Question about Cell Phones
My lg spyder jumps to a million different places when i hit the menu button. I cannot do anything until it stops jumping around and even then when i try to hit something else it starts jumping again. Can anyone helP?
How much to repair timing chain?
The internal damage is always the main worry with a broken timing chain, bent or broken valves, damaged valve stems and seats, I have even seen broken rings and split pistons and snapped camshafts, if the chain has stretched and the timing has jumped a couple of teeth you may be lucky, but you shouldnt turn the engine over even by hand until you find out the root of the problem, any damage may be increased tenfold. Unfortunately the timing cover will have to be released to find out before you do anything.
Jul 29, 2014 | 2001 Nissan Altima
2001 spyder gs auto tach issue
Check that the sensor that feeds info the tack is good.
Oct 14, 2013 | Mitsubishi Eclipse Cars & Trucks
My LG TV is menu jumping by itself it keeps switching between 3 different screens. What is causing this? Thanks
Issue with Sticky Button Due To Humidity and dust acumulation betwen contact Solution Take Off You Pad Selector and Clean-it
To do,,,So You must take Off our Back Cover and Rich inside your Front Panel and Take Off the Board then take off the Rubber Pad and clean it.. with a Q-tip warm Water dont use anything beside water like acetone or Alcool you will damage it..
Sep 22, 2010 | LG 47LD450 47 in. TV
How do you reset the LG DRT389?
to reset hit eject on the machine and the blue text button on the remote for 5 secs
Jun 24, 2010 | LG Cell Phones
I tried to play links crossbow training and the cross hairs kept jumping around all over the place. i couldent hit anything. what do i do to fix this?
You have to go in your Wii settings menu and then select the sensitivity menu, there you can adjust the sensitivity of the Wiimote as you please.
Mar 31, 2010 | Nintendo Wii Console
I have an Acer laptop. While typing the cursor suddenly jumps up a couple of lines, or suddenly may highlight a phrase, causing instant erasure of the previously typed material. Why does cursor continually...
your palm might be hitting the touchpad causing your mouse cursor to move and jump around... try to type with only your fingers hitting the keys and the back of your hand raised and not hitting any part of your laptop... hope this helps....
Nov 10, 2009 | Acer Aspire 5315 Notebook
Can't jump to the end on level 5
Hmm, perhaps you are not holding down the jump button to jump higher?
Also if you run (press and hold the Y button) and jump you can gain more distance though its much harder this way when running over small platforms. (I enjoy myself personally)
Another tip for higher jumps is to use Mario's triple jump.
You jump once then hit jump again right when you hit the ground and then do a third one for a full summersault jump up in the air.
This is better for later parts of the game and isn't really all that needed to beat the game, but its very fun.
Another tip is the purple/pink bouncy mushrooms all around stage 1-5. You can jump higher off them if you hit the jump button right when you land on one.
Though I'd suggest holding the run/fire button (Y by default)
to move a little faster when bouncing all around. It can be a little harder but can help when you need to really move as you loose a little speed when bouncing on those mushrooms.
I hope that helps you out some.
Remember to keep trying, practice makes perfect, and shouldn't be too hard to master.
Good luck and have fun.
Apr 27, 2009 | Nintendo New Super Mario Bros. for DS
New Super Mario Bros:Stuck on world 6
wow, I don't know how you guys got this far in the game if you can't wall jump... all you have to do is get on the red blocks and "wall jump" to the other side. how do you wall jump...? well you hit jump as you hit the wall. If you can slide down a wall, you can "wall jump" all you do is basically hit the jump button and the point the arrow pad (left or right) to which ever side the wall is at. ex if the wall is on your left (which is the case on this level) you jump close to the wall and hit left on the arrow pad and jump. MArio, then. will jump to the other side off the spot you hit the controls off. you could even jump straight up slide down the wall and just hit jump. Try practicing wall jumping, it'll make your life a lot simpler and the game much more fun :D good luck. you could twitter me if you have any questions, but twitter is kind of short with letters.
good luck to you all.
http://twitter.com/ilikeapples
Jan 27, 2009 | Nintendo New Super Mario Bros. for DS
Pointer Nib
its no good take it back they dont sell these parts
Feb 03, 2008 | Wacom Intuos2 A6
Cell Phones Logo
52 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
