Question about Frigidaire FSC23F7D Side by Side Refrigerator
Three way solenoid valve
We have a 2005 frigidiaire side by side frig. In Aug we noticed it was leaking, I took a look and saw that the solenoid valve was leaking. Water was on the floor.I purchased another part and now it is leaking again. The leak is in a different place on the solenoid valve. The part is not on full warranty. Do you have any advice on this problem?
Thanking you in advance!
  • 90 Answers
All you can do is replace the part. I am not sure on frigidaire parts, they use to have 1 year warranty on replacement, some companies have gone to 90 days.
Posted on Jan 08, 2008
Why is there water dripping from the bottom of the water/ice dispenser
The solenoid valve that controls the water dispenser is leaking internally. It will be a double valve (one for ice, the other for chilled water) located at the bottom of the frame in the back of the unit. To find it, just trace where the plastic tubes originate from.
Easy to replace.
These leaks are sometimes caused by particles getting trapped on the valve seat. This can be prevented by use of an inline water filter on the copper supply line.
Oct 20, 2014 | GE Profile PSW26P Stainless Steel Side by...
Leaks water
I don't know what model you have but if you have the combo unit than check to make sure the drain line for the frig part is not stopped up. if just the ice maker than check the water supply line leaking at solenoid valve inlet side. Tighten or replace fitting, if not there than check water line leaking at solenoid valve outlet side, If so than replace water line and fitting.
Oct 07, 2013 | U-Line Icemaker
Freezer and frig not as cold
It sounds like the heater that automatically defrosts the unit may have failed. Before calling service I recommend checking the following: all door seals, make sure they are closed and sealing properly, also the condenser coil either on the back or bottom of the machine should be vacuumed out regularly to get rid of dust buildup. If that's all good it may be the defrost heater and if you're handy you can look up on youtube how to replace it or call a professional.
Nov 28, 2017 | Roper Refrigerators
I have a Kenmore elite bottom freezer refrigerator. The unit was made by Amana according to the first 3 digits of the model number (596.76253702). The unit leaks about a qt of water. It started as once a...
I have a Kenmore elite bottom freezer refrigerator. The unit was made by Amana according to the first 3 digits of the model number (596.76253702). The unit leaks about a qt of water. It started as once a month and is now leaking every 2-3 days. I brought the frig in Aug 1009. Any thoughts? Ishqbaaz Full Episode Watch Online
May I simply say what a relief to find somebody that truly understands what they are discussing on the web. You actually know how to bring an issue to light and make it important. A lot more people should check this out and understand this side of your story. It's surprising you're not more popular given that you definitely possess the gift.Ishqbaaz Porus Drama
Feb 06, 2018 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water leaks from ice maker and freezes next to fan.
Probably is the solenoid or dual valve ,thats leaking and the only way to fix this is changging the solenoid.
Aug 27, 2009 | Whirlpool ED5FHEXMQ Side by Side...
2005 grand caravan error code P0400 egr valve chk/ performance
I have the 2005 Town & Country TOURING . If my memeory serves me correct, I believe this was the same code that I got on time. The van didn't seem to drive any different but this is what I did and I haven't seen the light come on since.
first I went to the dealer ( you can get these parts from a auto parts house also) and bought the 3 gaskets total.for the the EGR solenoid vavle assembly where it bolts on to the engine ( that gasket was made from metal), NOTICE AN INDENTATION IN THE METAL GASKET WHEN YOU TAKE IT OFF,YOU WILL WANT TO PLACE THE NEW GASKET IN THE SAME DIRECTION. one gasket that goes between the EGR valve solenoid and the small stand pipe. and another gasket that goes between the stand pipe and where it connects to the plastic valve intake area cover on top of the engine.
I took the EGR solenoid off from the engine and took it apart (reall carefully) and cleaned it thouroughly with a spray carbuerator cleaner. I took mine "completely apart" after I did this I dont recommend to do this again, you can damage the coil inside if you're not cafefully. I suggest just cleaning the valve and plunger ports, etc....
When it was completely dry I reinstalled the EGR solenoid on the van making sure I used ALL NEW GASKETS. The van hasn't produced the engine light since. I hope this helps.
Jun 11, 2009 | 2005 Dodge Grand Caravan
Water dispenser will not work when lever is pressed. we had an intermittent problem with it before it stopped working altogather.I was going to look at it but was afraid to pop off the trim on the outside...
This could be a bad water valve in the frig. This frig has a double water valves. One for the ice maker and one for the water dispenser. It should be in the lower back. Where the water line goes in. You can check this valve easily. Find the double water valve on the frig. Turn off water supply to frig first. Swap the plastic water lines going from the water valve into the frig. Turn water supply on. Then see if the water dispenser works. Sometimes you will have to operate the water dispenser for a little while to get the air out of the line. If it works now then the problem is in the water valve solenoid and needs to be replaced.
Nov 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Water in the frig and possible overheating
clean the coils and check to see if the condensor fan is working. Call your local dealer and ask them to order you new o-rings for the filter mount to fix the leak from the filter.
Jul 19, 2008 | Frigidaire FRS26R4A Side by Side...
WATER DESPENSER IN DOOR WILL NOT WORK
Solenoid should be near bottom rear of frig. check wiring connections on solenoid. Turn off water valve to frig, disconnect hose at solenoid and see if you can blow air thru the tube.
May 28, 2008 | Whirlpool ED2FHEXN Side by Side...
My ice maker is leaking and would not stop making ice.
MAKE SURE THAT THE WATER SUPPLY SOLENOID VALVE IS NOT STUCK OPEN BY DEBRE. AS FOR THE HAIR DRIER ??? THERE IS A LIMIT T-STAT THAT PREVENTS THE ICE-CUBE MAKER HEATER WIRES OR PLATE FROM OVER HEATING. MAKE SURE TO LET THE IT COOL-OFF TO RE-SET THE SAFTY SWITCH. YOU CAN CHECK TO SEE IF SOLENOID IS ENERGIZED BY PLACING A METAL BUTTER KNIFE CLOSE TO THE TOP OF THE SOLENOID... YOU SHOULD FEEL THE MAGNETIC PULL FROM THE SOLENOID. ALWAYS MAKE SURE THAT YOU HAVE ADEQUATE WATER GOING INTO AND OUT OF THE WATER SOLENOID VALVE ... USUALLY LOCATED BEHIND THE FRIG WHERE THE ICE MAKER IS LOCATED.
Apr 21, 2007 | Whirlpool GD5SHAX Side by Side...
Frigidaire FSC23F7D Side by Side Refrigerator Logo
180 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
