Question about Brio Toys
Hi: I am using BRIO Hyperion 8.3 and trying to revamp an old BRIO GUI/dashboarding *.BQY with a newly revised data file with updated data. I prepared the new *.csv data file and import it in the old GUI BRIO. The good news is that the old dashboarding accepts the new file's data. However . . . when I saved the old GUI-ized BRIO and try to reopen it after saving . . . I get the following error message: "The following section is damaged and cannot be read. It will be removed from the document." The new file totally disappeared. Interestingly, when you right-click the old "master file" ... it shows "Delete Section," "Rename Section," and "Duplicate Section" in the drop-down menu. But, when I right click the newly imported refreshed "master file" . . . it only shows "Delete Section" and "Rename Section." I tried adding a new table below the new master file to copy over the columns . . . and, do actually get a table that has all 3 (Delete, Rename & Duplicate) . . . but, if I save with all 3 tables showing (original master, new master and its associated copied table) . . . then, get out of the program and try to reopen it . . . I get the above mentioned error message about a "corrupted file" with only the original master table showing. However, if I re-import the new master file back into the newly saved GUI BRIO . . . its copied table magically reappears. Are there any ways to work around this "corrpution" problem?
  • 1 more comment
  • jbeazley Nov 16, 2009
    Jack:
    Thanks for your suggestion. I did go back into my imported *.csv file and look for any variables that had entries with quotes *(i.e. " " ) around them . . . and, did find my company name variable had a number of entries with quotes around them. I solved this problem last Friday by re-outputting the *.csv file in SAS and added some SAS code that stripped out all the quotes an eliminated the quotes. However, when I tried to re-import the corrected *.csv file into BRIO along side of the old "Master" original file (which I hoped to change the new imported file's name to become the new "Master" . . . the new file still did not save and gave me the same error message of "The following section is damaged and cannot be read." Still, it only showed "Delete Section" and "Rename Section" with a right-click. So . . good thought and suggestion . . . but, no dice. I'm back to square 1.
    Jerold
    Jack:
    I pulled the *.csv file into Excel and looked at the entries under each column . . . and, everything lines up perfectly. I don't see any data that is not aligned . . . so, that is evidently not the problem either.
    Using Excel . . . I decided to run a test by uploading a freshly created and frehly saved *.txt, *.csv and *.xls files into BRIO . . . with 4 variables (i.e., VarA, VarB, VarC & VarD) with 3 rows and just keypunched in 1,2,3,4 going across from left-to-right to give VarA, VarB, VarC and VarD some data in the fields. Then, I tried uploading each separately into BRIO. All 3 versions (csv, txt and xls) only showed the two sections of "Delete Section" and "Rename Section" when I right-clicked on the imported file. So . . . maybe the "corrupted file that cannot be read" error message has nothing to do with whether 2 or 3 sections pop up when one does a right-click.
    Jerold
  • jbeazley Nov 17, 2009
    I appreciate your assessment of my situation. I think you are correct in that it will take a number of calls to Hyperion BRIO/HP tech support to finally resolve this problem.
    President:
  • 2,777 Answers
This is a far too advanced question to explain here. Many factors in your database will make a difference on whether what you want to do is possible or not.
You are going to need to call BRIO / Hyperion / Oracle (all now just Oracle) at 1-800-633-0925
Posted on Nov 16, 2009
    Guru:
  • 1,049 Answers
Get it in there any way you can and then see if you have the option to repair the master table. Then save it out and see if the problem doesn't go away. If that doesn't work, look in your csv file. If it is comma delimited with quotes - make sure you don't have any entries with quotes in them, this botches the import process. Similarly, if you have no quotes, make sure that non of your entries have commas. I had a similar issue with an inventory system where the inventory item was a CD titled something like "Guy's "Spiderman""
Posted on Nov 12, 2009
  • 1 more comment
  • NA NA
    NA NA Nov 16, 2009
    Ok, well have you tried to open the CSV in Excel to make sure that the column headings and correlating data line up? The nice thing about Excel is that it will import regardless, but if the data is loosing it's format somehow it will show some kind of shift in the data or drop a subset of your data all together. Another suggestion is to check your carriage returns...Windows uses /r whereas Linux and many appliances use /r/n. Just a thought.
  • NA NA
    NA NA Nov 17, 2009
    Sorry I haven't been more help
  • NA NA
    NA NA Nov 17, 2009
    Ok, so you know it is something in that particular file right? ...and the file won't import but the other files will. So have you tried taking a subset of the file your trying to import, actually opening the file in notepad, word-pad, etc. and manually taking only the first...say...255 entries. This could tell you a couple things.
    1) If there is a particular part of the file that is causing the problem or if it is the entire file
    2) Could indicate that you have some sort of cap on the size of the data imported
Fix code 3141 3151 b200 0700 c000 0013 help me fix please .
Did you download the 12625 update from Microsoft and try it from USB? More info please, was the box modded in any way? The update you need is not the latest by far. Download update 2.0.12625.0 here
1 Plug your USB flash drive into a USB port on your computer.
2 Download the update file.
3 Click Save to save the console update .zip file on your computer.
4 Unzip the file. If you are using Microsoft Windows XP, Windows Vista or Windows 7 or 8, double-click the .zip file to unzip it.
5 Copy the contents of the .zip file to the root directory of your flash drive.
6 Unplug the USB flash drive from your computer.
7 Plug the flash drive into a USB port on your Xbox 360 console.
8 Restart the console.
When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Hope this helps
http://download.digiex.net/Consoles/Xbox360/Dashboards/2.0.12625.0.zip
Jan 29, 2015 | Microsoft Xbox 360 Console
Repair damaged pdf
See this theme on non-commercial resource: http://www.filerepairforum.com/forum/adobe/adobe-aa/pdf/417-%E2%80%8Bdamaged-pdf-file-cannot-open
Guide for PDFTK (Freeware)
1)Download Gui for PDFTK from the Paehl website.
2)Double-click the downloaded installer to begin the program's setup.
3)Click "Start," select "All Programs" and click "Gui for PDFTK" to open the program.
4)Click the "..." button next to "PDF file" and locate your corrupt PDF. Click the "..." next to "Target" if you are not happy with the output file name.
5)Click "Repair a PDF." Wait for Gui for PDFTK to confirm repairing is complete.
6)Close Gui for PDFTK. Your repaired PDF will be in the same location as the original PDF unless specified otherwise.
To read more about them pdf repair service online, visit:
https://onlinefilerepair.com
Oct 29, 2014 | Adobe Acrobat 7.0 Professional
How to Recover accidentally deleted data from formatted Linux partitions.
You can also try to use a very effective and affordable application for Linux Data Recovery from here:- Linux Data Recovery
Apr 18, 2014 | Computers & Internet
How do I set security on my DWL-952
There are 2 possible areas raised by this question. The first is a security patch needed to fix the firmware of your router, which by the way is not dwl-952. Your router is a di 954. Dwl 952 is a bundled router and network interface. The details of the firmware update are below.
Security patch for your D-Link router
These firmware updates address the security vulnerabilities in affected D-Link routers. D-Link will update this continually and we strongly recommend all users to install the relevant updates.
As there are different hardware revisions on our products, please check this on your device before downloading the correct corresponding firmware update. The hardware revision information can usually be found on the product label on the underside of the product next to the serial number. Alternatively, they can also be found on the device web configuration.
Please make sure you follow the firmware install guide provided within the ZIP firmware package.
DI-524 Revision E1/E3Thu, 28/11/13
The new firmware 5.13b01 that fixes the security vulnerabilities
DI-524 Revision Ex 5.13b01
Please note: please unzip the file and use the file DI524Ex_FW513B01.bin to update firmware.
DI-524UP Revision A1/A2Thu, 28/11/13
The new firmware 1.08b02 that fixes the security vulnerabilities
DI-524UP Revision Ax 1.08b02
Please note: please unzip the file and use the file DI524UPAx_FW108B02.bix to update firmware.
The second possibility is to set the local security on your network.
From the wikipedia page:
Wireless security is the prevention of unauthorized access or damage to computers using wireless networks. The most common types of wireless security are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA). WEP is a notoriously weak security standard. The password it uses can often be cracked in a few minutes with a basic laptop computer and widely available software tools. WEP is an old IEEE 802.11 standard from 1999 which was outdated in 2003 by WPA or Wi-Fi Protected Access. WPA was a quick alternative to improve security over WEP. The current standard is WPA2; some hardware cannot support WPA2 without firmware upgrade or replacement. WPA2 uses an encryption device which encrypts the network with a 256 bit key; the longer key length improves security over WEP.
The complete article is here
Wireless security
Log in to your router and find the wireless security section. Set up the security model that best suits your needs and then set up your wireless network card with the same information.
Mar 11, 2014 | Computers & Internet
Windows old restore
Hi, if you updated your operating system and the windows old file was created it can't be used to restore your system. The windows old file is like a backup of your data etc...You will have to do a fresh install of the operating system.
Jun 27, 2013 | Gateway M Computers & Internet
Http://www.nnvns.org/data/ratelist/Revised%20Rate%20%20(10-11)%20List%2016-03-10.doc this file not be open why plz help
I could able to download and open this doc file. Content is not compatable to my language so, some characters are not shown properly but there is a table in it.
If you want I can email it, please send and email to f1delphi@yahoo.com if want me to send it to you.
Be sure that you should have MS office word software installed at your computer to open this file.
regards.
Aug 22, 2010 | Microsoft Office Professional 2007 Full...
Error message coming on the screen when i start it
please follow the procedure below.
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
All the best
Regards
Richard.
Apr 24, 2009 | Garmin nuvi 205W GPS Receiver
Lost all memory on hard drive
Once it's gone, it's gone.
You can try loading the firmware update from Philips website, but this is unlikely to resolve.
Philips HDD – Reloading the Firmware Hack
1. Plug your GoGear HDD into the computer
2. From ‘My Computer’ right click the GoGear drive and format it. Be SURE you format it as FAT32 and quick compression is not on
3. Create 3 folders on the newly formatted disk called: ‘_System’ , ‘Data’ , ‘Media’
3. Download fom Philips the latest Device Manager for your kind of player
4. Install the Device Manager
5. On the Desktop, right click the Philips Device Manager shortcut, then Properties, then open file location.
6. Copy the folders you see there into the ‘Data’ folder
7. Copy the Firmware.ebn file into the ‘_System’ folder
8. Unplug the device and now it should run fine
-Tha Mp3 Doctor
Oct 16, 2008 | Philips GoGear HDD1830 MP3 Player
Symbol PDT3100 TFT300 & File Transfer
I would like to suggest since you are approaching to GUI enviroment you need to develop system build by visual basic using MSCOMM control by sending and receiving data between PDT3100 and PC.
Please try to visit www.planetsourcecode.com for best VB tutorials about how to use MSCOM1 or hire/chat me if you need my further assistance.
Good luck,
Philip
Nov 04, 2007 | Symbol PDT 3100
Toys Logo
345 people viewed this question
Top Brio Toys Experts
ray gallant
Are you a Brio Toy Expert? Answer questions, earn points and help others
