Question about Sewing Machines
I have a longarm sewing machine and since I changed my needle my thread always breaks on top...why???
  • 132 Answers
Youneed to reset the tension
Posted on Nov 12, 2009
Why does top thread keep breaking?
Sounds like your tensions, both upper and lower are out of whack. Easily fixed if so...google a vidyfor your make/model machine on adjusting both upper and lower tensions.
Jun 18, 2017 | Sewing Machines
I have a Janome 1600P and the top thread keeos breaking
There are several common reasons for upper thread breakage.
Check that the needle/thread/fabric are compatible.
All About Needles
Remove the upper thread from the machine, install a brand new needle, ALWAYS RAISE the presser foot, and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point.
NMSU Checklist of Common Machine Troubles
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
Oct 29, 2016 | Janome Sewing Machines
Top thread keeps breaking
Upper thread breaking is usually a sign of incorrect threading or tension too tight, although there are other possible problems:
Industrial Garment Printers Sewing Machines
When threading the upper thread, be sure to ALWAYS RAISE the presser foot so the thread will seat properly in the tension disks. Avoid old thread or bargain bin thread. If the thread is fraying and breaking at or near the needle eye, then try a different type of needle with a larger thread groove that will protect the thread from fraying on rough fabric. Also, check that the thread is not hanging up on something, ie the slit on the side of the spool where the thread tail is stored.
Jul 02, 2016 | Brother XL-2600I
Kenmore sewing machine jams and breaks the needle
always make sure the needle is inserted correctly and all the way
up into the needle holder
try a different bobbin
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin case is inserted correctly in to the machine
if it's a front or side loading bobbin case
make sure the top thread has not come off the top thread take up
lever
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Dec 01, 2012 | Kenmore Sewing Machines
Juki DDL 227 top needle keeps breaking
Needle breaks
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Oct 08, 2012 | Juki Sewing Machines
Top thread on my Brother Limited Edition 350 Sewing machine keeps breaking. Having used the automatic cutter, the thread pulls up and out of the needle when I want to start sewing again. Also the machine...
rethread the machine
try a top thread tension of 3 or 4
change the needle
always keep a thread tail of 3-5 inches on top & bobbin thread & keep the thread pulled back behind needle before starting to sew
always keep the bobbin area clean of lint & loose thread
& check under the needle plate for lint also
you might consider having the machine serviced, since you said it sounds like a tractor
some needle & thread are not compatable-try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 04, 2010 | Brother Sewing Machines
I can start working withmy baby lock, the needle brokes verytime i runthe machine , and i can not sew
If this machine has a needle position adjustment and it is on the center position -
and you are sewing a zig-zag stitch and using a presser foot with a narrow opening this could break the needle
and the needle plate is a single hole, this will break the needle.
and you are sewing a straight stitch with a new needle and it breaks, the machine needs to go in for servicing.
Feb 13, 2010 | Baby Lock Sewing Machines
The top thread keep breaking. should the tension
Thread breakage is usually due to the needle in backwards, upper tension too tight or old/weak thread.
When replacing the needle, make sure that the flat side is to the right (3 o'clock position) and is pushed all of the way up before tightening.
What brand and weight of thread are you using and are you sewing with the foot or free motion sewing?
Jun 17, 2009 | Juki TL-98Q
Cannot machine quilt without the thread breaking and/or shredding. I've change needle, thread type and size and tension on my fabric.
If the thread is shredding and breaking, there is an incompatibility of your needle, thread, and fabric. Could be old, bargain bin, or poor quality thread--does the thread have little "hairs" of thread lint sticking out of it--that's probably not good quality. Look for fresh, good quality thread. Try a brand new needle--a sharp if you are sewing woven fabric. Make sure the thread is not too big for the needle eye. Sometimes, a top-stitch needle or embroidery needle will work well on FMQ. (A top-stitch needle has a longer scarf which helps protect the thread during the multiple times the needle penetrates the fabric before the thread forms a stitch. Shredding means the thread is getting worn out before it forms a stitch. A piece of thread penetrates the fabric 10-20 times before it forms a stitch.) Could also be a snag somewhere that is damaging the thread.
Sewing Needle Troubleshooting Guide
SCHMETZ Household Needle Chart
Most FMQ instructions say the upper and bobbin tension should be the same, however, I find my machine works a bit better when the bobbin thread is just a little tighter than the upper thread. Then the bobbin thread does not "pop" up on the top of my fabric quite as much. It's probably something you will just need to experiment with in getting used to your machine.
P.S.--when threading your machine, make sure the Presser Foot is ALWAYS RAISED so the top thread will seat properly in the tension disk. Failure to do this will cause thread barfs (usually referred to as thread nests or bird nests) under your fabric. Also, before beginning your FMQ, ALWAYS PULL the bobbin thread to the top of the fabric, then hold both thread tails gently in your left hand while you slowly take the first couple of stitches.
How and Why to Bring up the Bobbin Thread
Mar 01, 2017 | Brother Sewing Machines
Thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Dec 16, 2008 | Simplicity American Denim SA1100...
Sewing Machines Logo
55 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
