Question about Craftsman Drills
I Have a Craftsman Pro 1/2 in Hammer Drill . The Keyless Chuck is $50 plus ship and Hand. puts it over $70. Is there some type of off brand or can any replacement chuck work
  • 2,176 Answers
Any replacement chuck will work as long as it is the right thread size and made for a hammer drill. I would try and find a JACOBS chuck for this. You should be able to pick it up locally.
Posted on Nov 13, 2009
How do i change the sds chuck to the standard chuck on an kango 220k hammer drill
do not think that is an option . get another drill with standard chuck .
Oct 05, 2015 | Hammer Drills
Craftsman 19.2v drill. What is process remove the chuck. The back side of it has 17mm dual flat spot. I tried 17mm open end thin bike wrench but I cannot get the chuck to unscrew. I need it off in order to...
Hi Charles! The chuck is fixed to the spindle by a bolt (with Ph2 or hex head), you can find the bolt head if you look directly into the chuck (with its jaws completely opened). You'll just need to fix the chuck (with your hand most probably), and unscrew that fixing bolt (might be with left-hand thread! - don't use excessive moment, first try it gently both ways). After removing the bolt you'll just need to gently tap the bottom of the chuck - through a piece of wood - with a hammer, to remove the chuck from the spindle. Gently is the key word - in order not to damage the chuck and ball bearings/gear set of the drill.
Below are 2 reference links from Craftsman and Sears Parts catalogue - may help you as well.
Good luck! Craftsman C3 19 2 Volt Lithium Ion 3 8 in Drill Driver Kit Craftsman Drill Parts Repair Parts
Mar 28, 2015 | Craftsman Drills
How do i remove a keyless chuck from a Craftsman 19.2 volt 2-speed drill
Inside the chuck you will find a screw (probably torx) this is a left hand screw (Remove clockwise)
Insert a 1/2" allen key into the chuck and using a hammer strike it to spin the chuck off (Standard thread - Counter-clockwise)
Mar 09, 2015 | Craftsman Drills
I have a makita BHP451 drill/driver with a keyless chuck and the gear box has striped out. I have a new gear box but do not know how to get the chuck off. I see a slot in the chuck that looks like you my...
The chuck has a left hand threaded screw inside. Turn to the right when removing the screw. Once the screw is removed you can remove the chuck by turning it to the left as it has standard, right hand threads. It is easiest to insert a large, L shaped allen wrench into the chuck, tighten the chuck, and hit the wrench with a hammer to spin the chuck off.
Jul 11, 2011 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
How do you work the keyless chuck on the 6.5 amp 3/8" rear handle pro drill?
Most drills with the keyless chuck work this way. Put the drill into reverse. Grasp the chuck with your left hand, and then pull the switch slowly. This should release the chuck. If your drill has no reverse, then grasp the chuck again with your left hand and hold the drill with your right hand. Turn the chuck with your left hand quickly, this should release the drill as well.
Mar 17, 2011 | Craftsman Garden
Need to change chuck
When you buy a replacement chuck it will have detailed instructions- at least Jacob's brand chucks do. Basically there is a retaining screw inside the chuck that needs to come out first- it may be left-hand threads . Then you put the short end of a 1/4" or larger allen wrench in the chuck and close it tightly. Set the drill on a bench with the chuck off of the bench and strike the allen wrench with a mallet in a counterclockwise direction. Do this several times, then you'll be able to spin the chuck off by hand. Reverse the process to install the new chuck.
Apr 13, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
I cannot release drill bit from chuck
how does it happened?be sure to loosen you chuck becos you may probably turn it backward or turning to be thight? take note that loosen the chuck shall be counterclockwise when the drill bit towards or fronting you.
Nov 25, 2009 | Craftsman 1/2" Pro Hammer Drill
Need to change a keyless chuck
open jaws for large size bit.look in bottom and there will be a screw slot or phillips head screw or possibly an allen head screw.remove this,by possibly turning clockwise. and then chuck up a large allen wrench. try removing the chuck by tapping wrench with hammer. this may be threaded on counterclockwise.have to try both ways.
Aug 28, 2009 | Craftsman 19.2v 3/8"drill/driver W/ Work...
Drills Logo
114 people viewed this question
Top Craftsman Drills Experts
Tim Venetis
Gary Nitowski
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
