Question about Yamaha DSP-A1 Receiver
Av amplifier RE:-YAMAHA DSP-A1 AV AMPLIFIER, PROBLEM IS=== UNABLE TO GET LIGHTS ON DISPLAY PANEL TO DISPLAY ANY INFO?? THEY COME ON INITIALY FOR 3-5 MINS THEN PROGRAM DISPLAY ALL GOES OFF,UNABLE TO ASCERTAIN WHERE I AM ON SUSTEM SETTINGS.AMPLIFIER WORKS OK OTHERWISE.
  • Anonymous Sep 28, 2008
    Display goes off after a few seconds. Before it came back on again, but now it mostly stays off. I also have problem with the volume control, it can not be operated by the remote control. I can operate the volume control manually though. FYI, the DSP-A1 has a motorized volume control.
The display problem is because the solderings on the back of the display are broken. To fix it you have to open the amp and redo the solderings (there are about 50 or 60 of them). There is a Youtube video that shows how to do it. I have fixed this on my DSP-A1.
I also have the problem with the motorized volume control. I have tried cleaning it, and it works for a few days, then it's stuck again. I guess I will have to replace it to have it fixed permanently. The part number is VZ621400, a new one costs about 40$.
Posted on Jun 23, 2009
Sounds like a capacitor problem in the power supply to front panel display,another common problem is everything o.k for a few miutes since power on then goes off like you say which could be down to dry joints on the vacuum display panel whick go open circuit when everythig warms up (open circuit meaning non contact) in non tech term.
Posted on May 02, 2008
6ya staff
SOURCE:
How do I connect my 901 equalizer /speakers to the yamaha rx-v633 receiver?
Sorry, it doesnt look like you can hook up an external EQ while still using the amplifier section of the yamaha. Instead, You would have to use the preamp out to go to 901 EQ, out of the EQ into another stereo amplifier, then to the 901 speakers. Personally, to power the 901's properly, I'd use another external amplifier. You will barley get 75watts per channel out of the receiver to power the 901's
Jan 03, 2015 | Yamaha Av Reciever Rx-v793 Cinema Dsp...
What is the replacement of transistor 2sd 1915?
http://www.datasheetarchive.com/buy/2SD1915.html Costs 87 cents from MCM
Nov 17, 2014 | Yamaha Audio Players & Recorders
Our 2nd zone won't work, we get the error saying check SP wires. The wires seem connected correctly. We also can't change the volume on zone 2. The Yamaha unit is working otherwise.
U cant get an amplified out put form ur av receiver for zone 2. speaker a A and B is the same out put of frond left and right. it is not ZONE 2 output. U can get only a pre output for zone to from this receiver. U nee a separate stereo amplifier for using zone 2 .put an amplifier in the other room, connect the zone 2 pre out to it. And do the following setup in ur av receiver .
The receiver shows check speaker cable because its amplifier minimum impedance is 8 ohms . when u connect other speaker in speaker the total impedance will come under 4 ohms. Speaker b is not ZONE 2 in this amplifier
1. press the input selector button A or B to select the source component you want to setup.
2. press and hold LEARN (on remote) button about 3 seconds by using a boll pen or similar object ( SETUP and the selected component name appear alternately in the display window.)
3. press up or down arrow to select "zone2"
4. press LEARN to complete the Zone 2 setup.
5. press source select up arrow to display Zone2 in the window.
6. press an input selector button to select input source u want to listen to in the second room
7. u can control the component by using the component control area button
ok
Dec 26, 2010 | Yamaha RX-V2200 Receiver
The receiver works, but the LED display does not come on.
My Yahaha DSP-A1 had the same problem. Apparently its quite a common problem, caused by the heat from the LEDs causing the solder joints to fail.
I fixed mine by removing the front panel, and resoldering all the connections on the back of LCD panel - and it works fine now.
Its not particularly difficult, but is a bit fiddly and does require the use of a small soldering iron.
If you are tempted to try it, these links show help
http://www.youtube.com/watch?v=eiJRmpfKxBM
http://www.avforums.com/forums/av-amplifiers-receivers/1058423-yamaha-dsp-a1-display-fix.html
Best regards and good luck
Jan 06, 2010 | Yamaha DSP-A1 Receiver
HOW TO INSTALL THE 15 BAND EQUALIZER TO THIS
I dont know this amplifier, but if there's a tape-monitor button, you can insert the eq on the tape in- and output.
Kind regards,
Gerard
Jun 17, 2009 | Audio Players & Recorders
Yamaha dsp-a1
you need to set the ntsf or pal settings for hdtv and s-video is video1 video 2 or video 3 seting on input on remote
May 13, 2008 | Yamaha DSP-A1 Receiver
DSP-A1
Over the years the solder joints on the display panel become bad due to the heat that the display puts out. The way to rectify this take the cover off and dis-assemble enough to get to the display. Then using a soldering iron re-solder all of the joints on the board. You should be able to see the joints that are bad as they will wiggle. If you are un-comfortable soldering then try to find someone that is. There is a your tube video on doing this as I learned tonight. I have not done this procedure yet, but I have had the same problem for over 2 years. The display does not even work any more. Now that I have learned what the problem is I will be doing this when I feel like unhooking everything.
Jan 07, 2008 | Yamaha DSP-A1 Receiver
Remove on screen monitor display with out the remote
Check ebay for a remote. There are also several online dealers that sell replacement remotes. Do a search using "replacement remotes" and you'll find most of them. If you don't have the owners manual, I suggest getting one. It can probably be downloaded for free at Yamaha's website.
Sep 24, 2007 | Yamaha DSP-A3090 7-Channel Amplifier
Effect off
Dear Zforce, The Yamaha DSP A1000 has three different options of on-screen display. Try using the On-screen button on the remote control in order to remove the disturbing display. If this fails or if your remote control malfunctions then you should contact Yamaha for further assistance.
Oct 31, 2005 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha DSP-A1 Receiver Logo
441 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
