Question about Samsung Office Equipment & Supplies
I recently was givin a samsung model sp2504c 250gb hard drive and cannot install it on my compaq computer, i was curious if it is possible to get somekind of adapter to match the ribbon in my compaq or if there is only a specific model of computer this hard drive can be installed into
  • kidderchris Nov 12, 2009
    thank you very much i appreciate you answering that question
    President:
  • 1,865 Answers
That hard drive is a SATA drive. New computers have the SATA connectors on the motherboard, however older computers do not. If you want to add that drive to your system, buy a SATA drive dock that connects via USB.
The following link is for reference only, it is not a recommendation for this particular docking station
http://www.google.com/products/catalog?hl=en&source=hp&q=sata+drive+dock&um=1&ie=UTF-8&cid=1714274043047601551&ei=qHL7St7lG9TolAfx58yKBQ&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CBwQ8wIwAg#ps-sellers
Posted on Nov 12, 2009
Compaq presario c300 does not detect samsung hm251hi
You may need the SATA drivers if XP is older. Get a newer version or download the drivers and press F6 during the setup when it asks if you require 3rd party array software (array controller).
Feb 01, 2013 | Samsung HM251HI 250GB 5400RPM 8MB 2.5"...
My Dell PC scan says that my Samsung SP2504C hard drive is about to fail and should be replaced. Is this something I can do?
Replacing the hard drive involves the following process:
  1. Turn off and unplug the computer
  2. Remove the two screws from the left panel (facing the front of the tower)
  3. Slide the left panel back and to the left to remove it
  4. Unplug both power and data from the hard drive
  5. Unscrew the hard drive (You may need also remove the right panel to get to additional screws)
  6. Slide hard drive out
  7. Slide in new hard drive.
  8. Screw in new hard drive in approximately the same fashion as previous hard drive was screwed in
  9. Plug in power and data
  10. Re-install panel
  11. Plug computer in and boot
However, if this is your main or only hard drive, you will need to install your Operating system and all of your software and files from scratch. It may be possible to preserve them, but that's often risky and requires a bit more work. If this is your main hard drive, you probably want to consult an expert on having the old drive contents moved to the new drive.
If you like my solution, please vote for me,
Apr 09, 2011 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
Provide information on\r\nlaptop manufacturer:_________________ laptop model number:________________ amount of ram:________________________ size of the hard drive:___________________
manufacture is compaq model number is under the laptop If you right click on my computer and go to properties you can see how much ram is in your computer. If you open my computer right click properties on the c: drive you can see drive size. normal size for the hp touch pad is around
  • 2GB memory
  • 250GB hard drive
best of luck
Mar 08, 2011 | Compaq (153515-001) Touch Pad
I have a compaq witha samsung hd M/NSP2504C, S/N S09QJ1ULB30333. What are the speed and buffer specifications and which hard drive would you recommend for a compatable replacement or slave.
Hello
Samsung SP2504C is a 250 GB hard disk drive using the new SATA-300 interface, which allows a maximum theoretical transfer rate of 300 MB/s. Its main specs also include an 8 MB buffer, 7,200 rpm rotation speed and support to NCQ (Native Command Queuing). In this review we checked the performance of Samsung SP2504C installed on a motherboard using a regular SATA-150 port and also on a motherboard using the new SATA-300 port.
This very same hard disk drive is also available with a 200 GB capacity, being called SP2004C. Both belong to SpinPoint P120 series from Samsung.
Good LUCK AND DO RATE THE SOLUTION IF HELPS
Dec 20, 2010 | Compaq Computers & Internet
2.5'' external fell down
Sorry, but if your hard disk fell down and now isn't regognized by the computer the most possible situation is that the disk is destroyed.
Stelios.
Feb 22, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Xp drivers compaq cq60 104tu
try installing with registerd versions of windows and you will be able to sort ot out,
Jan 11, 2009 | Compaq Presario Notebook
Upgrading Hard drive of Compaq Presario v3018TU
I am afraid you cannot use 250gb hard drive on the notebook. Check the following service manual for hard drive specifications and supported hard drives with part numbers:
http://h10032.www1.hp.com/ctg/Manual/c01035667.pdf
Nov 02, 2008 | Compaq 10.2 GB ATA-100 Hard Drive
Hard Drive
you will be able to connect this samsung hard drive which is a SERIAL ATA drive if you the SATA port on ***********-board(remove the jumper from the hard drive)...
after you are connected ,in your bios set the seagate as your primary booting device.....
after this is done you can continue the virus software
thankyou,.
regards
JC
Aug 13, 2008 | Computers & Internet
250GB harddisk only 130GB
try downloading any program that manages disks (partition magic for example ) and see if all the space appearsin that program, if so asign to that space a drive letter and format it .... (with the program that u will use )
Jan 16, 2008 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
21 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
