Question about PreSonus INSPIRE 1394 External Sound System
Has been working great. but now when i plug it in to my laptop, it turns blue, then immediately red. and when i pull up the control panel, it says 'no device'
I've recently had the same problem with mine. What did you do different to cause this?
Posted on May 12, 2010
Hi, i have a ge side by side and the freezer is working great but the frige side is not getting cold , could you tell me what might be wrong. i just put a new motherboard in it.
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Jun 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
Refrigerator/freezer not cold as they should be
is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off .
May 07, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Inconsistant turn on
This set has a history of power supply problems. The power supplies are NLA from the manufacturer - but if you make an inquiry to www.parts-link.com they will be able to supply you with a power supply.
Apr 24, 2009 | Polaroid FLM-3201 Television
Proton pltv 32 no signal
I have the same problem. It seems the tv is switching from composite1 to composite 2 source.
Jul 09, 2008 | Protron PLTV-32 Television
Cannot connect wireless keyboard and mouse
I am assuming that this is an INFRA-RED device, with
plug and play capability.
1) Make sure that the infra-red port is turned ON on your PC,
in the BIOS and in Windows (using control panel)
2) Make sure that the infrared driver is working:
My Computer ==> Right Click ==> Properties ==>
Hardware ==> Device manager ==> ....
Find the Infra-red device and check its status.
Some laptops have a mechanical switch witch controls all
wireless ports. If you shut-off the Wi-Fi, the blue-tooth and
the infra-red will also be disabled.
3) Check for tiny reset buttons on the keyboard, mouse and
the receiver. Press them repeatedly.
4) If the device is communicating, and infra-red ICON
should appear on you taskbar (RHS).
Right click the icon and make sure you enable IR
communications AND plug and play.
5) Make sure you have installed any drivers that came with
the keyboard, if any.
6) Again, make sure that infra-red communications are enabled
in the control panel.
5) Failing that, it is possible that the keyboard is defective,
or the infra-red port on your laptop is NFG, it would not
be the first time.
6) You may want to take your keyboard to a computer
shop, and ask the staff the try it with a different PC.
Alternately, try a different keyboard with the laptop.
Martin
May 07, 2008 | Computers & Internet
I'm seeing red, literally, after buying this set for $300.
through the front of the tv behind the speaker grill and behind the panel in front if the CRTs there will be a square object with 6 knobs you can turn. grab a flashlight and twist the RED SCREEN control to the left until the red is less prodominate. make sure you still have some red because then the picture will look purple. that adjsutment is called G2 or SCREEN control adjustment. try that be careful though because tooo far one way and the picture might start to blank.
make sure that you check all connections coming from your video sources also.
Jan 20, 2008 | Sony KP-53XBR45 53" Rear Projection...
Faint red lines in a curved arch like pattern
Guys I did this myself real easy. Just don't turn the corresponding screw too far. Only need to adjust it until the lines go away. Do it on a darker screen so the lines are more visible. I did the red 2 years ago and the green 6months before that. The blue lines are coming on my screen now and I've fixed it in 10 minutes. The TV is amazing.
Apr 10, 2007 | Sony KP-51WS500 51" Rear Projection...
PreSonus INSPIRE 1394 External Sound System Logo
435 people viewed this question
Top PreSonus Computers & Internet Experts
Matthew Spark
Matthew Spark
Marcin
richie46
Are you a PreSonus Computer and Internet Expert? Answer questions, earn points and help others
