Question about HP Compaq FS7600 17" CRT Monitor
My monitors menu keeps popping up and changing the monitors settings it seems as if its going haywire
    Genius:
  • 1,970 Answers
Mcdevito75 here, You can try to disconnect the monitor from the computer for about 5 minutes and then reconnect, then press auto on the monitor seee what happens. I didn:t see anything related to your problem in Start, then control panel then visiual display that can cause your problem.
Posted on Jul 14, 2010
Brightness menu keeps popping up
This problem is usually caused due to a faulty microswitch in the brightness button. To rectify this, you'll have to change this switch.
Get your monitor serviced by a qualified service personnel.
Hope this solves your problem. For more help or clarifications, please reply. Thanks.
Aug 09, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
On screen audio display
hi
it seems that your system setting need a change and for this you must go to the CONTROL PANEL and from there you can change the setting----http://techbuddies-robin.blogspot.com/2009/06/get-free-technical-support.html
Jun 17, 2009 | HP w17e Monitor
Monitor Resolutions Menu Pop ups
Please disable this notification from settings menu of monitor. you should find it under settings or notification menu which can be accessed via switches on monitor.
Jun 14, 2009 | E-Machines eMachines Desktop PC
Main menu inviting to take a tour on how to adjust the monitor keeps popping up uninvited.
Your screen settings are not optimized for that monitor, most Gateways (to h*&%) come with a drivers disks for the monitors put that in and run setup for the monitor.
May 02, 2009 | Computers & Internet
RCA HDTV MENU AND VOLUME CONTROL POPS ON AND OFF SCREEN.
My TV was doing the same thing. Someone told me to disconnect the front menu buttons and this worked for me. The board goes haywire. You have to take off the front black panel on the bottom first then the grey front panel where the controls are. Once you do this you will see where there is a plug from tv to the panel where the control buttons are. Just disconnect. You will only be able to use your remote for TV. Its a cheap and easy fix. Just lots of screws to get the panels off and on. Good luck!
Apr 09, 2009 | RCA HD52W58 52" TV
Changing font size for larger monitor.
You can adjust your settings to something more to your liking by right clicking on your desktop in an empty area - then choose "properties" from the menu that pops up.
In the new window go to the tab that says "settings" and adjust the screen resolution to something a little larger. If you change your desktop settings in this manner then a window will pop up immediately after the adjustment asking you if you want to keep the new settings or revert back to the old one. If you don't select something within like 15-30 seconds it will change back. It does that just in case you change the settings so bad you can't see anything.
Another place to adjust the size of your fonts is to go to the "appearance" tab of the same menu and look for "font size" and there you can make your fonts bigger and ridiculously big, in case you still need to after changing the resolution.
I hope you find this information helpful, have a blessed day!
Dec 12, 2008 | Dell E173FP 17" LCD Monitor
Menu Screen
so sorry, not a solution but the same thing is happening to me. gateway emachine model LE1799
Aug 17, 2008 | Gateway FPD1975 19" LCD Monitor
Resolution notice keeps popping up every thirty seconds or so. very annoying. this happens only when using cd rom game diablo. wants me to change to 1280x1024, which my computer is set at now. otherwise...
When you load the splash screen of Diablo enter into settings. Make sure you have the game set to the screen resolution you want.
For the system. Open display properties. Click Settings, click Advanced, click Monitor. (Most games require 60 hertz) to run correctly. Change your monitor to 60 hertz. Than click the Adapter tab. Click list all modes. Move the slide bar to your normal screen res with 60 hertz. Click ok at every screen as you back out od display properties. That should stop your game from popping up.
Feb 26, 2008 | Niko 1920R Monitor
Dropped lcd monitor
Very often the problem is that when an LCD monitor is dropped, the ribbon cable and power cables which have very little slack become partially unconnected from the ports they plug into. Unplug the monitor, remove the back casing, and have a look to make sure the ribbon and power cables are seated properly. If in doubt, reseat them by hand.
Good luck...
Nov 14, 2007 | Computers & Internet
Menu randomly pops up while pushing no buttons....
It sounds like an issue with the power button board and I would certainly make use of the warranty option.
May 31, 2007 | Acer AL1916B 19" LCD Monitor
HP Compaq FS7600 17" CRT Monitor Logo
204 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
