Question about Car Audio & Video
Jeep grnd chero limtd 95 wires have attached plug that belongs to another type of radio i bought a OEM jeep radio for my year however it has 2 connectors on back of unit what now??
  • 2,559 Answers
Go to a salvage yard and get the two original plugs, one is grey and the other is black. Make sure to get the wires as long as possible. Then remove the wires from the plug in the car and splice to the same wire on the harness you bought at the salvage yard. You will also need to attach the ground wire to the bolt on the back of the radio. The ground is either a large braided wire or a single black wire. Make sure you have the right radio, if the Infinity name plate is on the speaker locations, then you need an infinity factory radio.
Posted on Dec 21, 2009
How step by step do I install a Panasonic stereo into my 1995 jeep cheerokie
why let a pro install it.
DIY
a new radio or old.? what model is the install manual missing in the new radio box.?????????
a non stock radio install.
depends on what radio, for sure. huh?
did said new radio come with a DIN box>?
there are 2 issues, mechanical, and electrical.
all autostores and even walfart sells an an adapter plug that lets
the new rad, wire connect each, and not damage to car harness.
that be first
then use google, yes, lots of videos of other figuring out the mechanics .
so i will type for you, now, using google ,is that ok.???
your not the first.
https://www.google.com/webhp?gws_rd=ssl#q=how+to+install+a+new+radio+in+my+95+jeep+cherokee
there are vast clues there,
Sep 30, 2014 | 1995 Jeep Cherokee
Reactivate radio jeep after lock for wrong code
You will need to contact the dealer on this problem.
Oct 28, 2012 | 2004 Jeep Grand Cherokee
I need a color coding of the wiring for the harness i was given for my kenwood dpx308u. i just need to know which colors belong to which wires
Ok, you should have a wiring harness that plugs into the radio. That comes with the radio. You will need a wiring harness that is specific to your vehicle, this will plug into the vehicle harness. The wiring harness will have the correct colors to attach your radio to it. All aftermarket radios have standardized wiring. I recommend not attempting to hardwire your radio due to the risk of frying your entire electrical system. I hope this helps.
Aug 19, 2011 | Car Audio & Video
I have a tti cb radio but the wires have come away from the mic but i dont know what colours go to what number can you help
one should be a ground. look at the board were the wire is.. and its obvious that its a ground pin 1. then should have 3 remaining. one will be tx.. touch the others to ground to see which one makes it tx.. theres your pin 3 tx.. on a galaxy pin 4 is not used. thats rx pin4 cobra radios would have a increase in rx audio when this is connected to grnd. the last would be audio. once you find grnd and tx. reconnect mic and put to pin 2 audio. the last 2 wires that gives it audio..
Nov 05, 2010 | Galaxy Radios Microsystems DX98VHP CB...
Canabalized wiring job on OEM radio
You should buy a replacement harness to restore the OEM wiring, so that you can then properly plug it into an aftermarket harness that has been mated to your Kenwood radio's harness. The next buyer will appreciate that the factory radio has been replaced when you're done with the car, and you get the added benefit of not being forced to leave your Kenwood head unit in it, since it can be easily unplugged once you're at that point.
Jun 22, 2017 | OEM Systems Car Audio & Video
Engine dies
Sounds like its time for a tune up, new plug, wires, cap, rotor, fuel/air filter. Also have the timing checked. Could also be a fuel pump starting to go as well.
Aug 07, 2009 | 1995 Jeep Grand Cherokee
Hard top wiring
I'm guessing that the top and Jeep are 2 different years.
You need to go to a salvage or junk yard to find the same plug and cut the other one off and splice in the one you buy from the junk yard.
Oct 13, 2008 | 2003 Jeep Wrangler
Factory Amp
I assume you used the correct Metra plug (70-1878) to install the radio. Ensure the blue and white wire on the Metra is attached to the blue and white wire (or solid blue) on the Sony. This will provide + turn on voltage to the factory amp.
The other good possibility is that the Metra harness has a black and a black and white set of wires both must be ground.
Lastly the Metra harness does not provide these( -) grounds, they are supplied by the braided strap . or the single wire that was attached to the back of the Jeep radio.
Jul 22, 2008 | Infinity 475A Car Audio Amplifier
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
