Question about HP Officejet 4215v All-in-One Printer
Removed the jamed pdper but printer still indicates a jam
  • 132 Answers
Turn it off and then unplug it turn off your computer then turn the printer back on and then the computer
Posted on Nov 12, 2009
PAPER JAMED IS THE PROBLEM OF DC BOARD AR NOT
hai,
paper jamed in some areas have moiture or dirty etc.,
but,, dc board indicate the location.
IF DC BOARD CHIP IS DEMAGE DUE TO HANDLING THE WORK PLACE. PAPER JAM PROPLEM IS CREATED.
best of luck..
Mar 16, 2011 | Canon imageRUNNER 400S Copier
My paper keeps jaming
paper keeps jaming - Brother MFC-3240C All-In-One InkJet Printer
Nov 09, 2010 | Brother MFC-3240C All-In-One InkJet...
Paper jamed
THERE SHOULD BE A COVER AT THE BACK OF THE PRINTER THAT COMES OUT(WITHOUT REMOVING ANY SCREWS). TRY REMOVING THAT COVER AND CLEAR THE PAPER JAM.
Apr 09, 2010 | Brother MFC 420CN All-In-One InkJet...
Paper Jam cleared but?
It sounds like the paper sensor in the paper try is broken or jamed. Remove the paper tray and locate the paper sensor. Check if it is jamed in the up position or if it is broken.
Jan 21, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
Error Light on Brother HL-2170W
Do not try to depress the green lever, since you need to remove the cartridge AND its base altogether. Just grab the front middle part of the assembly, pull it out slowly and steadily. You may need to apply extra force in doing so as it does take some effort to disengage the cartridge assemly from its seated position.
After the cartridge is removed, you may find some jamed paper inside. simply remove it and the printer should work again.
You may email me at stevenjoy@gmail.com should you have further questions.
May 12, 2009 | Brother HL-2040 Laser Printer
Misfeed Indicator light is on - there are no jamed copies present. Other solutions recommended. Thank you
Make sure that there isn't any little piece of paper caught near a sensor. Often when a jam is removed, the operator rips the paper, leaving some if it there inside. If it's near a sensor, you'll get a constant jam indication. Use a flashlight to check for it.
Feb 21, 2009 | Sharp AL-1642CS Copier
MF5750 All-In-One Laser Printer DOES NOT PRING indicate paper jam I check and there is no paper jamed in the printer. It starts as it will pull the paper to copy document and then indicates in the display...
It starts as it will pull the paper to copy document and then indicates in the display that the paper is jamed.
Can anyone explain what the problem my be?
Please assist me.
Jan 19, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Paper jam
Remove the paper following the procedure below.
(1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
Do not load it in the landscape orientation.
(2) Turn off the machine.
(3) Turn on the machine.
The paper is fed and then pushes out the jammed paper as it ejects.
If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
James Mac
Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
HP Officejet 4215v All-in-One Printer Logo
Ben Johnson
