Question about HP Pavilion a805n (PS519AA) PC Desktop
No power HP Pavillion A805NI was using my internet when the computer froze. I was not able to turn it off with the on and off switch and in the end I had to turn it off thru the power strip. I waited a few seconds before I turned it back on, but nothing happened. It wouldn't turn on at all. I tried a different outlet, made sure that all the cables were in place, but to no avail. The computer won't turn on. The power supply has a green light that is blinking when the power is turned on, but that is about all.
    Genius:
  • 1,601 Answers
The power supply should be replaced.
Go to Blinking LED section.
Here are steps to take from HP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=449144&lang=en
Posted on Jan 07, 2008
2 Suggested Answers
Sunil Panem
  • 80 Answers
SOURCE: HP Pavillion A805N
Hi
diconnect all the external devices and also the power cable from the comp...press and hold down the power button for abt 30 seconds and then turn on the comp....
if the light is still blinking or the comp doesntturn on, reseat the power supply cables to the motherboard and also to the hard drive....
notify me if u still have any problems and may be u ll have to replace the power supply
Posted on Jan 30, 2008
How to access the power switch on HP Pavillion g6-2073ca
Are you on battery or over a power cord?
If you're on battery, try with the power cord. If the same behaviour happens, it can be that the battery is out of order.
May 30, 2017 | HP Computers & Internet
HP Pavillion a1514n Won't Turn On
Yes even with the green light on it could still be the power supply. Have you pulled the power, opened the case, and pulled the BOIS battery? Could be the BOIS needs to be reset. You might also pull all the memory chips, turn it on and see if you get a beep code. I have had that happen in the past. Then I would replace the power supply (if you have an old one laying around use it to test, with just the MOBO plugged in). If the power supply fails, that leaves only the mother board as the issue.
Good luck, I hope one of these suggestions works for you.
Jun 29, 2012 | HP Computers & Internet
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
Jun 29, 2012 | HP Pavillion dv9740us Notebook
Hi. I went to switch on my HP Pavillion Laptop one day when it unexpectatly froze during startup. I clicked the power button of the laptop and everything seemed fine with the lights turning on and the...
That blinking cursor is the way in which the BIOS of the laptop is telling you that it can't load Windows because it's too corrupt There's nothing more you can do apart a full reinstall. Use the recovery disk that has came with the laptop when you bought it.
Jan 15, 2011 | Computers & Internet
''My HP Pavillion ZE5300 Laptop Doensn't Come On At All!''=v.v=
when you press the power button, does any light flash for 1 second?
remove the memory, hard disk, cd writer from the laptop. then try to switch on again. do it using the power adapter.
if it doesnt come on then its an internal problem. you will have to open the laptop case and remove all parts for test
good luck
Oct 06, 2009 | Computers & Internet
I have a hp pavillion a820n..i was watching youtube quickplaylist 1 day.Then the comp froze. I turned it off,and ever since havent been able to turn it back on.. I tried unplugging power cord and surge...
Check the cable going to your monitor and from the monitor going to the back of your computer, take it out and put it back in. Check also the power cable of your monitor.
Jun 02, 2009 | Computers & Internet
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
Hp pavillion power problem
Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure:
CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC.
1. Disconnect all cables from the computer, including the power cord.
2. With the power cord disconnected , press the power button on the front of the computer for five seconds.
Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply.
3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America.
Performing this step ensures that the voltage switch is engaged and set correctly for your country/region.
4. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet and test to see if the computer can turn on.
Dec 22, 2008 | HP Computers & Internet
Computer won't boot with chime-ing
If it beeps in a pattern (example 2 long 3 short) then I would need to know the pattern. With that pattern I could try to determine when the faulty component is.
Jan 23, 2008 | HP Pavillion a818n Desktop PC (Refurb)...
HP Pavillion A805N
Try remove and clean the memory fixed back and switch on the system.
if not solve.
If the VGA is add-on remove it and clean and fixed back and switch on the system.
if this all not solve notify me for further instructions.
Jan 07, 2008 | HP Pavilion a805n (PS519AA) PC Desktop
HP Pavilion a805n (PS519AA) PC Desktop Logo
242 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
