Question about Parrot MINIKIT Bluetooth Hands-Free Kit Wireless Headset
Hello,this is mike i just got given one of your headsets and am having trouble making it work. Never used bluetooth b4.Plse help me.
    President:
  • 2,976 Answers
We don't have headsets, in fact, we don't have anything other than repair advice. You should contact the manufacturer.
Posted on Nov 12, 2009
Music player through my bluetooth
Hi Mike Cronk,
I see that you have a Bluetooth Headset and that you are tryingto connect it to your BB.
You mentioned it will not play or you cannot hear Audio From it from your BB?
Did the Bluetooth Headset sync to your BB? you need to make sure that the headset is sync properly on your BB and that the BB is dectecting your Bluetooth Headset. make sure that the BB is also set to be detected by any device for the Bluetooth to detect your BB as well for proper syncing of both devices.
try your Bluetooth headset on another devices as well see if it will sync to a different device just to see if the Bluetooth headset is working fine.
I hope this helps,
michaelvincentc
Dec 25, 2011 | Jabra BT2080 Bluetooth Headset
HBM 730 Bluetooth Headset Wireless Headset: Headset was given to me a while ago and I have a n...
To put your headset in paring mode, first turn it off. Then, press and hold the PWR/END button until the indicator led is solid lit (some 5 seconds). Now, make your phone's bluetooth software to search for devices. Select 'LG HBM-730' from the list. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
Hope it works for you
Hope it works for you.
Cheers! Carlos
May 05, 2010 | LG HBM 730 Bluetooth Headset Wireless...
How to pair with iphone
Hello
1.From the main home screen of the iphone open "SETTINGS".
2.From the setting menu go to "GENERAL".
3.From General go to "BLUETOOTH".
4.In the Bluetooth menu you will see an on/off switch. Make sure you turn the switch to "ON".
5.From here you want to go to your bluetooth headset. Hold the on button for about 5-10 seconds until the light starts blinking. Once light is blinking go back to iphone.
6.In the Bluetooth menu (same as step 4) your iphone should have discovered your bluetooth headset. However if it is not paired yet. Open the headset menu.
7.In the headset menu you are required to enter the appropriate PIN number (which should be given inside your bluetooth headset instruction manual).
8.After you have entered the correct PIN number press connect.
9.From here your Bluetooth Headset should be connected and ready to use.
NOTE:Fully charge your bluetooth headset before syncing it to your iphone
Goodluck
Apr 16, 2010 | Samsung WEP410 Bluetooth Headset Wireless...
I cannot get my Orb bluetooth headset to work. and yes before you say it im not a dohnut i did follow the instructions as they are put out but when scanning for bluetooth devices on my ps3 it scans...
i figured it out!!! you have to do the Scanning firstly then when you are asked to hold down the P button for 5 seconds and it turns RED immediately open the microphone whilst it is still RED and it will work (hopefully) then it will be registered with your ps3! (hopefully)
Good luck :)
Nov 18, 2009 | Video Game Consoles & Games
My bletooth h350 handsfree device needs a pass code for my phone to accecpt
All the motorola bluetooths that i have had that needed a passcode used "0000". See if that that works. Good luck!
May 28, 2009 | Motorola Mobility H350 Wireless Headset
I cannot get my Plantronics voyager520 to pair with my tmobile g1
I just did this... first make sure your old phone is off... second go to bluetooth and make sure that discovery is on and then put your plantronics in learn mode or what ever its called by turning it on and holding it until it flashes red and blue... Your phone will request a pin code.. the pin code for plantronics is 0000 then it should connect. Hope this helps
May 24, 2009 | Plantronics Hama Voyager 520 Bluetooth...
Motorola H700 will not connect or stay connected
hello, dont be dispaired just keep trying to connect by pulling your mike in and out, some times they need to be worn in, had same problem with my first h-700 and after about 20 0r 30 times moving the mike in and out it took off, some of my seven h-700s paired automatically and some didnt, the secret to putting them in discover mode is with the mike closed press the call button till it turns solid purple and briskly pull the mike down and go thru the pairing process.these are my expieriances, may not be a solution but give er a whirl. good luck m,m.
Jan 21, 2009 | Motorola Mobility H700 Wireless Headset
Wont find headset
Fold the mike boom to rear, push center football shaped button down for about 3 sec until it stays lit (not blinking) unfold the mike boom make sure it stays steady lit (no blinking) scan for bluetooth Walla!
Jan 02, 2009 | Motorola Mobility HS810 Consumer Headset
Problems w/H700 bluetooth
Try taking a small needle and gently clearing out the mike hole near the end of the boom. Anything I am outside and sweating a lot mine will clog up and I have the same trouble until I clean it out and then it's fine. Do not insert the needle in very far, all you need is to clear the outside opening a bit.
Jun 20, 2008 | Motorola Mobility H700 Wireless Headset
Motorola Bluetooth® Headset H555
This will vary depending on the model of your phone. First off, you need to ensure that you are using a bluetooth enabled phone.
On your bluetooth headset, hold down the power button down until the power light stays lit. This may take 5 seconds or more. Now your bluetooth is in pairing mode.
You will need to enter the settings and tools menu. From within that menu, you need to find either "connections" or "bluetooth" and select. Make sure bluetooth is enabled. There will be an option to add a new device.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code. This pin code will be 0000.
Jan 14, 2008 | Motorola Mobility Bluetooth Hands Free...
Parrot MINIKIT Bluetooth Hands-Free Kit Wireless Headset Logo
Top Parrot Radio Communications Experts
Henry  Thomas
Henry Thomas
yobo007
yobo007
Are you a Parrot Radio Communication Expert? Answer questions, earn points and help others
