5184XPS its not heating. how to troubleshooting the problem?
There will be a technical sheet hidden behind the controller assembly or elsewhere.
There is a YouTube video here which shows you how to remove the controller assembly in about 5 minutes.
You can also find it online here.
It may be a bad door switch, controller problem, inverter problem, or defective high voltage part.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jan 08, 2013 | Whirlpool Gold GH5184XPS 1.8 Cu. Ft. Over...
Locating reset button on my microwave
To my knowledge none have a reset button or circuit breaker. If the unit is total dead there will be (has to be) a fuse inside the unit.
Dec 06, 2012 | Whirlpool Gh5184xps Microwave Oven...
Whirlpool GH5184XPS-7 microwave oven dead, no power.
The problem is in the magnetron or the inverter board.
May 27, 2012 | Whirlpool Microwave Ovens
Loss of power to Whirlpool over the stove AccuWave GH5184XPS-4. Checked circuit breaker and GFI -all OK. No other electrical problems known.
Remove unit and check trip/reset switch on unit. Double check GFCI receptacle with plug tester with GFCI test button.
Jan 12, 2010 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool GH5184XPS microwave -- no heat
The element is burn out or the reset or hi limit is out.
Mar 12, 2009 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool gh5184xps-4
type in the same info you just typed, in your browser and see what happens.
Dec 07, 2008 | Whirlpool GH5184XPQ Microwave Oven
F7 Error
This is schematic:
http://www.servicematters.com/docs/wiring/wiring_main.htm
But your correct model # is: GH5184XPS4
F7 Power to magnetron
interrupted
1. Check the door, hinge and cavity front alignment. Adjust as needed.
2. Check the operation of all interlock switches.
3. To check the over-temperature protection for the magnetron, unplug
microwave oven or disconnect power.
4. After 40 seconds, check to see whether this solves the problem.
5. If this solves the problem, check the cooling fan for proper operation or
blockage.
6. Unplug microwave oven or disconnect power.
7. Check resistance of the magnetron thermostat. It should be close to
0 ohms. If necessary, replace magnetron thermostat.
8. Check that the control cable to the 1100 watt inverter is correctly connected
to plug P2 on the display PCB. If necessary, adjust or reconnect.
9. If interlock switches operate correctly, replace 1100W inverter.
10. If problem persists, replace electronic control.
11. Plug in microwave oven or reconnect power.
Dec 06, 2008 | Whirlpool GH5184XPQ Microwave Oven
We have a whirlpool GH5184XPS-4 microwave that we are getting an F7 error on. We removed control panel and parts of the board were scorched. we resoldered in loose parts still have smae problem
From the technical sheet usually located behind the control panel or grille:
F7 Power to magnetron interrupted
3. To check the over-temperature protection for the magnetron, unplug microwave oven or disconnect power.
5. If this solves the problem, check the cooling fan for proper operation or blockage.
7. Check resistance of the magnetron thermostat. It should be close to 0 ohms. If necessary, replace magnetron thermostat.
8. Check that the control cable to the 1100 watt inverter is correctly connected to plug P2 on the display PCB. If necessary, adjust or reconnect.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Microwave Ovens Logo
375 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
