Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Cabrio squeaks in agitate - Whirlpool Cabrio WTW6600SBT Top Load Washer
    Genius:
  • 1,689 Answers
First, check your rubber o-rings, your counterweight and the belt drive.
if those are loose, you will hear squeaks and vibration.
Posted on Nov 12, 2009
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
Squeaking Cabrio dryer when running
The squeaking is due to the drum glides or as some people call them slides, being worn or broken. Easy fix and very inexpensive part
Mar 25, 2014 | Whirlpool WGD8800YW Cabrio Platinum High...
How to take a whirlpool clothes washer agitator out of the washer to be replace
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool cabrio washer - a piece of clothing is stuck under the agitator - how do I get it out
    Take off the cap on the agitator and remove the bolt. The agitator should pull off and you can rescue your clothing item.
    Manual and parts list click here.
    Hope this helps.
    Zeppelinx12
    Feb 24, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Squeak as drum rotates not the agitator in the middle? Bearing or motor?
    Here is a tip that I wrote about dryers and noises...
    It will help you determine what is happening there...
    Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
    heatman101
    Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
    Sep 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Need to remove agitator to remove lodged medallion
    Remove the agitator top cap, and unscrew the mounting bolt part way. Pull up on the agitator by both sides of the rim, then finish removing the bolt after the device is loose. (Keeps you from smacking your face when the agitator comes loose.) Hope this helps.
    Oct 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    GE Washer Model WJRR4170E4WW squeaks while agitating
    There are four suspension rods that the tub hangs on. When the washer is agitating the tub will rock back and forth and the rods will move back and froth as well. To fix this noise, lift up in each rod and put some lubricant in the cup that the rods fit into at the top of the washer.
    Note that it is best if you use a lithium-based lubricant rather than silicone based lubricant.
    For more on do-it-yourself appliance repair help visit http://www.appliance-repair-it.com/index.html
    Sep 11, 2009 | GE WBSR3140DW Top Load Washer
    Squeaks really loud while agitating. Drains great, and works well other wise. Could the belt be going bad?
    Could either be the drivebelt slipping or, if an older machine could be the main bearing getting dry.
    May 20, 2009 | Washing Machines
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    677 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
