Question about Panasonic Panafax UF-890 Plain Paper Laser Fax
Paper Jams I have a panafax UF890 Fax and the paper jams when it's attempting to print. The jam occurs between the feed tray and toner cartridge. I've tried cleaning the rollers, but there is no change.
  • 25 Answers
Try changing out the toner cartridge if cleaning rollers didn't work.
Posted on Jan 25, 2008
Our printer is not picking up the paper from the tray and is saying it is jammed. There is not jam.
Hi there !
Is your printer had jammed before and it stop printing in the middle of printing? For some reasons, paper can jammed due to printing interruptions, printer turn off, improper loading or feeding of paper, roller feeder had problem and others.
If jams before and paper have let inside the printer, please do the following first:
1. Check th paper tray, see inside if the paper is jammed inside that compartment. If there is paper jammed, remove, turn off your printer and turn on. This will solve your problem.
2. If not, open the printer cartridge door, remove the toner cartridge and look for paper jammed inside. If these is paper inside, remove it, turn off the printer and turn it on.
3. If you cannot see the paper jammed inside, the paper maybe inside the heating area. To remove paper, just turn off your printer and turn it on to roll over the paper jammed inside of it.
4. If the printer is blinking and saying there is paper jammed. You have to check the cartridge toner by opening the cartridge door, remove the cartridge and return it back but be sure it is well firmly fitted.
If following the 4 diagnostic procedure and you cannot locate the jammed paper, the problem lies on the toner cartridge itself. When toner cartridge is not rolling over, it will stop feeding the paper and it will cause printer to jammed.
To diagnose the problem, put old printer cartridge and if no toner power, just shake it well and I am sure there is still small amount of powder inside it and if it prints, the toner cartridge you purchase is defective. Reason, factory defect or improper refilling and part is not working well.
I hope it is helpful and thank you for using FixYa !
Jan 06, 2011 | HP LaserJet P3005n Printer
Hi. Everytime we use a new toner cartridge in our UF590, it works for so long and then has a paper jam evertime it tries to print a fax.
When did you replace the toner crg?
It may be that drum isnt turning, and when paper comes to the drum it jams.
New crg should resolve the problem.
But you also want to check the pick up, feed and separation rollers.
Jun 02, 2010 | Panasonic Panafax UF-595 Plain Paper Laser...
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
ERROR CODE #021
Try a new toner cartridge. If that doesn't take care of the problem, it's the fuser.
Apr 08, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Print fragmented documnts
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Aug 14, 2008 | OKI MICROLINE ML-395 Matrix Printer
Light blinking
Step1
Step
Step
Step
Jun 02, 2008 | Epson FX 1170 Matrix Printer
HP 4700n Paper Late Jam
duplex area related jam in other printers. is problem only occurring in tray 1. If so, there is a problem with the tray. If it's happening from tray 1 and tray 2, replace try replacing transfer belt.
May 27, 2008 | Office Equipment & Supplies
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Print out very light
Step1
Step
Step
Step
Apr 17, 2008 | HP LaserJet P3005dn Printer
PAPER JAM MESSAGE, BUT CAN'T FIND ANY JAMMED PAPER
look at the paper tray,some of your sensor are jammed,try tyo find out where is the sensor on paper try
Feb 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Panasonic Panafax UF-890 Plain Paper Laser Fax Logo
229 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
