Question about Acer Aspire One AOA150-1784 Netbook
How to recharge Acer Aspire One netbook. I have used it with the AC adapter thinking that was how you recharged it but it didn't work.
  • 922 Answers
If the AC adapter light turns on the battery is dead. Replace it.
If the AC light does not turn on try another outletor the adapter is dead. Replace it.
If this helps please vote for my solution.
Posted on Nov 12, 2009
The battery in my acer aspire 5251 will not charge over 67%. What can I do?
two questions to ask first 1)is it Ni Cadium? or 2) Is it lithium Ion ?
alkaline and NiCadium batteries have discrepnacies when being recharged all the time they just last for ever. Lithium on the other hand sometimes has to shocked jumped when near 0 voltage to collect a recharge. the connections on a lot of baterries may be so smooth that contact is at fault as well . new batteries are not cheap but is something we all do from time to time.
Aug 21, 2013 | Acer Aspire 5241 5251 5332 5334 5338 5516...
LAPTOP RUNS ONLY ON BATTERY
If the unit powers through an ac wall transformer its probably the cause, they burn out
all the time.
Replace it with the same rating that is shown on the unit (input/outpu
hope this helps
Jul 24, 2012 | Acer Aspire One Netbook 8.9" Notebook
My Acer aspire one just stopped working for no reason. I plugged it in to charge it but none of the lights come on, and nothing happens when I hit the power button...
Assuming that the AC/DC Power Adapter is not faulty no LED lighting up at all and no image at all on the screen might mean a power management fault on the motherboard.
First try removing the battery underneath the netbook. Then connect the netbook to the power cable without the battery installed. If the netbook powers up without a battery installed then the battery is probably faulty most likely with completely depleted and unchargeable power cells. if so you will almost certainly need a new battery and some little known guidance on the correct management of a netbook or notebook battery (see below). Dead batteries tend to generate a more than normal amount of heat.
If the AC/DC adapter is not faulty and using the netbook without a battery does not help then check the DC power jack where the power cable connects to the netbook to see if the jack is loose or detached from its original solder point on the motherboard.
If the none of the above are the cause of the problem then the motherboard probably has a power track or capacitor fault which might be repairable (as would a loose DC jack) but these types of fault even if successfully repaired can easily come back and the cost of repair might be high compared to the value of the netbook and not worth it since a brand new state of the art netbook with a full warranty would not be very expensive.
Many users take an incorrect approach to netbook/notebook/laptop battery management. These batteries are rechargeable and are only supposed to be connected to the power cable when their cells are low or depleted. Once the cells are fully charged the power cable should either be disconnected and the computer used on battery power alone or the battery should be removed and kept for when battery powered use of the computer is next needed.
Once a fully charged battery is removed the computer can be used directly connected to the electricity without the battery installed.
A disconnected battery needs to be reinstalled and recharged from time to time if it is stored for long periods of time, because the charge in its power cells very slowly dissipates even if is disconnected from the computer.
Nov 08, 2011 | Acer Aspire One Netbook 8.9" Notebook
My acer aspire ones screen is just staying black and wont reboot what do i do ?
I have the same problem! I received a response to my email telling me to disconnect adapter and battery, hold the power button 30 minutes, connect ac (make sure it's plugged), turn on, wait 1-7 minutes, then attach battery after windows boots. After several tries, it still hasn't worked. When I turn on the system, my power led stays green, but the hdd indicator is not lit. My battery can still recharge, but the screen is still black, and there is no sound.
Apr 16, 2010 | Acer Aspire One Netbook 8.9" Notebook
Power cord attachment into the back of computer seems worn, it wants to run off battery instead of recharging through power supply
Either Have A Failing AC Adapter, Or A Failing DC Jack
you can test the AC Adapter using a multimeter (available at any home improvement center for $6)..
The DC Jack Would Need To Physically Be Checked To See If It's Faulty... which would intail removal of all parts down to the motherboard and visually inspect the DC Jack (the port where the Charger Cord Plugs into)
Remove The Battery... Plug AC Adapter Into Laptop.. Attempt To Power On....
Nov 15, 2009 | Acer Aspire 5100 Notebook
Have an acer aspire 5002WLMi laptop bought second hand. no manual. old battery. If I bought a new battery, how long of a charge would I get. Is it ok to continually use my adapter/recharge cord when I use...
I use the adapter plugged in all day long, it will not do any damage to your battery. You can leave it plugged in a work as long as you want. Just make sure you get the lithium ion battery as that is the latest..in fact I would get it off of the Acer home page if possible. As for as how long a battery last, depends on the usage and how many times you recharge it. Lithium are good for over 1000 recharges so again depends on your usage. Its the recharge that wears it down. Hope this helps. Pls rate this solution.
Apr 28, 2009 | Computers & Internet
Acer Aspire One AOA150-1784 Netbook Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
