Question about HP PSC 2175 All-In-One InkJet Printer
When i start the printer, after the intilisation it starts clinking and all lights flash with message that there is fault in the scanner. How do I fix this?
    President:
  • 787 Answers
This is a problem in scanner section on your printer.You need to disassembly the printer and pull out the scanner section.Open the cover of scanner section and you'll see the mirrors inside.You need to clean the ash from these mirrors using cloth which leaves no hairs.
WARNING! If you don't have a technical skills don't try to do anything.
If this not help you need to replace the scanner section.
Posted on Nov 12, 2009
Gearbox fault problem
You do not say if it is an auto box or a manual box.
It could be a run-down battery..... or something more serious like a faulty starter motor...
Oct 06, 2014 | Vehicle Parts & Accessories
Keeps flashing up error and light a b c keep flashing
you either have a paper jam or the scanner module has jammed. open the printer and check the paper path for possible jams. then open the scanner lid and make sure the scanner light bar is in the home position at the end of the scanner deck and not stuck mid path.
Feb 27, 2012 | Canon Office Equipment & Supplies
Everytime I turn my printer on (Epson Artisan 700 series printer) it waits for about 5 to 7 seconds and then displays a message that says "A scanner error has occured. Please see your...
when I turn my printer on (Epson Artisan 700 series printer) it waits for about 5 to 7 seconds and then displays a message that says "A scanner error has occured. Please see your documentation". Then all the lights start flashing, And then I cant do anything, but turn the printer off.
I have turned it off and unplugged it and tryed again always same result.
bdl12920@aol.com
May 10, 2011 | Epson Stylus Multifunction Inkjet Printer/...
SCANNER ERROR
Message comes with Printer Scanner Error 6
Turn Off Then on
Jul 21, 2010 | HP LaserJet 3055 All-In-One Printer
Electric fault
You might try removing the battery connectors for five minutes and replacing back.
If the codes do not disappear, please you might have to get a scanner to do that.
Cheers.
Dec 15, 2009 | 2000 Alfa Romeo Spider
HP 5500 can not print with 59.CK error code on display
You probally need to contact an engineer on this one, from HP trouble shooting manual
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
1. Press the green <Tick Symbol>(Select) button to continue.
2. Turn the printer off, and then turn the printer on.
3. If the error message returns, turn the printer off.
4. Perform a cold reset.
a. Turn the printer on.
b. Watch the control panel.
c. When the memory starts counting, press and hold the green <Tick Symbol> (Select) button.
d. Continue holding the green <Tick Symbol> (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
e. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
f. Press (Down Arrow) button once. The control panel will display COLD RESET.
g. Press <Tick Symbol> (Select). The printer will perform a cold reset and then continue its power-on sequence.
5. If this message persists, contact an HP-authorized service or support provider.
Sep 22, 2009 | HP LaserJet 5500 Printer
Jag S Type won't start,alarm sounds lights flash fault messages
try taking the negative off the battery for 20 secs then put it back on and try it
Feb 08, 2009 | 2004 Jaguar S Type
C3150 print cartridge
  • Remove the cartridges.
  • Turn off the printer.
  • If the cartridges are leaking, put the print head on some tissue, so it can extract the excess ink. With a dry cloth, clean your scanner. Look inside the printer. If there is ink in there too, clean it. Use a lot of tissue or toilet paper. Might put some gloves on too.
  • When you make sure that the cartridges are not leaking anymore, gently wipe the electric contacts on them, and clean the ones on the cartridge carrier.
  • Turn the printer on.
  • Try printing.
  • If the cartridge light keeps flashing:
  1. If a computer message indicates a specific cartridge, that is the problem cartridge.
  2. If there is no computer message, look at the Start Copy lights - if the Black Start Copy light is blinking, the cartridge on the right is the problem cartridge.
  3. If the Color Start Copy light is blinking, the cartridge on the left is the problem cartridge.
If you find out which cartridge is the problem, you will need to replace it.
Unfortunately, the ink that has leaked inside, might have damaged your printer.
Dec 31, 2008 | HP Photosmart C3150 Printer
Epson 3490 scanner red light flashing message that printer cannot properly communicate with pc
If the start button light is flashing red, it is because of one of the following problems:
  • The scanner is not connected to your computer properly or your software is not fully installed.
  • The transportation lock is locked. Slide the lock to the unlock position.
Jul 16, 2008 | Epson Office Equipment & Supplies
Scanner not responding to preview scan
Try this as a last ditch effort. Remove the software. Reboot the computer and come off line. Disable the Anti Virus program. Now install the soft ware. Then try. If the red light still flashes then assume it is new scanner time.
Jul 26, 2007 | Epson Expression 1640XL Flatbed Scanner
HP PSC 2175 All-In-One InkJet Printer Logo
99 people viewed this question
Seeker5211
Seeker5211
