Question about Whirlpool WED5100SQ Front-Load Electric Dryer
Dryer runs about 20 minutes on its cycle and cuts out. It will not turn back on without a 20 or so minute rest. I have checked the lint filter as well as the exhaust and they are both clear. Anyone have any other solutions.
  • l_leonardi_j Nov 12, 2009
    By checking I mean taking the lint exhaust off and wiping the entire thing down inside and out along with the fan blower to make sure there are no obstructions. The hose I made to that it was less then a foot and double checked to make sure nothing was in it as well and the vent to the outside and again no obstructions. When the dryer gets to the point that it is near the 20 minutes or so there is a faint smell almost like burning plastic.
    President:
  • 2,976 Answers
Check the exhaust path, where the lint trap goes. If there is lint in the path, it will retain heat that will shut the unit off. You can't just look and see, you will have to dismantle the path from dryer to final exhaust port to make sure it is all clear.
Posted on Nov 12, 2009
Dryer seems to be overheating within 3 minutes of turning on. No lint in trap or outside in the trap. What else could I check??
may want to check inside the housing, u may have had a lint build up somehow? Ur cycling thermostat or thermal cut off may be going haywire on you and u should check them with a multi-meter. for continuity. is it overheating and shutting off? If so u may have bad motor windings which will heat up rapidly then shut down the machine? but they usually will atleast let u run it about 20 minutes b4 shutting down
Dec 27, 2014 | Dryers
I have an Amana NED7200TW dryer that is approx. 2 1/2 years old and am having issues. The first sign of a problem was it would not come back on after running a 40-50 minute cycle. Nothing would come on,...
Open the cabinet and look for lint buildup around the motor. Lint will act like a blanket and hold to heat in on the motor which in turn will cause it to shut down by way of it's safety mechanism. Check that out and post back your findings.
Oct 16, 2012 | Amana NED7200TW Electric Dryer
On my Bosch Nexxt 500 Series Electric Dryer keeps shutting off and gives the E-01 error we have check the exhaust air duct on back of the dryer and we have vacuumed the inside bearing shield what else...
Motor won't work
Lint screen hi-limit (thermal cutout) tripped.
Clean lint screen and clean lint and other debris from front shield, then replace hi-limit. Also check exhaust duct length & # of elbows.
Wire harness failed.
Run resistance or continuity checks to track down broken wire or connector. Replace failed wire harness.
Display shows "E:01" during drying.
Lint filter, air duct or air damper is blocked.
Air leaking past felt drum seal.
Air duct is too long, too small or has too many bends. Inadequate ventilation around dryer (i.e. in a closet).
Clean out filter, air duct and air damper.
Replace felt drum seal. If seal doesn't fit snugly onto drum, wet felt and dry it by running a timed dry cycle for 20 minutes (felt will shrink and fit drum snugly).
Shorten, enlarge, reroute and reduce # of bends in air duct. Move dryer to an area
Jan 09, 2011 | Bosch Nexxt 500 Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Jun 17, 2010 | LG DLG7188 Gas Dryer
Whirlpool electric dryer cuts out about 20 minutes into cycle and then will not start. If it is left to rest for 20 minutes it will start back up and run for 10 to 20 more minutes before cutting out. I...
its getting too hot. Take the panel off the front and take the cover off the blower wheel. It could be packed with lint. vacuum out all the lint that you can get too inside the dryer.
Nov 12, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool LER4634EQO Runs for about 2 minuts and shuts off.
It is possible your Cycling Themostat is not working properly. It determines at what temperature to turn heat on and off to maintain a consistent dryer temp. The High Limit Thermostat would turn off the heat but your dryer would still run. That leaves the Thermal Cut Off which is turning off your dryer. It might be faulty and turning off at too low a temp, or it might be doing it's job. In that case something else is wrong. If you can check the exhaust air temperature at the dryer, it should be under 175 degrees. If you are absolutely sure the vent is clear, then replace the Dryer Cycling Thermostat.
Aug 25, 2009 | Dryers
Bosch Nexxt 800 series dryer E01 error
My wife has a Bosch Premium dryer that had drying problems. The lint filter would get cleaned but the machine still did not operate correctly, as you explained above. Her machine was made in 2005 and the lint screen, the plastic slotted unit in front of the lint filter was the problem. It gets clogged up with hair/lint that never makes it to the filter. I tried a shop vac to vacuum it but the problem was still there. Get a pistol cleaning kit for a 22 cal gun. Pull the lint filter out & then take the pistol rod and insert it from the drum side into each slot and pull out the tons of lint. Pull the lint off the rod when done and take a flame to burn the rest off as the rod is a brass brush with small wires on it.
Jun 14, 2009 | Bosch Nexxt 500 Plus Dryer
My dryer operates well but cuts off during operation.
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Jan 29, 2009 | Whirlpool LER5636P Electric Dryer
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Lint Filter
hi there,
i can understand your frustration. i have reviewed the information that i have from Bosch and they indicate that the lint filter indicator light should only come on as a reminder but should not shut off the dryer.
here is my recommendation and also a question:
the dryer is shutting off due to the fact that it's overheating. it's a safety precaution from the manufacturer and it's built in to prevent the lint collected in the lint filter, since it's highly flammable.
check the venting in the back or side, wherever it was installed.
the vent tube is often the cause for the dyer to stop functioning.
if that turns out to be okay, the dyer is equiped with a sensor on the heater. it is possible that it's opening due to the heat generated by the dryer that has nowhere to go.
does the display show any error messages?
can you tell me what they are?
thanks again
Sep 24, 2008 | Bosch Nexxt WTMC 6300 Electric Dryer
Whirlpool WED5100SQ Front-Load Electric Dryer Logo
80 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
