Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Lamp reset on a panasonic model pt-50lc14-k
How do I reset the lamp reseton a panasonic model pt-50lc-14k
  • 647 Answers
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Posted on Nov 12, 2009
How do i reset air filter warning on a PT-50LC14
Posted on Jan 17, 2010
Does my panasonic hdtv 1080i pt-50LC14 have a lamp
Yes it does! Behind the front bezel under the screen. you can buy it here. http://projectorlamps.com/panasonic-dlp-tv-bulbs-pt-50lc14.html PT 50LC14 Panasonic Genuine High Quality Original Projector Lamps now...
Refer to the manual or the instructions that are shipped with the lamp.
Apr 25, 2015 | Panasonic Televison & Video
Where is the lamp housing for the Panasonic
The lamp housing is located behind the front cover panel.When you open the front panel you can access the lamp unit screw.
thanx
Jul 21, 2010 | Panasonic PT-50LC14 50" Rear Projection...
How reset the lamp in panasonic tv PT-50LC-14 ?
While holding Volume Down button on TV Front and press and hold Play/ PIP button on tv Remote at same time for 6 or more seconds to reset lamp hours.
TV will show lamp reset message on screen.
Thanks.
May 02, 2010 | Panasonic PT-50LC14 50" Rear Projection...
How do I reset my lamp timer on a panasonic HDTV
go into menu.... and you will find lamp setting. reset it to zero hours
Nov 17, 2009 | Panasonic PT-50LC14 50" Rear Projection...
I need to know how to reset an indicator light fo a panasonic pt-50lc14
Panasonic Lamp timer reset.
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue.
asnowman
Oct 13, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Reseting The Projection Lamp Hours Meter
If you need the original remote, you can order the original Panasonic replacement remote control for this model (PT-50LC14) from a major Panasonic parts distributor at the link below:
Panasonic PT-50LC14 Replacement Part Remote Control
Sometimes there's a way to reset the counter by mashing certain keys on the TV itself in a sequence, but if your owner's manual doesn't specify this option, then you may have to get the original replacement remote to be able to reset it.
Apr 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic tv model pt-50LC14 will not turn on
First, turn off the tv. Once the fan has stopped, unplug the tv. Remove the front cover from it latches (takes up most of the area below the screen). On the left is the lamp door. One screw holds the door. Remove lamp door. Looks like one screw holds the lamp assembly. Loosen screw and remove lamp. Lamp may be hot if the set was running before you began the lamp replacement.
If you have a new lamp assembly, reverse the process. If a new lamp without assembly, change lamps. CAREFUL. No fingerprints on the new lamp. The oil in the fingerprints will shorten the life of the new lamp.
Reset lamp hours in the menu when done.
Sep 01, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
2,055 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
