Question about Whirlpool Dryers
We have a Whirlpool Imperial 8 cycle 5 temp Ultimate Care Heavyduty Super capacity plus dryer. It's about 12 years old. It runs fine but seems to be taking longer and longer to dry. 4 bath towels and a few washcloths take well over an hour to dry on medium. They seem to dry better on low, but still we must use very small loads. Should we replace the element? Also, the dryer is situated in the center of the house and the duct is maybe 25 feet long.
  • Whirlpool Master
  • 7,482 Answers
The first thing I would check is to make sure the vent hose is clear of lint. An exaust full of lint will cause the problem you are talking about.
Most of the time either the heater coil is working or it is not working.
If after you make sure the machine, and hose is clear of lint and it still does not dry then I recommend the following:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Posted on Nov 12, 2009
Turns on but doesn't heat up
most likely heating element needs to be replaced.most can be accessed by removing back panel. also a thermostat switch may be faulty.
Aug 09, 2009 | Dryers
Whirlpool Ultimate Care II Super Capacity Plus
BETWEEN THE MOTOR AND TRANSMISSION THERE IS A COUPLING THAT SERVES AS THE BELT PART # 285753A REPLACE THAT WILL SOLVE YOUR PROBLEM
Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool, top-loading Ultimate Care, 20 lb washerm
The ticking sound is coming from the drive motor.
Removing the back and peering into the guts will tell you if there is a shredded belt causing the problem.
If the transmission has failed, the last one I bought years ago cost ~$130 wholesale.
Jul 19, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryers Logo
168 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
