Question about LG VX8550 Cellular Phone
How to fix a bad charge port - LG VX8550 Cellular Phone
My phone will not take a charge or power up
Confirm that the charging port is working (it may have cable connection issue, and have to be place in a certain position to charge), If the port is fine, then figure if battery is bad.. If charging port is bad, its a relatively easy and cheap fix.
May 29, 2014 | HTC Vivid
Charging problam
Hello,the problem you are facing could arise due to two things
1.bad charger,you can fix these by getting a friends charger to test your phone so as to confirm if the charger is bad.
2.bad charging port.if the port is bad you will have to visit an authorized phone engineer to help you fix it properly.
Wish you good luck,
Take care.
Jun 15, 2011 | Nokia 1600 Cellular Phone
Battery will not charge
You need to post a lot more information for a solution to be given. Have you tried a different battery and the result is the same? What about another charger?
For this particular model and the problem you describe the most common solution would be to change the charging port. The part is cheap (flexqueen.com is my usual supplier) but the installation is not easy so you are likely to be better off buying the part and then taking the phone to a cell phone store with proper tools to fix the charging port.
HOWEVER, although the problems listed before are the most common by far (bad charging port, bad battery, bad charger) There is also a chance the problem is in the mainboard. Certain circuits within the mainboard can get damaged (water damage or phisical damage would be the most common way) and they would make the battery not charge. Because the charging port is cheap, I would still try to replace it but keep this in mind as it could be something else.
Nov 29, 2010 | LG Vu CU920 Cellular Phone
My nokia 5320 ran out of charge the other day i tried to charge it up but it would not accept charge.
Hi
First thing to do is to charge the phone with another charger, if the phone charge it means the charger is bad, if not it means the charging port is bad.
You can also try the phone with another battery and charge the battery to know if the battery is not the problem.
The charging port is easy to fix and very cheap to buy. Go to the phone accessories shop and tell them you need your NOKIA port. Get a screw driver, unscrew the screw, open the phone and replace the charging port with the one you just bought.
Thanks for contacting FixYa.
Aug 13, 2010 | Nokia 5320 XpressMusic Cellular Phone
Not charge
hello,
from the information that is gone ting from you
this means that your phone have develop charging port problem
what you need to do from here is that you need to unscrew your phone and then remove the bad charging port and fix up a new one that is in good condition, then if you can not do just this your self
then you will have to take your phone to a very good phone work shop around for fix up then you will be able to make use of your correctly and your phone will then charge from it port again
Apr 10, 2010 | Nokia 1100
Blackberry pearl 8130 won't charge
Sounds like your charging port has gone bad. Try CPR in New York City. They are faster than the manufacturer, and cheaper! They have a usual turnaround of 3-5 business days. And if you become a fan on their facebook page, mention it and you will get a 10% discount.
Here is the link to their facebook page, it has all the info you need.
http://www.facebook.com/pages/New-York-NY/Cell-Phone-Repair-NYC/312054784441
Hope it helps!
Apr 09, 2010 | RIM BlackBerry Pearl 8100
Nokia N73 not charging. There is no issue with battery as it is working in other cell phone. I have also tried different chargers. The problem seems to be with point where the pin is inserted.
hello,
this means that your phone have develop charging port problem, that is the charging port is bad
what you have to do is to replace it with another that is of good condition
you can do the fixing your self if you have the tools to unscrew phones get a new charging port from the store unscrew your phone remove the bad month pics and fix in the new one you but from the store
note if you can't do it your self take it to a very good phone work shop around you to do the fixing for you then you will be able to charge your phone from it own charging port again.
thank you and thanks for using fixya.
Mar 29, 2010 | Nokia N73 Cellular Phone
W995 port doesn't work
Since the port of your phone works as the charging port and headphone port, it means the charging i.c. is bad. Invariably, you have to change the charging i.c. of the phone by taking it to a technician since you cannot do it yourself.
Alternatively i will advice you to buy a universal/desktop charge for you battery and suspend the use of your headphone till you fix the port.
Jan 12, 2010 | Sony Ericsson Walkman® W995 Cell Phone
Dell Inspiron E1505 charging port is bad
happened to me.... tech guy from dell came over, and temp. fixed it ... laptop is then no use with battery, i still always have to use the plug
Oct 21, 2009 | Dell Inspiron E1505 Notebook
My lg vu will not charge
There are 2 possible problems you are having. You charger is going bad as evidenced by th cable going bad. Take it to a carriers store and try a different charger.
The other issue may be the charging port is going bad. Having to tape the charger may be an indication of that.
Try a different charger first but if that is not the problem check out the following link for ways to fix the charge port on your LG VU
LG VU Charge Port Repair
Jul 13, 2009 | LG Vu CU920 Cellular Phone
LG VX8550 Cellular Phone Logo
100 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
