Question about U-Line Icemaker
It will make one or two ice cubes that quickly melt. The water keeps running.
  • 43,501 Answers
Check the float that lets in the water. It sounds like the float is stuck and water is continuously running through, that will keep the ice from forming
Posted on Nov 12, 2009
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
Hi have LG fridge, ice maker making ice but freezes into one solid block instead of staying in individual ice cubes making it impossible to dispense do you have any ideas a sto why this is happening and...
Sounds like this is a water level problem. Too much water is being released into ice tray, which raises the water level above the depth of each cube form, causing one big cube. You can adjust the water level.
Check this out:
How to Adjust the Water Level on an Ice Maker eHow
Jul 19, 2014 | LG LSC26905TT Side by Side Refrigerator
Will not dispense ice
commonly what you will find on that model is the main control board on the back of the unit is the source of your issue, it begins like a computer virus where the unit will render the water in the door feature useless, next goes the ice delivery sys, then the unit does not defrost properly causing cooling issues. But before running out and getting a new control board go by this check list first: 1) make sure your ice bucket is properly seeded, 2) make sure the ice in the bottom of the bucket is not melted together if so empty good ice in seperate container and put back in freezer quickly to avoid melting then run hot water in ice bucket to melt remaining bad ice afterwards completely dry ice bucket and put good ice back in and see if it works properly, 3) make sure the auger mtr is not seized due to door being left open and humidity freezing in mtr gear.
Apr 16, 2012 | GE Refrigerators
I have a Whirlpool French Door Refrigerator Model #G17FVCXWY and the ice maker jams up about once a month (ice doesn't completely dump into the door bin, water refills into the ice maker, then refreezes to...
HI, we have the same problem with ours from time to time. It is a engineering flaw, bad design, the ice cubes are kept in the refrigerator section, which is about 38-40 degrees. So the ice cubes melt, the only way to keep it clear is to use ice cubes every day and not let then thaw and freeze.
Mar 11, 2011 | Whirlpool Refrigerators
My subzero 650 has melted and refrozen cubes under normal cubes - I have emptied the ice cube tray three times, made sure it is dry before putting it back, and each time there is eventual frozen water...
maybe the water valve keep open. try replace the water valve. the ice maker energized the water valve. and release water. MAYBE in each cycle after energized the valve this one keeps open. ttry replace is really simple..... good luck...... leave a comment if it this good for you
Jan 12, 2010 | Sub-Zero 650 / O Bottom Freezer...
Is it true that if you remove the white box where the ice cubes fall into, that it will stop the ice cubes from being made? I am interested in temporarily stopping the ice cubes from being made (4 months...
Removing the box may stop ice making on some refrigerators but not all. Look for an on-off switch inside your ice maker. Turning it off will not only stop the cubes from forming but in some cases will also stop the freezing action so you should remove any cubes that are there or they will melt and the melt water will run out of the ice maker. If there is no on-off switch you can raise the sensor arm up or block the ice detector beam to trick the ice maker into a "full" mode. That will stop the ice making function but not the freezing function. You could also turn off the water supply to the refrigerator if you do not need the water dispenser to work when you are not making ice cubes.
Oct 16, 2009 | Refrigerators
Ice maker trap door does not close tightly, ice cubes become one big cube and water drips from the ice cube trap door. need some adjustment to this door so cubes do not melt and water run out of storage...
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
There is a solenoid that operates the door that could be sticking.
The hinge on the door could be broken or the bracket it goes in could be broken.The spring could also be off or broke. You'll have to look to see what's wrong.
Sep 23, 2009 | Refrigerators
Ice maker
MAKE SURE THE DOOR CLOSER IN THE DISPENSER IS OPERATING PROPERLY. IT SHOULD SLOWLY CLOSE THE DOOR AFTER YOU STOP PRESSING ON THE PADDLE.
EITHER THE DOOR IS CLOSING TOO QUICKLY, NOT AT ALL, OR THE DISPENSER IS RUNNING AFTER THE DOOR HAS CLOSED. CHECK THE OPERATIONS OF EACH OF THESE AND SEE IF YOU CAN TELL WHICH.
Apr 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Tray Freezes & ice builds up around internal workings of ice cube holder
Check and make sure you door seal is tight. Take a dollar bill and place it between the door jam and gasket, close the door and then pull the bill slowly out. It should be rather tight all the way around. So you will have to do several checks all the way around the door. If you have a bad spot call and have them either replace the gasket or adjust the door.The other thing you can do (I have found most if not all manufacturers require this) empty your ice maker once a week. The problem comes from your refer being a self defrost. There is a heater coil that gets as hot as a range element to defrost the evap coil. It is the defrost cycle that causes the ice to melt down a bit. And the defrost cycles every 12 to 24 hours causing the cubes on top to melt down some. So as your bucket fills whatever was on top melts a bit and by the time you are ready to use several layers may be melted causing them to stick together.
Jun 07, 2007 | KitchenAid Superba Architect KSCS25INSS...
U-Line Icemaker Logo
182 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
