Question about Kenmore Dryers
Model 76822694 Gas Will Not come on - Kenmore Dryers
  • trholliday57 Nov 12, 2009
    Gas will not come on in Gas Clothes Dryer, Kenmore, Model 76822694. I wish to jumper out the ignitor to test unit. Where is the ignitor located?
    Tom
  • 10,865 Answers
Hello, I can assist you. If your dryer doesn't heat, check these: Igniter Gas valve coils Thermal fuse Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Nov 12, 2009
  • Joe Hogan Nov 12, 2009
    THANKS FOR CHOOSING FIXYA!
    President:
  • 1,865 Answers
The most common failure with this symptom is ignitor failure. You do have to check the circuit with a multimeter to find the exact failing component, otherwise you'll end up blindly replacing parts til you get the right one, and that is just not cost-effective
I have a genesis model 320 natural gas grill what
change all the gas orffices and the reg , try Calgary bbq center for a kit they are on line .
Sep 07, 2011 | Weber Genesis E-320
Conversion kit to switch to natural gas on modelFG50069
The model you have (G50069) has been discontinued by Fiesta and replaced by model # FGF50069-584LP (they are very similar). Neither your model or the current model have a conversion kit available. You either purchase/purchased it as a Propane model or a Natural Gas model. Even the Owners Manual states that it can not and should not be converted from one fuel type to another. (See link below)
http://www.blueembergrills.com/manuals/FGF/SP1811-37_FGF50069_ENG-V6.pdf
Hope this helped answer your question.
Apr 25, 2011 | Fiesta Blue Ember Gas Grill
Is this a gas or electric dryer (part of a stacked set) Frigidaire
Model No. GLGH1642FS has a gas dryer.
Model No. GLEH1642FS has an electric dryer.
Model No. GLGT1031FS has a gas dryer
Model No. GLET1031FS has an electric dryer.
Model No. FGX831FS has a gas dryer.
Model No. FEX831FS has an electric dryer.
Get a stack model that suits your needs and compatible with your home's utilities setup.
Gas models are more common with most people because most electric models
require 240v outlets that many houses don't have.
Feb 20, 2011 | Dryers
I need 4 replacement knobs and I cannot find them!! Please help
Hi and welcome to FixYa, I am Kelly. I am assuming that your model number is MGC5430 as listed in your post. If not use this link to find them by entering your model number:
(just note that there are 2 to 5 digits missing from your model number)
http://www.appliancepartspros.com
See this page:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MGC5430
It brings up the following models:
arrow_link.gif MGC5430ADB SURFACE UNIT- GAS arrow_link.gif MGC5430ADC SURFACE UNIT- GAS arrow_link.gif MGC5430ADQ SURFACE UNIT- GAS arrow_link.gif MGC5430ADW SURFACE UNIT- GAS arrow_link.gif MGC5430BDB SURFACE UNIT- GAS arrow_link.gif MGC5430BDB20 36`` GAS COOKTOP arrow_link.gif MGC5430BDQ SURFACE UNIT- GAS arrow_link.gif MGC5430BDS SURFACE UNIT- GAS arrow_link.gif MGC5430BDS20 36`` GAS COOKTOP arrow_link.gif MGC5430BDW SURFACE UNIT- GAS arrow_link.gif MGC5430BDW21 30`` GAS COOKTOP
I used the MAYTAG MGC5430BDB20 as a reference and the BLACK knob is item 6 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5515609&diagram_id=28426062#d28426062 Detailed view is here: http://www.appliancepartspros.com/part_details.aspx?part_id=4100044 If you need more assistance please respond with a complete model number and I will use other sources to loate your knobs. Thanks for choosing FixYa, Kelly
Jan 05, 2011 | Maytag MGC5430 Gas Cooktop
Hi, I want to replace my Honeywell gas valve ( Model VR8440P2088), but I don't know with model is compatible to replace it. Can I replace it with different model ? Please help. Thanks
It is very important that you replace your gas appliance with the same model gas valve. Gas valves function diferently from appliance to appliance. Some open slow, some are two stage, ect. Your safety is very important!!!! To save a few dollars on a gas valve not for your application is dangerous.
Mar 15, 2010 | Honeywell Heating & Cooling
Converting Weber from LP to Natural Gas
On the weber model you need to purchase the natural gas model. It will cost you alot more to buy all parts needed to convert. Weber doesnt want you to convert do to safety reasons. This is why they will only tell you you can't convert. Buy the right grill and save yourself a headache.
Jan 19, 2010 | Weber S-420 (NG)
Model 75775 slight gas smell problem and no one
take a bottle of 409 cleaning spray and spray all gas connections the leak will bubble
Nov 07, 2009 | Kenmore 75620 / 75621 / 75622 / 75624 Gas...
Kenmore gas dryer not heating all the time model#76822694 took off back cover does show a flame when i looked slight gas smell when trying to use it
make sure the fan is working and that the filter is clean and the discharge pipe is not clogged
Jun 24, 2009 | Dryers
I CAN NOT FIND THE NON- SELF CLEAN MODELS FOR MY HOTPOINT GAS RAN
heres the cpnversion kit number for the model that you listed, if you have a different model number then rgb790ssehsa, then please list it , and ill find you the correct part number
Nov 25, 2008 | Hotpoint RGB790SEHSA Gas Kitchen Range
Dryers Logo
35 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
