Question about Maytag Neptune FAV6800AW Top Load Washer
We have a Maytag Atlantis washer. The cold water will not work. I had changed the washers in both hoses sometime back, and it worked for awhile, but has stopped again. Seems to simply be an unwillingness to open the valve for the cold water.
    President:
  • 1,865 Answers
The solenoid valve is failing, (common failure part) replacements are about $20. Replace the water solenoid valve
Posted on Nov 12, 2009
Maytag Atlantis Washer - no cold water
Check the solenoid valves. If it's connected to hard water, the minerals build up inside and won't let the internal plunger move.
Mar 16, 2017 | Maytag Atlantis MAV9501E Top Load Washer
Maytag atlantis mav76000aww the cold water is coming out hot, i've checked the hoses and lowered my water heater temp, what else could cause this?
o know you say youve checkes your hoses,but try swaping them around see if that makes a difference!if it doz,nt get back to me,
Sep 23, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer was working fine! Moved washer to new house, and now it will run but only with hot water. put washer on Auto controll, and cold cold or warm cold setting, and it wont even turn on.
Have you tried checking your cold water supply faucet? Are you sure there is cold water running out of that faucet before you hooked up the hose? Is it possible there is a shut off on the supply valve that isn't turned on? Therefore it will not run on cold water setting? This actually happened to me once. We went away for a week and turned the water off for the hot and cold supplys. Came back to do laundry and only turned the hot one on and not the cold. Good luck!
Aug 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water fill, discharge and noise problems
to reset the water level you have to turn the knob all the way over as far as it will go and then come back to large load.
Feb 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Cold water will not run into washer, but drips when washer is off
Take the hose off the back of the washer and remove the screen and you will find it to full of sediment. Clean it out and try again.
Jan 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis top load washer that wont' let cold water cycle through. Water is always hot or luke warm. checked screens on hoses. Any suggestions?
ok just a touch of help for ,,onthejob...i need you to start at a cycle and put unit on cold cold,,ok...now i want you to put your hand on back of unit where the inlet vavle and the hose meet at unit...do you feel a vibebration,,or here it humming,,now if hot water comes though,,all you have to do is reverse the hoses there on wrong,,im here onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
162 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
