Question about RCA P52812BL 52" Rear Projection Television
Displays three images in different colors. Could it be alignment, burnt bulb, minor adjustment on something ?
Alignment problem
Posted on Nov 12, 2009
Hi there - I've got a Phillips mdl # 60PP9753/17 and recently the picture has dulled and has a red tint . I'd consider doing minor repairs (less than $200.00 usd) if replacement parts can be aquired for...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2011 | Philips 60PP9753 60" Rear Projection...
Just replaced burnt out bulb in Infocus 4805 projector. Great picture with new bulb but only black and white. Is this a bulb issue or something else in the projector?
This is most likely the color wheel. When the bulb blows, it can damage the color wheel. The color wheel is a wheel composed of thin layers of colored glass that spins in front of the projected image. It is possible to repair it with super glue, but the best way is to try to find a new one to buy.
Dec 29, 2010 | InFocus ScreenPlay 4805 Multimedia...
I just need to adjust the resolution on this TV. NO ONE at RCA could seem to help me. Thank you.
hi,
did u mean to adjust the picture setting then go for the following
1 press menu on the remote
2. using down arrow select picture quality and press ok. available options in picture quality and its use is listed below. you can use it according to your preference.
Basic Picture Control- Displays the five slider controls for adjusting
the way the picture looks.
Contrast Adjusts the difference between the light and dark areas
of the picture.
Color Adjusts- the richness of the color
Tint Adjusts the balance between the red and green levels
Black Level Adjusts the brightness of the picture
Sharpness Adjusts the crispness of edges in the picture.
When exiting this menu, the Save Personal Picture Preset choice list will
appear. You can choose either Yes or No. If you save the settings as a
Personal Picture Preset, the TV will store the settings so you can reselect
them easily if someone changes the settings.
Picture Presets Displays- a choice list that lets you select one of three
preset picture settings: Bright Lighting, Normal Lighting, Soft Lighting
or Personal Picture Preset. Choose the setting that is best for your
viewing environment.
Auto Color Displays- a choice list that lets you turn on the feature that
automatically corrects the color of the picture. (This is especially useful
for tracking realistic flesh tone colors as you switch from channel to
channel.) Choose On or Off, depending on your preference.
Color Warmth Displays- a choice list that lets you set one of three
automatic color adjustments: Cool for a more blue palette of picture
colors; Normal; and Warm for a more red palette of picture colors. The
warm setting corresponds to the National Television Standards
Committee (NTSC) standard of 6500?K.
Video Noise Reduction Displays- a choice list that lets you turn on the
feature that automatically reduces noise from the picture. Audiovariable
enables the TV to automatically adjust noise reduction level;
off turns off noise reduction feature; on-fixed sets a fixed level of noise
reduction.
Dec 21, 2010 | RCA G36705 36" TV
Covergence problems or alingment , its has three colors without alingment please help me!!!
manual convergence should fix the problem if it does not the set most likely either has a bulb burnt out or a bulbs power / focus needs to be adjusted by taking off the panel and finding a 6 screw control panel
should look like that 3 screws in a row on top of another three screws each of thees control the power and focus of each color this is a somewhat delicate process and is a huge pain on larger tvs that you cannot completely see the picture or color while you are directly under in front of it so I had my gf come in the room and sit across to let me know which color was doing what if you dont have someone you will need to check after each adjustment
now the diagnostic
as i said each screw controls a colors power and focus the focus is used if you see an outline of a color around pictures if everyone looks like a dead jedi with a blue aura around them the blue focus needs to be adjusted and so on for each color if you skies or blue screens seem feint your blue power probably needs to be turned up and so on for each color
if through the course of this you can see the bulbs and notice one is out your probably looking at dealing with the color issue until the time you can purchase a new tv as the cost of the bulb and the technician needed to install it as they are wired to a circuit board and requires technical knowledge and tools
hope this helped
Robb
Apr 29, 2010 | Zenith R57W46 57" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
My Sony KDF-60Xs955 rear projection has a blueish green tint on the screen. it is really noticable during darker scenes and is distoring the colors in other pictures. A tech came out and tried to adjust...
this is normally either a color calibration (easy) or a light adjustment(if burnt out very bad)
for the color calibration you want to go into your menu setting and look for the color calibration menu it should give you two cross hairs to align causing a different color yellow red is orange green is blue yellow and so on after ensuring all theese setting are correct your best bet is going to be taking it to or having a television repair man come to you to check the bulbs hopefully if just an adjustment needs to be made cost should be minimal unfortunately if a light is burnt out its usually cheaper to buy a new tv
hope this helps
please leave feedback
thanks
Robb
Apr 22, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Samsung model number PCL5415R The blue bulb is weak. where can i get one and can I replace it it is a 52inch projection HDTV ready
You may also have a problem with the convergence. There are three color cans that project the image on the screen. A red one, green one and a blue one. The blue one is the one that you should try and adjust. Have you tried to realign the convergence yet? You should be able to go into the menu setting and locate this option is is typically done using the remote. What you will see is some cross marks starting in the center and move to the four coners. When you adjust it you will want to align all three (red, green and blue) crosses where neither color is more prevalent. If you are unable to get the blue can to align with the others, there is a problem with the convergence board. These boards or ICs can be replaced, if you have a repairman fix it your looking at around $250 - $400. If you would like to fix it yourself you can get the parts from...
http://nfm.partsearch.com/Model/Samsung/Samsung/PCL5415R.aspx
NOTE: "Most of the text above was gathered from another online source"
Aug 28, 2008 | Televison & Video
52 in rca projection 2006 cutting of the top of heads of people
There are manual settings on most projection tv's to adjust the size and to bring the picture down so it is centered on the screen better. Try adjusting the three colors mentioned below first. All projection tv's are pretty similar. If you need to adjust the picture manually, which you should not have to, there are manual knobs behind the front of the tv or at the rear. They should be marked for thier function.
Here is how to adjust the convergence one color at a time.You should be able to get to the convergence screen with your remote. You need to go into the setup screen and read what is on the menu there. It should say how to adjust when you get there.
Convergence- The Auto convergence feature automatically adjusts the TV’s tubes
(this may take several minutes, after which you can make fine adjustments to the
convergence settings); Red convergence displays the Red convergence screen,
allowing you to use the arrow buttons to align the red and green images; Blue
convergence displays the Blue convergence screen, allowing you to use the arrow
buttons to align the blue and green images.
Also this is in the manual for a generic projection tv.
Call 1-877-RCA-HDTV and have your unit’s date of purchase and model/serial number ready.
• A representative will troubleshoot your problem over the phone.
• If the representative determines that you should receive service, they will provide you with the name(s) of the
Authorized Service Center in your area.
• Contact the Service Center and arrange for home or pick up, repair, and return service, provided that your unit is
located within the geographic territory covered by an Authorized Service Center. If not, you must take your unit to the
Service Center location at your own expense, or pay for the cost the Service Center may charge to transport your unit to
and from your home.
• Proof of purchase in the form of a bill of sale or receipted invoice which is evidence that the product is within the
warranty period must be presented to obtain warranty service. For rental fi rms, proof of fi rst rental is also required
Here is a link to rca tv manuals if you don't have one.
You can download them in pdf.
If this is not a help, please give the specific model number.
Apr 21, 2008 | Televison & Video
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Picture cut off
No adjustment needed on these LCD projection. Your problem is in your setup menu. Your default is now is set ZOOM. That is why the bottom of the picture is cutting off. Go to Menu, setup and screen size or something close to that.
Best regards
Circuitcity
Jul 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
99 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
