I have an hp 511w that displays the message file missing or corrupted. WINDOWSSYSTEM32CONFIGSYSTEM that is the last screen i can access. anything i try to do (like push f8 or f1) doesnt work. i cannot start windows. period. i dont have the original start up or installation cd (windows xp home ed) so im not sure what to do. i have another desk top but it doesnt have a floppy drive and its a vista. what can i do short of spending a ton of money?
  • 558 Answers
You most definately have to restore windows.That system 32 config file is part of the boot process.Yours got corrupted .I take it your computer is out of warranty.If its not try calling hp and maybe they might send you recovery cd.
Good luck
Posted on Nov 12, 2009
I have an hp 511w that displays the message file missing or corrupted. WINDOWSSYSTEM32CONFIGSYSTEM that is the last screen i can access. anything i try to do (like push f8 or f1) doesnt work. i cannot...
The first thing I would do is remove the cables connected to the back of the CD burner and try booting it once again. BE SURE TO TURN YOUR SYSTEM OFF FIRST!!!
If it boots up, then replace your burner. It could be a dozen other things, but this is where I'd start and I've been repairing systems for 30 years. Good luck!!
Nov 11, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Hi, I have a pc desktop is HP 750n with os xp home edition. so when I turn on the pc on screen appear this message: (Windows could not start because the following file is missing or corrupt:...
you may have an internal recovery in the bigining of your system press pause, and check for recovery, by pressing the key that is telling u TO use coud be F2 OR ELSE and follow directions
Nov 11, 2009 | HP 290563-B21 Network Adapter
I get a message that Windows could not start because the following file is missing or corrupt: /WINDOWSSYSTEM32CONFIGSYSTEM I bought this thinkpad preloaded with Windows XP and do not have an original set...
About the only thing you can do is buy or borrow another Windows XP install disc as this is the only way you'll be able to extract the missing file using the repair console. Hope this helps.
Sep 19, 2009 | Computers & Internet
When I turn the power on (not the computer off/on) the unit starts up by itself. The screen displays the message Windows cannot start, the following file is missing or corrupted....
This could be a variety of things, but a lot of CPU's will do this if you have a disk in the disk drive or even a thumb drive. Worst case is you have a failed hard drive and you could may need to reinstall windows to get it working. Good luck
Jul 13, 2009 | AcerPower 1000 (AP1000EA380M) PC Desktop
Computer does not boot
you have to installed a new Windows xp but when he ask the repair and new installation the go for the repair you got the old files as it is
Apr 15, 2009 | Sony VAIO (PCWA-A200)
Aspire 5610 file is missing or corrupt
The error message means you use the Windows installation CD to repair Windows by booting up with the Windows CD and select r at the first screen to start repair.
Apr 08, 2009 | Acer Aspire 5610-2328 Notebook
Windows xp corrupted
This is supposed to be caused by some missing registry entries in your windows installation. Not exactly sure why this is happening. May be you have some important files that cannot be copied due to a damaged CD. Microsoft replaces the media for you so that you can try installing using the replacement. Click here for more details
http://support.microsoft.com/default.aspx?scid=kb;en-us;326246
You can also try to recover the PC using recovery console. To do it follow the steps below
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:windowssystem32configsystem c:windows mpsystem.bak
    copy c:windowssystem32configsoftware c:windows mpsoftware.bak
    copy c:windowssystem32configsam c:windows mpsam.bak
    copy c:windowssystem32configsecurity c:windows mpsecurity.bak
    copy c:windowssystem32configdefault c:windows mpdefault.bak
    delete c:windowssystem32configsystem
    delete c:windowssystem32configsoftware
    delete c:windowssystem32configsam
    delete c:windowssystem32configsecurity
    delete c:windowssystem32configdefault
    copy c:windows epairsystem c:windowssystem32configsystem
    copy c:windows epairsoftware c:windowssystem32configsoftware
    copy c:windows epairsam c:windowssystem32configsam
    copy c:windows epairsecurity c:windowssystem32configsecurity
    copy c:windows epairdefault c:windowssystem32configdefault
  6. Type exit to quit Recovery Console. Your computer will restart.
Source:http://support.microsoft.com/kb/307545
Dec 29, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Have gone to black!
The error: Window could not start because the following file is missing or corrupt;
WINDOWS\SYSEM32\config\system
You can attempt to repair this file by loading the Win CD into your cdrom drive. Start the PC & press the F5 key every 2 seconds & windows boot menue will load.
Choose the cdrom drive that has the Windows CD in.
Select "r" at the first screen to start repair.
Once back in windows run a full system virus scan.
Good luck & have a great day!
Mar 14, 2008 | Computers & Internet
Having problems with my compaq Persario 2500
this problem occurs when you try to update drivers in the computer..sometimes windows XP cannot update the driver and that corrupts system.ini file as it has a lot of bad entries..Due to this you will get this error mesage..No its not due to virus.its due to an attempt to change system.ini file
Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
That means the System Registry Hive has become corrupted.
There are two ways to get back up and running. The easy way which doesn't always work, and then there is the hard way.
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Oct 11, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
