Question about Watches
I need an Okley Time Machine titanium
I need an Oakley Time Machine titanium bracelet...where can I get it?
  • tacinari Nov 12, 2009
    I dont have a dealer near home...can I buy it online?
    Genius:
  • 1,689 Answers
All dealers have em
http://www.oakley.com/dealer
Posted on Nov 12, 2009
WHY DOESNT THE SECOND HAND MOVE?
It probably isn't the second hand, but the sweep timer hand that is only used in Chronograph mode. If it is indeed the small second hand down at the bottom of the watch face, try pulling the crown, and moving the hands and then depress the crown again.
May 10, 2015 | Oakley 12 Gauge Chronograph Stainless...
From where i can buy a bracelet for Tissot PR 50.
mcdevito75 here, Ebay is a great place for your Tissot watch band, or you can check with any small watch repair shop in your area, specially if you want a band directly from Tissot.
Oct 26, 2010 | Tissot PR50 Titanium Large Bracelet Watch...
Bracelet pin rusted off
You should be able to poke it out with a pin. Is it the pin in the bracelet itself or the one holding the bracelet onto the watch?
Jul 24, 2010 | Casio PRG60T-7 Wrist Watch
Where can I get the tools to open the wath to replace the battery?
You can get the tools needed on ebay, uner Jewelery, watch tools. mcdevito 75
May 21, 2010 | Oakley 4 D Bullet Watch Titanium Case with...
HOW TO CHANGE BATTERY ON AN OAKLEY BULLET WATCH
Open the watch case back, release the upper contact (unclip or unscrew it), memorize the writings on battery and the way the battery was placed in. Buy exactly the same battery, insert the same way in and close watch case back. Reset the watch and you are done. Some watches need a shortcut to be made before resetting. This should be written on the label covering the battery. Rate me, plz.
Mar 15, 2010 | Oakley 4 D Bullet Watch Titanium Case with...
My gunmetal titanium band (only half of the band is broken, what do I need to get it repaired or replaced???
some watches provides bracelet parts to replace, like rado, tissot etc...otherwise you have to replace whole bracelet, as per my experience titanium cant be solder nor repair
Feb 23, 2010 | Skagen Signature Mesh watch
How do I get the pins out of the titanium band for Casio PAW1500T
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Jul 09, 2009 | Casio PAW1500T-7V Atomic Solar Pathfinder...
Tissot T-Touch T33.7.788.51 Bracelet replacement
Sounds like it's broken @ a factory sealed link (non servicable). Local jeweller should be able to order & fit you a new one
Feb 19, 2008 | Tissot T-Touch T33759851
Watches Logo
74 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
