Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Vacuum condensor light flashing and the refrigerator won't get colder than 51 degrees.
  • 585 Answers
The light is indication a problem with the condenser coils being covered with dust/dirt and cannot dissipate the heat energy absorbed by the system in the evaporator coils (freezer). Or the condenser fan is not running. Clean the condensor and/or check the fan.
Posted on Nov 12, 2009
  • Bruce Volkers
    Bruce Volkers Nov 15, 2009
    If the maintenance issue of dirt on the condenser coils is not the answer, then you may need to have the unit serviced.
No ice
The service light flashing usually indicates that there is a rise in the temperature of the machine, most likely caused by either the condensor coils being dirty or the condensor fan motor not running, either of which cause the compresor to run hotter than normal. The ice maker itself won't operate if the temperature rises above 10 degrees F, which is still well below freezing but its a fail safe to prevent flooding in the machine. I would take off the removeable grate and check the coils and clean them before I call anyone.
May 08, 2012 | Sub-Zero 642
My sub-zero 642 will not get colder in the freezer than about 9 degrees and the fridge won't get colder than about 45 degrees. I turned off the breaker and vacuumed the coils, but still no change. ...
The Sub Zero 642 uses independent refrigeration meaning the freezer and refrigerator each has their own system. Best to have an "Authorized Factory Service Company" check it out.
Jun 08, 2011 | Refrigerators
Temperature is at 51 degrees. Door has been open and shut all day but the temperature shouldn't be this high and it doesn't seem to be going down.
check the evaporator fan and condensor fan. condensor coil clean. compressor warm.how much frost build up . if frost build block air way, i am sure the problem is heatelement or defrost thermostat. good luck.if the compressor not work . need to check the relay
Jan 10, 2011 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 690 vacuum condensor light flashing, clean vac. condensor, light still flash after 2 days.
I assume from your post you have vacuumed the condensor at the top of the unit? Did you do this regularly over the life of the unit? You have shut the unit off for at least 5 minutes (allowing it to reset) and then turned it back on and the vac condensor light still flashes? I had this same thing happen - unfortunately for me I have had to replace the condensor twice in the 12 years I have owned the unit. Luckily first time was covered by warrantly (parts and labor). Second time was in the 11th year and the parts were covered, and the labor was covered 50% after I complained......It ended up being a leak in the sealed system (condensor). If it keeps happening you may want to call for service - could be that it just needs freon, but it could be the condensor)
Sep 08, 2010 | Sub-Zero 690 Side by Side Refrigerator
I recently had to throw away some questionable food that had partially thawed in the freezer cabinet of my kenmoore, model# 253.67882508 fridge with freezer on top. i keep this fridge in my garage and in...
probably,there is a garage kit available that willallow it to work at colder temps,listed in owners manule under accessories the thermostat senses refrig compartment temps.soif garage temp is below 40 or so the thermostat just doen't turn the unit on enough or not at all
Jan 17, 2010 | Refrigerators
My vaccume condensor light is flashing and my refrigerator is 55 degrees. I vaccumed the coils on the side of the fan What could be the problem ?
You may need to unplug the fridge for a few hours and let it reset itself. Also make sure coils are clean and there is plenty of air flow to the condensor..
Jul 09, 2009 | Sub-Zero 690 Side by Side Refrigerator
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 690
Call the factory at 800-222-7820.They will give you a list of the authorized servicers in your area. It sounds like the evaporator and the parts will be covered by the year 6 through 12 parts only warranty. If you are in Westchester County $625 sounds right. The vacuum condensor flashes when the compressor has too long of a run time and will reaapear a day or so after it has been reset. I assume the tech made sure the condensor fan was running and the condensr is actually clean.
Nov 30, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-zero 601 fridge won't get below 42 degrees
You both sound like you need a qualified factory repairman out there. If there is a blockk of ice on the back wall you have a low charge in the refrigerant system. It is most likely the evaporator or cooling element as you call it which has a five year parts and labor warranty, then parts only for years 6-12. Here is the link to the factory locator site. http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 or call 800-222-7820.
Nov 24, 2008 | Sub-Zero 601R
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
278 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
