Question about Brother MFC 6800 All-In-One Laser Printer
Pls open cover
It says pls open cover i have three of these that say the same thing .
i dont see anything in there and no paper jams can you help thanks .
  • Anonymous Jan 26, 2008
    I also have this problem and so many more -- I think this is a piece of junk and has outlived its usefullness -- I used it for 2 years.
  • 11 Answers
This could be caused by a series of things the best way is to check the error code. While powering up hold down MENU/SET
then you might see MAINTENANCE or you might get a machine error. enter 82 if you see maintenance. It should say Machine Error 00. Meaning no problem. Any other number will let a service tech know what the problem is. Press STOP then enter 99. It might reset at that point.
Posted on Jan 19, 2008
Paper jam dx7400
Here's how to clear the paper jam,
  • Open the paper tray and remove all the loaded papers.
  • Open the printer cover and check through for any stuck papers and remove them manually.
  • Close the cover and turn the printer off.Wait a few minutes then turn it on.
Now try to run a status print by:
  • Turning on the printer.
  • Load a paper
  • Press the right arrow > three times.
  • A status sheet is printed.
Hope this helps.Thanks!
Nov 02, 2011 | Office Equipment & Supplies
When printing i get the paper jam message have checked for paper jam but dont see anything
Open the cover on the back of the printer sometimes paper is stuck in there and thats why you can't see it.
Sep 29, 2010 | Dell 1700n Laser Printer
My cannon printer MX700 just now paper have jam inside. After i taken out of paper that jam inside my cannon printer have a error of 6A80 and it can't fixed. Pls help. Thanks.
The 6A80 indicates that the mechanism called the `purge unit' does not work correctly. In some cases after a paper jam, some paper gets in the unit. Try this:
Turn on the unit and open the cover. Hopefully, the printhead will come to the center. If it doesn't, unplug the printer and try to move the printhead by hand, to the left. Do not force it. If you are able, get a flashlight and inspect the area inside the unit to the right. There may be bits of paper in that area. Being careful, remove it with a tweezers or some such tool.
If you cannot see anything, then the machine will need to be dismantled for service. I recommend authorized service.
Sep 20, 2010 | Canon MX700 Office All-In-One InkJet...
I have a paper jam and it says to open the front cover, put the front cover just shows the ink cartridges and there is no visible paper jam. how do i find the jam and remove it? It's a canon image...
The paper jam could be in three places.
Open the cover of fixing section, its above bypass, and check for jamed paper
Open the transfer cover, these cover has handle and it goes by pulling toward you, and check for jamed paper.
In hight of first paper cassette, on left sideway of copier, beaneath the bypass are small door, open it and check for paper jams. Be sure that you closed them properly because if they arent closed the check printer cover message will arrise.
Hope that helped
Jul 07, 2010 | Canon ImageRunner 1600 Copier
Recurrung jam message
if there's no paper jammed then a sensor might be dirty, the printer has several sensor along the path of the paper to detect its flow.
Mar 30, 2010 | Xerox DocuPrint C525A Laser Printer
this error indicates 1 of the following.
the front cover is open
the back cover is open
paper jam
usually its the back cover, either its not fully closed or the swing gate inside is not in track with the sensor, it has to be pulled out realigned and put back in.)
also possible there is a little piece of paper jammed inside the front or back area.
thanks adi
Aug 19, 2009 | Brother HL 2140 Laser Printer
My printer always said ''open back cover and then remove the paper jam'' what's that means? also can't print anything.
open the back cover to remove any paper jam on your printer, follow on it. Maybe there's a paper inside hanging in the ruler, take a look.
Jul 22, 2009 | Office Equipment & Supplies
Epson R265 paper feed problem
Paper feeder problem. You must open case and paper feeder.Check for all screw. spring, rubber and lubrication. If you never done, find diagram at is printer paper jam berfore? and clearing jam by pulling paper form back?
Jun 28, 2009 | Epson Stylus R265 InkJet Photo Printer
Paper jam message but there is no paper jammed. opening and closing cover doesn't work.
hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
Apr 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Brother MFC 6800 All-In-One Laser Printer Logo
270 people viewed this question
James Cagle
James Cagle
Jim Keysor
