Question about Wega Mininova EPU Espresso Machine
I have a old dual faema commercial espresso machine. My problem is water is not properly coming out to make an espresso, it comes out more from the side. Is this because it's dirty? How should I clean this?
    President:
  • 1,618 Answers
Replace the group gaskets and clean the shower screens.
Posted on Nov 12, 2009
Where do I find a Faema Smart A2 replacement touch pad? The left push panel is not working and the guy fixing it wants me to order a new one but I can't find a matching part anywhere on the internet.
You're looking for part number 3301135601. I've come across a few Smarts with Due front panels - so measure your keypad: if it's 68x58mm you need a Due version instead.
Feb 09, 2015 | Faema Smart A2 Automatic Espresso Machine...
Waterpump makes a lot of noise
It is possible that the water coming into the pump from the mains is obstructed. If you have a water filter, that might need to be replaced. Some of the pumps have a stone filter on them, you will see a huge nut on the inlet side of the pump, that might need to be cleaned. Also check all water lines make sure you have no kinks. Pay attention to the gauge on the machine when the noise is happening if the water dispensing pressure lever should be at about between 3-6 bar when not being used and about 9 when brewing espresso.
Feb 19, 2014 | Faema Smart A2 Automatic Espresso Machine...
I have a faema x1 grandaitalia machine , the water coming out of the boiler is only getting to 33 deg can you send me or a diagram of hot water system thanks or tell me what to fix problem
Ope you mean from hot water spout if so several problems exsist as this machine has a cold mix system to bring the roughly 120c water from boiler down to roughly 94c to use for americano. check spout and descale hot water nozzle or see if any black/brown particals in defuser(fine mesh in spout)as boiler pressure is roughly 1.3/1.4bar and mains water is roughly 2/4bar thus cold water will win if black brown particals in mesh poosible boiler contamination causing restriction to which once again cold water will win. question did any one take any pipes apart about 5 months ago????? as there are restrictors within the system.
Aug 15, 2012 | Faema Coffee Makers & Espresso Machines
Commercial Faema Espresso Machine with 2 heads, model #E97/A-2
It can be many things. If I understand machine start working (pouring water) itself, otherwise not working.
Probably your touch pads is bad, must be replaced. If I now more about problem mighty I can help more.
Mar 14, 2009 | Faema FA60081
No water coming out of the group head?
Your problem is either the brew solenoid or the brew switch.
Feb 09, 2009 | La Marzocco FB-80 Series 3 Groups Coffee...
Espresso machine problems
You may want to have a close look at the seats. There may have been irregular wear on one or more causing the leak. Try and make sure each one is back in its original location.
http://www.faema.com/eng/contatti_rete.asp
Found a manual for you (closest match) It's only for a Faema Family. Well, what the heck, it's free!
http://picasaweb.google.com/Grendelpics/FaemaFamily
Hope you come right, cheers.
Mar 02, 2008 | Coffee Makers & Espresso Machines
Wega Mininova EPU Espresso Machine Logo
166 people viewed this question
Top Wega Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Wega Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
