Question about Cell Phones
The volume doesn't work. I have to keep it on
My LG env2 is acting up and I really love this phone. The volume doesn't work. Ringtones can't be set, I have to keep it on vibrate missing most of my calls. It also keeps shutting off without warning even if fully charged. I've only had it less than 6 weeks.
How do I turn off silent mode on my Lg 365 as choice seems to be silent or vibrate and cannot find profiles under settings as stated in manual
The quickest way - on the left side of your phone there is a button with up and down arrows. Keep pressing the up arrow and this will raise the volume up, or keep pressing down and you can set it to vibrate or silent. Also, you can change it from the menu. Go to Menu > Settings > Audio & Ringtones > Ringtone and there are all of your options here. You can go to Volume and set the volume, Alert Type and set if you want it to vibrate/ring, etc. I hope this helps, if you still have questions feel free to ask :)
Apr 28, 2011 | LG Neon GT365 Cell Phone
LG EnV3 ringer volume is LOUD even when set to LOW
I have the same issue. I know this is a roundabout solution, but I love the phone in all other ways, so I handled it like this:
I make my own ringtones with audio editing software anyway, so I just made versions of my original ringtones that were "volume-cut" by 6dB or 12 dB. Then to get these .mp3 files installed as ringtones, first I save them to the "my_sounds" directory on the micro-SD card (either via USB cable and "USB Mass Storage" mode, or by taking the card out and plugging it into my PC with an SD card adapter,)
This puts them in as "sounds" but not yet ringtones. Then, on the phone itself, I send a multimedia message of each sound to myself (i.e. to this same phone, "from me to me") Once each message is received, you will get an option to "Save as Ringtone", and once you do that, the sounds become available as ringtones.
I just use ALL of my own "volume-cut" ringtones for the different ring sounds in my phone, and it makes it quieter. Note that if you then use any "standard" ringtones, they will seem particularly loud by comparison.
Oct 05, 2009 | LG enV3 VX9200 Cell Phone
Env2 vx9100 call volume soft
We have 3 ENV2's in our family. None of them have volume problem. The speaker phone is especially loud when used in indoor environment. It is so loud that I have to turn the volume way down when used with good quality ear set. You probably are right about the phone being defective.
Aug 23, 2009 | Verizon Communications enV2 Cellular Phone
Env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. Thefirst step is to contact your carrier to see if it is covered underwarranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3. You can get an external battery charger to charger the battery separatefrom phone. cost about 25 dollars. Check out the following link forones that are available on ebay. A extra battery is a good idea as well so you can have one charging at all times.
LG VX9100 ENV2 External Battery Chargers
Hope that helps
May 28, 2009 | Verizon Communications enV2 Cellular Phone
I have the lg keybo and i cant get my sounds to become ringtones this doesn't work with the LG Keybo, only the enV2, Keybo can't save sounds as ringtones. I have been looking for a solution for a while,...
Hiya, my wife has the same phone.. everything works and the way to get your mp3's as a ringtone is what I found easier to do like my LG dare.. which is to edit, compress the mp3 file and send it via text attachment from your vzpix account to your phone, from there you can save the attachment and modify it's use on your phone as a ringtone. Aloha!
May 26, 2009 | LG enV VX9900 Cellular Phone
Volume
Ringtones that come with LG Vu just arent loud enough. Try downloading FREE ringtones from -myxertones.com-you can find many that ring REALLY loud!
Feb 04, 2009 | LG Vu CU920 Cellular Phone
Having alarm clock sound even in vibrate mode
It is not possible to sound alarm in vibrate mode, but by going into master volume and setting it to sound alarm only, the alarm sounds in silent mode.
Jan 10, 2009 | LG Cell Phones
Sounds to ringtones
Try this:
Under Get It Now, choose Music & Tones; then choose My Sounds.
Highlight the sound you want to use as a ringtone and send it to yourself. When you get the text message, choose the option "save as ringtone". Now you can use it as a ringtone.
Sep 10, 2008 | LG enV VX9900 Cellular Phone
Lg ke 970 volume
my lg is so low my friends are laughing a me i would why a i cannot get a code to tune it up the person who made the phone should have codes for it plz post it because i love lg phone like the ke970 plz post the codes
Mar 01, 2008 | LG Shine KE970 Cellular Phone
Cell Phones Logo
60 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
