Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
My 4750 makes grinding noises when receiving faxes.
  • 120 Answers
SOURCE: problem w/my brother 4750 fax
make sure you put the drum and toner in correctly.Take it out and re install. Lawrence. Gears are making the noise.
Posted on Feb 25, 2008
  • 47 Answers
SOURCE: Brother Fax 4750 System error 76
try resetting the machine by pushing the features button, and then *2864 in quick succesion, if done correctly you will enter test mode, then enter 91, and then after that clears enter 99 to exit test mode. make a copy to see if it works, and if it doesn't it is time to replace the fixing assy.
Posted on May 12, 2008
leroyal
  • 2120 Answers
SOURCE: brother 4750 fuser replacement
The entire front, sides, and rear cover is all one piece. Take the screws out and lift straight up.
Posted on Oct 26, 2008
SOURCE: Loud grinding noise when paper is feeding through machine
Mine was indeed a gear problem. Took off the top cover and poked around. Found two areas that may have caused the grinding.
1. The lower roller shaft had slid to the left out of it's groove. By removing the handset cradle (3 release tabs are accessed underneath the toner hatch.) I could loosen the "gear box" (a black contraption with all the gears inside) and then snug the bottom roller into proper position.
2. I removed the "gear box" to look around. Don't know if I dislodged one of the gears while doing so, but noticed one was dislodged ;-)
This required opening up the gear box by removing 2 screws and lifting off the motor. Then i could get at a gear that had come loose from a claw sort of piece. Note: the teeth of the loose gear needed to be on the motor side when sliding it back into the claw thingy. It seems to use a metal clip for friction control and perhaps proper spacing.
I noticed "some" wearing of gears, but doubt this is an issue. This machine has been used VERY hard for years and now, just by re-aligning things, it works once again.
My googling barely found any mention of troubleshooting this machine, so I shudder to think what finding parts would be like.
Posted on Jan 21, 2009
greg_margo
  • 1959 Answers
SOURCE: white space in middle of faxes sent or received
Printing irregularites on sent faxes are due to spots or a dirty scanner.
Spaces on received faxes are due to a dirty drum, corona wire, or a failing or improperly installed toner cartridge. A new cartridge should be gently shaken back and forth sideways prior to installation.
Posted on Jun 23, 2009
Will not receive faxes. Line rings when phone was
make sure the mode switch is set to "fax"... not "tel", or "fax/tel". I think the mode indicator is on the top of the fax machine and it's a light that should be on next to "fax"
Oct 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Problem receiving fax
MAKE SURE YOUR MODE LIGHT IS ON IN THE FAX ONLY MODE
Aug 25, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
White space in middle of faxes sent or received
Jun 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
People receiving fax are getting black pages, all locations I send fax to.
If you make a copy on the fax machine, is it all black too? Yes? Most likely the scanner bulb (under the auto feeder) is blown out
Jun 12, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother 4750e fax machine
1- check the small stip of glass and see if it has toner,
check the maintenance section of the manual (it's free, just register)
http://www.retrevo.com/support/Brother-4750-Fax-Machines-manual/id/19095ci557/t/2/
Aug 04, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Problem w/my brother 4750 fax
Sep 21, 2007 | Office Equipment & Supplies
Able to send fax cannot receive fax
make sure phone line is pluged into line on fax,make sure fax is set auto.there should be a button on fax panel that say's receive mode.
Sep 07, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Gears grinding with Brother Intellifax 4100
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
Mar 22, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
35 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
