Question about Whirlpool GEW9250 Electric Dryer
Whirlpool electric dryer cuts out about 20 minutes into cycle and then will not start. If it is left to rest for 20 minutes it will start back up and run for 10 to 20 more minutes before cutting out. I have checked the lint filter and also checked the lint exhaust for any obstructions and there are none.
  • 126 Answers
Its getting too hot. Take the panel off the front and take the cover off the blower wheel. It could be packed with lint. vacuum out all the lint that you can get too inside the dryer.
Posted on Nov 12, 2009
The drying time goes for normal mode start at 34 minutes to 30 minutes left then drops to 20 minutes then goes down to 17 minutes left then suddenly it stops and says complete. so the normal mode doesn't...
Yes, I believe the "normal" setting is part of the sensor dry. So, if the sensors, bars located on the inside of basket, do not detect moisture, the time will decrease and eventually stop. Locate the sensor bars, get some scotchbrite pad, and lightly clean the two metallic "bars" on the inside of drum. I find alot of buildup from dryer sheets inhibiting the conductivity of the sensors. I would start from there. If that doesn't fix it then you may need to call for service. hope this helps.
Sep 29, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
My dryer a Whirlpool. will run for about 10 to 20 minutes, then cuts off. After about 10 to 20 minutes, I can start the dryer again (push start button) and it will run for another 10-20 minutes. ....This...
there is a hi and a low tempreture sensor best to check those for continuity first when the dryer heats up and gets to hot the hi will turn off the heater where as when the low gets to cool it will turn it back on
hope this helps
Apr 30, 2010 | Whirlpool LER4634J Electric Dryer
Dryer runs about 20 minutes on its cycle and cuts out. It will not turn back on without a 20 or so minute rest. I have checked the lint filter as well as the exhaust and they are both clear. Anyone have...
Check the exhaust path, where the lint trap goes. If there is lint in the path, it will retain heat that will shut the unit off. You can't just look and see, you will have to dismantle the path from dryer to final exhaust port to make sure it is all clear.
Nov 12, 2009 | Whirlpool WED5100SQ Front-Load Electric...
Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
Whirlpool dryer model LER7646EQ1
Thats what it's supposed to do hopefully the clothes are coming out dry. The dryer has both thermal sesors and fuses that tell the dryer when to heat up and when to cool down. So yes the heating element will come on and go off multiple times in a cycle.
Mar 31, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool electric dryer, Model LEC6646ANO. On
Make sure the internal and external exhaust vents are not blocked with lint.
Will it complete a 45 minute time dry and dry the laundry?
Mar 09, 2009 | Whirlpool Dryers
Humming noise, runs and stops thru out drying process.
You have a motor that has a thermal overload built into it. This is for the dryer's protection. My best guess is to replace the motor. But before you do all that, make sure the wiring is good from the receptacle to the controls in the back of the dryer. It could not have a good connection thus causing this noise.
Jan 29, 2009 | Whirlpool LER5636P Electric Dryer
My dryer operates well but cuts off during operation.
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Hunting boots no no!
If you have one of those fubuloso wrinkle guard whirlpools, they will buzz and start back up on their own in the cool down portion of the cycle the idea being the 2nd timer will keep the clothes from wrinkling by buzzing and then coming to life for a few minutes. Then it waits 10 minutes and if you aint got the clothes out or opened the door then it will repeat.
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
112 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
