Question about Compaq Computers & Internet
1st problem is that the date and time keep messing up and now the computer is shutting itself down. Windows XP won't even load before it shuts off completely. Tried starting in safe mode but as soon as you try to go into anything it shuts down again. It's an older computer so I suspect it could be the battery on the mother board. Anything else to try before giving up on it?
  • 558 Answers
Yes it could however the battery should not prevent it from loading windows.The motherboard might be failing.
Good luck
Posted on Nov 12, 2009
Testimonial: "Thanks for that tip! Will get the motherboard checked out"
Unit shut's off when trying to load anything.
Hold old is the computer? Does it freeze up before it shuts down, if so then the caps on the motherboard are probably bad.
Mar 18, 2014 | Dell Dimension E510 PC Desktop
I have a msi a6000 laptop and it keeps shutting off itself and wont boot windows when windows stars booting it shuts off and i clean the fan so thats not it can someone tell me what it's hapening
try replacing the thermal grease on your cpu.
the BIOS have a protection that restart or shut down the computer/laptop when the cpu get to hot.
You can also check if the power suply is working in parameters
Dec 06, 2012 | MSI A6000-226US Core 2 Duo T6600 2.2GHz...
My computer keeps switching itself off and won't swtich back on again? What can be the problem?
Hello
By know you should of fixed the problem .
1. keep the inside cabinet clean.
2.If the unit keeps shutting down by itself after a certain time and it is not dirty inside the cabinet .Also all the intact screens are clean . Check your Personlization settings By right clicking on your screen . then right click Screensaver and then power settings . Then check to make sure all the settings are turned off unless you want the computer to shut down after a certain amount of time
Oct 30, 2012 | LG Computers & Internet
Water won't shut off on my Estate washer
check clear tube that is inside machine.1st take off shell of machine look for clear tube about 1/4 inch diameter.it sometimes comes off,it pushes over nipple to load size water fill knob.if it came off the water will keep on flowing and over flow.if that's the problem just put a dab of silicon on nipple and push tube back on.
Feb 20, 2012 | Estate TAWS800JQ Top Load Washer
When I boot my computer the monitor flashes the Windows XP logo then goes dark and the computer shuts down and then restarts itself and start the process all over again and again
Try starting it in safe mode, F8 during the boot process, this loads a windows shell, once active, run a system restore.
(Programmes - Accessories - System tools - System restore)
Choose a date prior to your problems.
Sep 12, 2010 | Kogi L7CH Monitor
UNMOUNTABLE______BOOT_____VOLUME ***Stop: 0 X
It could be a problem with the harddrive and memories ,if you enter the DELL bios setup page when the computer starts up does it have an option to test the hard drive if so test it.
Also if you have two memory sticks then try with only one and vice versa.
Try booting with another boot CD like the ultimate boot CD it has some hard drive testing tools too.
Good Luck
Nov 04, 2009 | Compaq Presario 2195US Notebook
Whenever my computer starts up and shows the Windows XP logo it shuts down and shows me while starting up that windows wasn't started up rite. Than after a week it COMPLETELY messes up. I've tried a FULL...
It is one of 2 things....
1. It is overheating. Overheating will cause the computer to randomly shut down. You can usually decifer if it is overheating by trying to put the computer back on after it shuts down. For example , start it up...let it shut down...then try to put it back on again...if it doesn't come on at all, or if it shuts down even quicker then the previous time, you are most likely looking at an overheating issue. To remedy that you want to open up the case, clean out all of the dust with a compressed air can (be very careful not to tip the can, it will spray liquid), and verify that all of the system fans are running.
2. Could be any type of hardware failure - from the power supply to the hard drive. If you have completly ruled out the overheating issue, I would just take it to a shop to get diagnosed.
Feb 25, 2009 | Computers & Internet
This computer 5310s ser#0035081700 has all of asuden when sets idle it shuts down on its own also put it on stand byit shuts down and when turned back on it comes up on windows log just like it had been on...
get to the control panel and get to the power options and configure it to yor specifications concerning, the power button, standby and shutdown options, thnx
Jul 29, 2008 | Gateway Computers & Internet
Can not save to bios
windows and the bios needs to know that the operating system can be shut down through windows, so when you go into the F2 or Del on boot up, go into advanced cmos setings and look for ACPI and make sure it is enabled. This sets the motherboard to support shutdown. Save and exit settings and reboot. Now go to control panel>performance and maintanance>power options and set the correct instruction for shutdown to shut the pc down. Remember evertime you remove the cmos battery or reset with jumpers you have to reset date and time and anything else you have changed to suit your set up
May 06, 2007 | Abit KN8 SLi Motherboard
Computers & Internet Logo
60 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
