Question about Freezers
Chest freezer I need to find a specific part for an older chest freezer. It is known as a "Christmas Tree." Do you know what I am looking for?
  • 417 Answers
No sorry try and see if the part already has a part number on it.
Thanks J
Posted on Feb 16, 2008
Hi, Anyone tell me where I can buy a key for the lock on my chest freezer ?
I just checked out eBay they have deep freezer keys hope this helps Merry Christmas
Dec 09, 2017 | Freezers
Sear chest freezer stop working model#2539139180
The compressor probably shut off on thermal overload. This protects the compressor from burning up. What has happened is that a capacitor or evaporator has gone bad or it could be low on freon. Have someone take a look at it. However, if it is older than 8-10 years old, consider replacing it. This could be the beginning of the end.
Feb 02, 2013 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
Temperature swing specification in a chest freezer.
It depends on the control that your freezer utilizes.
If your temp control dial has the numbers 0-9 or 1-9, then you have whats commonly known as a coil temp sensor.
Unlike an air temp contol that measure the air temp inside the freezer and comes on and off with a 3-5° swing, the coil temp sensor runs a little bit different.
With a coil temp control or sensor, the temp control has a capillary tube and bulb that is inserted into the coil either at on of the ends down a guidetube or just into the center of the radiator type fins. This temp control measures the temperature of the coil, and not the temperature of the air inside the freezer. When the unit runs, the coils typically gets 20° colder than the air temp. And when the control satisfies (shuts off), it will not call for cooling again until the sensing bulb has reached the cut-in point which is typically well above design box temp.
So, to quickly answer your question, yes it is possible to have a 25° temp swing and not have anything really wrong with the unit. That is how its been designed to operate and that is how it will operate. Your only option (although not recommended) is to replace the coil temp sensor with and air temp control. That will give you more consistent temps.
Also, when taking temp of a freezer with a coil temp sensor, be sure to temp the product in the freezer and not the air temperature.
Jan 01, 2010 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Can I Mount Casters with Screws into Bottom of Chest Freezer?
youyr best bet would be to build a frame that the casters are welded to and there are no holes in the outer shell of the freezer. some L shaped angle would work nicely for this application and then there would be plenty of support for when the freezer is loaded up with product. Be sure that teo of the casters are lockable and two in the swivel freely.
Dec 26, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
the settings usually are:
off - on - superfreeze. you just want "on"
Nov 16, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Kenmore 12 Chest Freezer - Needs New Lid
All you need is the model number
It gives you a list of all parts you can buy to replace what's broken, as for the frost try placing a sheet of plastic over the insulation, under the the plastic cover to keep moisture and humidity out of the insulation.
Apr 25, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
60 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
