Water draining as it is filling the drum
My washer sometimes drains as it is filling. Sometimes it does it on the wash cycle or it may do it on the rinse cycle. I unplugged it last night as to 'reset' it. It seemed to work. It only happens cold
  • Washing Mach... Master
  • 43,501 Answers
The drain hose is not high enough and it is siphoning the water out. Get the highest point of the drain hose above the water level in the washer.
Posted on Nov 12, 2009
Washer just shuts down
If the washer is turning off mid cycle then the problem most likely has something to do with the draining or the filling.
First check the drain hose is not to far down the standpipe. If it is to far down then the water might siphon out during fill. The water would fill and drain at the same time. One cycle I would like you to try is the "Rinse Only" cycle. This is a simple, short cycle that should just fill once, drain and spin. If the washer will do this then the major components are most likely okay.
Make sure the water drains out and let me know if the drain pump is the source of the noise you hear.
Oct 19, 2012 | Washing Machines
Water won't fill
it's syphoning caused by the drain hose in the stand pipe (wall) too far.
pull the drain hose out and stick in 6 inches only and secure to one of the fill hoses so it does not go back down too far. This will solve your problem
Apr 05, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water Everywhere
Look for loose, cracked, pinched, broken hoses to and from the water pump or leaks from the water pump itself. The outer drum could have a rust-through that leaks. This can be repaired with epoxy, but the inner drum must be removed to access it. The cabinet top is opened by using a putty knife or similar tool to push straight back under each front corner which releases a spring latch. Sometimes, the drain hose outlet is pushed from the house drain by high water flow. Tie the hose to the drain with tape or cord. Fill the tub with water, then stop the cycle and watch for leaks.
Aug 07, 2009 | GE WBSR3140DW Top Load Washer
Rinse cycle wont fill
check your drain hose. needs to be at hieght of tub before entering the drain....should only be 3-4 inches in the drain and secured with a ziptie.
Jun 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal filter.......as a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
Incomplete wash cycle.
It sounds as if you have something acting as a flap causing the restriction. You should take the hose that leads from the tub to the pump off and see if there is anything just inside the tub. I have noticed that alot times you could have a coin that blocks the opening. You may have to remove the inner tub to remove anything in there
Dec 30, 2008 | Maytag SAV3655A Top Load Washer
Ariston awd121 washer will not complete wash cycle
I'm also having the same problem. I hate this machine!
Jun 28, 2008 | Ariston Technologies AWD 121
Maytag top load washer pavt244aww leaking into drain
Chad -- Your problem most likely is the drain hose is either
a) Clamped tight to a drain line of some sort allowing water to siphon out
b) Washer drain hose is Shoved too far down the drain pipe
c) Drain pipe is lower than tub of washer alllowing water to drain
Oct 18, 2007 | Washing Machines
Washer sometimes drains durring the rince cycle
Ave, sounds like you have a siphoning problem. Check your drain hose and make sure there is a gap to break the siphon. Sometimes I find the drain hose shoved too far down the drain causing this problem. Another thing you might want to check is the drain itself. Is the drain water backing up causing the drain hose to be submerged after the initial drain? Catriver..post back.
Nov 18, 2006 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
