Termostat call for heat and it will not come on untill I hit the front of the unit
  • 43,501 Answers
You have aloose wire somewhere in the unit. That could be very difficult to find. Take the cover off and carefully start to wiggle wires till you find it.
Posted on Nov 12, 2009
Lg dryer dle7177 cutting off during cycle
I had a tumble dryer that stopped working and after much investigation it turned out to be an internal thermostatic switch and lots of fluff around the internal filters. ( Mine had 2 of them 1 would cut the heat and kick back in when the temperature dropped and the other one would completely cut all power rendering the drier non usable until cicuit breaker thermostat was replaced. The reason they cut out is to prevent overheating and possible fire. When the thermostat gets to certain temperature it breaks the circuit. Apparently you shouldn't stop the drier until it has completely cooled down as there will be too much heat which could cause a fire, which is why most drier cycles have 10 minutes of cool/ non heated air at the end. So in conclusion I would take all the filters out and give them a good clean and try to avoid opening the door while there is still a lot of heat in the drier. I'm not sure if this will help but its a starting point.
Feb 03, 2013 | Dryers
I have a honeywel t8002c termostat w heat already connected. The ac unit needs to b reconnected. Two wires for the ac to b connected. Was connected before but moved the termostat thus winter and didnt...
You need to connect to the Y terminal and the C terminal for A/C unit. The best was is to connect thermostat to furnace and then connect the two wires to A/C off furnace circuit board at Y and C terminal.
May 13, 2011 | Honeywell Heating & Cooling
Have warm air on heat but no heat. changed termostat,and flushed the radiator . what can it be
worth trying the topmost heater hose for an airlock,just undo the clip and fill with antifreeze.then with the radcap off, run the engine until hot.to check water flow.....
Dec 07, 2010 | 2002 Ford Taurus
Is over heating, has new ratiator, termostat, hoses, sensor in the termostat and still over heating
Does the electric fan work...if not the thermatic sensor is faulty, quite common.
Oct 15, 2010 | 1999 Honda Civic
I have a heat pump and it freeze up
If you are referring to the outside unit freezing up, the issue is in the defrost cycle. The defrost cycle works something like this: The unit reverses the flow of freon causing the inside coil to blow cold air into the conditioned space and the outside coil is now working like an a/c unit, it gets warm to melt the frost/ice. The inside unit electric heat strips come on so you do not notice the cold air being blown in. The fan on the outside unit stops running to allow the coil to get good and warm.
Now the unit should go into the defrost cycle every 90 minutes or so. It should not terminate the cycle untill the coil is clear of frost. There is an "Klixon" type termostat that measures the temperature of the outside coil. This is most likely the problem. It is prematurely terminating the defrost cycle. I'd start there first.
Hope this helps, Let me know if I can be of any further help.
Dec 29, 2009 | Intertherm P3RC-030K Air Conditioner
I have a thermastic mixer bar shower which runs off my combo boiler, normally this is fine but the thermastat keeps sticking and not letting any hot water through although the tap itself gets so hot you...
REMOVE THE CASING FROM THE BOILER AND FOLLOW THE HOT PIPE UNTILL YOU SEE A DISC SHAPE OBJECT , TAKE NOTE OF CODE PART AND GO TO A PLUMMERS SUPPLIERS STORE AND ASK FOR SAME PART , WHEN YOU GET THE NEW TERMOSTAT GET AN AJUSTABLE SPANNER AND REMOVE FITTINGS FROM EACH END OF TERMOSTAT BUT FIRST MAKE SURE THE HEAT IS TURNED OFF , GOOD LUCK.
Nov 05, 2009 | Home
The furnace is blowing warm air even if the thermostat low.
The only thing that tells the unit to come on and off is the thermostat so I would definatly say it is it. When you turn the system back on, does the a/c run normally? If it does, then it's the problem with the heating side of the tstat. Also, does the fan come on when you put it to on and then turn of when you switch it back to auto? If it does, then the system is working fine, its the t-stat. Let me know if you have any more problems.
Mar 23, 2009 | Intertherm P3RA-048K Air Conditioner
No heat
try changing your termostat
Jan 19, 2009 | 1998 Ford Taurus
Ruud central air conditioning and heat system
there is a fan relay in the unit. it is stuck and needs to be replaced
Oct 21, 2008 | Ruud Heating & Cooling
My appartment does not have cenral AC/heat, it has a GE cooling/heater unit in each room. You can set up low heat or high heat but it continues runing on until you manually stop it when is to hot. Is there...
the unit runs all the time because of the fan (ventilation motor)-but it is not working on cooling or heating all the time - The ventilation motor pushes the air from the room through the machine and when the termostat is reading that you set it up for cooler air or warm air it will turn on the air conditioning part or the heating part of the machine-it is very good system actually
Oct 04, 2008 | Heating & Cooling
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
