Question about Sonic RecordNow! Deluxe v7 for PC
Sonic Record now troubleshoot.
A suitable drive was not detected. Please cancel or save this project, attach a drive, then check for drives above. This is the message I get when I try to burn a regular music Cd. Prior to this I deleted a few programs I do not use at all. I need help. Thanks.
  • 4,924 Answers
This masage you get when you didnt choose the recorder ...or ..you have a larger project and auto sected a dvd instead of a cd..and you only have a cd writer on the computer ...so ...it does not see the recorder ...so it offer s the posibility to choose a folder to save the project as an image file ...for later burning...
Posted on Nov 12, 2009
  • Catalin Turcu
    Catalin Turcu Nov 12, 2009
    by the way ..if this is not the case...maybe the program is corrupted or not compatible ...so if I was in your place ..i'll use the windows burner for cd-es just add in the folder of the E drive ...and with a blank cd in ...press add this files to cd ...this for data cd ...and mp3...if you want a track cd ...playable in any cd player ..use the windows meda player to burn ....
    for any other and complex projects ...download and install Nero 7 ....its the most reliable I seen around...and its very complet
    http://www.mediafire.com/file/jz4tj2mumm...
How to detect sata hard drive P4M800-M7 Motherboard the sata hard drive can't detect
Hi fleetpio,
1. How to detect sata HD?- I am assuming that you have fixed the hardware part. During POST (Power On Self Test) press delete key inyour keyboard.
2. After pressing delete, a menu like the image above will appear. use arrow key to navigate, enter to select, +/- to modify values, Esc to exit current menu and F10 to save settings. proceed to Features Setup and press enter.
3. Another menu will appear like the image shown above, on the Onboard SATA-IDE from IDE change it to SATA-IDE.
4. Press F10, Saves the current configuration and exit setup.
5. To verify if the SATA hard drive has been detected, look on your POST if the HD appears. If the full screen logo appears repeat Step1 proceed to Standard CMOS Setup, check if youre HD appears.
Hopefully this information helps.
Thank you for using FixYa.
Sep 01, 2011 | EliteGroup P4M800-M7 Motherboard
Creater 7 will not record dvd or cds
If you are getting an error "No dvd/cd drive detected", you need to delete the roxio certificate.
Goto C:\program data\, find the roxio or sonic folder and delete it and restart the computer.
Regards,
Shrey
Jul 15, 2010 | Roxio Easy Media Creator 7
HOW DO I RECORD TV USING MY TEAC WITH BUILT IN RECORDER
You can ONLY record to the INTERNAL drive, there is NO facility to do as you wish. You could of course, using a TV/Video capture card, and suitable DVR software, and a PC, and IF your TV has a "Monitor Out" Composite Video Yellow, & Audio, Red & White. then you could stream the Video & Audio, to the TV/Video capture cards Inputs, and save, as a Video Format to the Hard drive IN the PC, or to an External drive, or whatever you wanted to. That's the only way I know of doing what you want.
Mar 27, 2010 | Televison & Video
Doesn`t work all the time and makes a whirring noise, do i need to buy a new cd/dvd drive?
Before you beginTo determine if the CD or DVD drive displays on the My Computer screen, follow the steps below.
  1. Turn on the computer and remove any discs from the CD/DVD drive.
  2. In Windows 98 and Me, double-click the My Computer icon on the desktop. In Windows XP, click Start and then My Computer .
  3. A CD/DVD drive icon displays on the My Computer screen when Windows recognizes the drive. If Windows recognizes the drive, find and use a section below that pertains to the CD-writing software with the issue.
  4. If the drive does not display on the My Computer screen, go to the Microsoft support website and search for documents on missing CD DVD drive .
RecordNow by Veritas/HP/Sonic does not recognize the CDRW or DVD+RW driveIf RecordNow does not recognize the CDRW or DVD+RW drive, follow the steps below.
NOTE: Install any updates for the RecordNow engine available on the Sonic support web site (in English). Step 1: Uninstalling RecordNowTo uninstall RecordNow to reset the software and cause it to look for the CDRW or DVD+RW drive again, follow the steps below.
NOTE: The steps below pertain to Windows XP.
  1. Click Start and then Control Panel .
  2. Double-click Add or Remove Programs .
  3. Select Record Now and then click Add/Remove .
  4. Follow the on-screen instructions until the uninstaller finishes.
  5. Select DirectCD and then click Add/Remove .
  6. Follow the on-screen instructions until the uninstaller finishes.
  7. Remove any discs from the drives and restart the computer.
Step 2: Installing RecordNow using Application RecoveryAfter Windows restarts, install the RecordNow software to begin creating CDs.To install the RecordNow software, follow the steps below.
  1. Click Start , All Programs , HP Tools or Compaq Tools , and then Application Recovery .
  2. Click Application Installation and then click Next .
  3. Select HP Record Now or Sonic RecordNow! and then click Install .
  4. The installation automatically installs all files. Follow the on-screen instructions.
  5. Restart the computer after the installation completes.
The HP Record Now or Sonic RecordNow! software should now recognize the CDRW drive. Back to topRoxio (Adaptec's) Easy CD Creator does not detect the CDRW driveEasy CD Creator produces an error message when it is unable to detect the drive, such as: There are currently no supported CD Recorders available...To prevent these errors from occurring, follow the steps below.
NOTE: Windows XP is not compatible with Easy CD Creator 4 and earlier. If the HP Pavilion computer was updated to Windows XP from Windows 98 or Me, use the native CD writing ability in Windows XP or purchase and install CD writing software that is compatible. Step 1: Installing updates for Roxio (Adaptec) Recording Software If the recording software is from Roxio (formerly Adaptec), go to the Roxio software updates page (in English) to obtain any software updates that are available for Easy CD Creator (with or without CD Copier or Direct CD). If Roxio still does not detect the CDRW drive after installing the updates, continue to the next step. Step 2: Changing the CD drive letter back, if it changedUpgrading to Windows 98 or Windows Me can change the drive letter to a different letter and make the drive undetectable to Easy CD Creator. To change the drive letter back to F or another previously designated letter, follow the steps below.
  1. Right-click the My Computer icon on the desktop.
  2. Click Properties . The System Properties window opens.
  3. Click the Device Manager tab.
  4. Click the plus sign next to CD-ROM .
  5. Double-click the CD-ROM name and then click the Settings tab.
  6. Under Reserved drive letters , select M (or the previously assigned letter) from the drop-down list. Be sure that both the Start drive letter and the End drive letter are the same.
  7. Click OK , Close , and then Yes .
  8. Restart the computer. If Easy CD Creator continues to fail to recognize the CDRW drive, continue to the next step.
Step 3: Uninstalling Easy CD CreatorIf the above steps fail to make Easy CD Creator recognize the CDRW, recover Easy CD Creator by uninstalling it. Recovering Easy CD Creator resets the software and causes it to look for the CDRW drive again. Be sure that you have the last recovery disc of your Pavilion recovery disc set before continuing.uninstall Easy CD Creator, Step 4: Installing Easy CD Creator using Application Recovery
Jan 17, 2010 | HP Pavilion dv6000z Notebook
Pendrive more than 2gb dont detect
usually 2.0 USB driver donot detect bigger capacity pendrives. so you need to install the driver for suitable capacity
Jan 15, 2010 | Vantec 1 Bay NexStar 3 USB 2.0 External...
My 2GB transcend pen drive is not detected by any computer.this is the first time. pen drive JF V30/ 2GB , Mic-D33193 and SrN. 510747 1741 Please Reply me.
My 4GB transcend pen drive is not detected by my computer.I have use it before 2 times. pen drive JF V30, S/N. 302925-0046 Please Reply me.
Dec 30, 2009 | Transcend T.sonic 612 MP3 Player
I purchased a Dell Computer back in 2004 which came with Sonic Digital Media Plus v7. My PC has Windows XP Operating System. A few days ago I decided to install Version 6.0 of Roxios Easy CD/DVD Burning...
Try uninstalling Roxio and the Sonic drives and run Fixit. Then reboot and install Roxio first then the Sonic driver.
If this doesn't work uninstall again as previously, install Roxio and check the CD/DVD if necessary run Fixit then install Sonic driver.
Aug 01, 2009 | Computers & Internet
All drive not detected
Check your power supply that its working or not. If its working then
Please check all the cable inside your system and then try attaching 1 by 1 i.e. attach first hard disk and than start your machine and see that it is detecting or not.
If its detecting then attach cd-rom and start your machine.
If its not detecting then remove hard disk and attach CD-ROM only.
If CD-ROM is also not detected then there is problem with your cable.
Mar 16, 2009 | ASUS P4V8X-X Motherboard
Hard Drive is Full
Check the settings on your Sonic Record Now. I think you have it set to copy data to your hard drive, look for this in the options menu. You should clean out all temp files too in case it is storing them there from the DVD sessions.
Nov 07, 2007 | Toshiba Satellite L25-S119 Notebook
Sonic RecordNow! Deluxe v7 for PC Logo
228 people viewed this question
Top Sonic Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Are you a Sonic Computer and Internet Expert? Answer questions, earn points and help others
